Skip to main content
KNOT Embedded LTE4 Global
KNOT Embedded LTE4 is now available in a Global (EG25-G) version with expanded LTE band support for North America and other international markets. Industrial LTE/BLE/GNSS connectivity that fits anywhere. Originally designed for coffee and vending machines – perfect for all kinds of industrial automation. AT&T, T-Mobile certified.
LTE Cat4 mobile connectivity
Bluetooth for IoT sensors
DIN rail mounting supported
Gigabit Ethernet
GNSS/GPS
eSIM + Nano SIM
GPIO
2x2 MIMO
PoE Input
KNOT Embedded LTE4 Global is a tiny but powerful industrial LTE gateway designed for integrators, automation specialists, and IoT system builders. It fits into tight spaces, mounts directly on a DIN rail, and delivers reliable LTE Cat4 connectivity with Bluetooth and GNSS support.
The built-in Bluetooth scanner supports Long Range Bluetooth and Extended Advertising, enabling reliable communication with MikroTik Bluetooth tags and other BLE sensors. Gather telemetry, track assets, and securely transmit data over LTE from a single compact device.
Use it as a primary gateway, a backup link, or an IoT data collection node – everything is powered by RouterOS for maximum flexibility.
Background image
MikroTik Connectivity is available
for the USA region
One simple plan provides dual-operator access via AT&T and US Cellular for reliable nationwide coverage. Data plans follow the same pricing structure as our EU Connectivity offer.
With MikroTik eSIM, you can activate a data plan directly from your MikroTik account and get online within minutes. No physical SIM cards, no carrier contracts, no activation delays. Ideal for IoT deployments, remote installations, backup connectivity, and low-usage setups where fast and simple deployment matters.
Connectivity Offer
Background image
Sensor-ready GPIO header
For simple automation and monitoring (Digital input/Analog Input/OD output). All pins are 24V tolerant.
Background image
Powered by RouterOS
Full networking stack, VPNs, firewall, SMS control and notifications, automation, remote management, and so much more!
* The unit requires external antennas – choose the models that match your environment and customize the KNOT to your specific needs.
KNOT Embedded LTE4
is made for environments where space is limited but reliability is critical
Smart city infrastructure (parking, sensors, metering)
Coffee and vending machine monitoring
Industrial automation cabinets
Environmental & utility monitoring
Vehicle or asset tracking with GNSS
Retail kiosks, payment terminals, digital signage
LTE backup connectivity for existing Ethernet devices
IoT gateways for BLE sensors and beacons
Whether you’re building a new system or adding LTE to an existing installation, KNOT Embedded LTE4 adapts easily. It’s easy to integrate, easy to deploy, and built to perform in harsh environments – from smart city deployments to industrial automation and mobile tracking.
Product image
Product image
Product image
Product image thumbnail
Specification
Specifications
  • Product code EG25-G&KNe
  • Suggested price $89.00
  • Architecture ARM 32bit
  • CPU Cortex A7
  • CPU core count 1
  • CPU nominal frequency 800 MHz
  • RouterOS license 3
  • Operating System RouterOS v7
  • Size of RAM 256 MB
  • Storage size 256 MB
  • Storage type NAND
Powering
  • Number of DC inputs 2 (PoE-IN, USB-C)
  • Max power consumption 6 W
  • PoE in 802.3af/at
  • Cooling type Passive
  • PoE in input Voltage 12-57 V
  • USB C input Voltage 5 V
Mobile
  • 2G Category Class12
  • 2G bands 2 (1900MHz)
    3 (1800MHz)
    5 (850MHz)
    8 (900MHz)
  • 3G Category R8 (42.2Mbps Downlink, 5.76Mbps Uplink)
  • 3G bands 1 (2100MHz)
    2 (1900MHz)
    4 (1700MHz)
    5 (850MHz)
    6 (850 MHz)
    8 (900MHz)
    19 (800 MHz)
  • LTE Category 4 (150Mbps Downlink, 50Mbps Uplink)
  • MIMO DL 2x2
  • MIMO UL 1x1
  • LTE FDD bands 1 (2100MHz)
    2 (1900MHz)
    3 (1800MHz)
    4 (1700MHz)
    5 (850MHz)
    7 (2600MHz)
    8 (900 MHz)
    12 (700MHz)
    13 (700 MHz)
    18 (800 MHz)
    19 (800 MHz)
    20 (800MHz)
    25 (1900MHz)
    26 (850MHz)
    28 (700MHz)
  • LTE TDD bands 38 (2600MHz)
    39 (1900MHz)
    40 (2300MHz)
    41 (2500MHz)
  • TAC 01673800
Ethernet
  • 10/100/1000 Ethernet ports 1
  • Number of 1G Ethernet ports with Reverse PoE (PoE-in) 1
Peripherals
  • Number of SIM slots 1 Modem (Nano SIM)
Other
  • CPU temperature monitor Yes
  • PCB temperature monitor Yes
  • Bluetooth version 5.4
  • GPS RF connector type SMA
  • eSIM Yes
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
  • IP 20
Included parts
Note
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.1 download files for arm devices.
System Package
Default Packages
More in download page
Related Products
