Skip to main content
New
LGO-LTE-W
A compact 617–5925 MHz, 3 dBi antenna for LTE and LoRa® connectivity. Its small footprint and SMA male connector make it an easy fit for compact IoT installations where space matters
Outdoors
LGO-LTE-W
Product image
Product image thumbnail
LGO-LTE-W
A compact 617–5925 MHz antenna for LTE and LoRa® connectivity. With 3 dBi gain, an SMA male connector, and a much smaller footprint than the HGO-LTE-W, it’s an easy fit for compact IoT installations.
Vending & coffee machines
There's never enough space in those machines... until now!
Industrial cabinets
More room for better cooling and access - the maintenance crew will be happy
Remote monitoring
Tiny footprint attracts less unwanted attention.
Cold-chain equipment
In logistics, save space to save money... without cutting corners.
Asset tracking
When the inventory is compact, the antenna should be too.
Recommended for KNOT LR8G and LR9G kits, as well as KNOT Embedded LTE and KNOT Embedded LTE4 Global. Its compact size makes it particularly convenient for the smaller KNOT Embedded form factor.
Specification
Specifications
  • Product code DPD0830AL08
  • Suggested price $8.00
  • Tested ambient temperature -30°C to 75°C
  • Can be used indoors Yes
  • Can be used outdoors Yes
Documents
Brochure
.PDF
Brochure PDF first page
