Skip to main content
868 Omni antenna
The upgrade of our antenna kit for LoRa® with a 6.5 dBi Omni antenna for 862-876 MHz, 1m long SMA cable and mechanical holder for quick and easy mast attachment. Smaller size, increased durability, and added IP66 water resistance.
IP 66
868 Omni antenna
Product image
Product image
Product image
Product image thumbnail
After reviewing your suggestions, we went back to the drawing board and redesigned the Antenna kit for LoRa®. The new kit offers significantly higher durability in a smaller package – without sacrificing performance. The improved cable durability and the added IP66 water resistance with protection against powerful jets make this kit an excellent choice for all kinds of marine and coastal projects.
The unit comes with an SMA female connector, a strong 1m long "SMA male - SMA male" cable, and a mechanical holder for quick and easy mast attachment.
Mount this antenna on a 25-50 mm mast or on the wall and enjoy the superb coverage!
Specification
Specifications
  • Product code 868_Omni_antenna
  • Suggested price $49.00
  • Beamwidth Horizontal: 360°, vertical: 30°
  • Frequency Range 862 - 876 MHz
  • Weight 0.6 kg
Certification & Approvals
  • IP 66
Included parts
Documents
Brochure
.PDF
Brochure PDF first page
