Skip to main content
New
KNOT Gateway LR8
A rugged IP66 IoT gateway combining BLE 5.1, 868 MHz LoRa®, Wi-Fi, Gigabit Ethernet, LTE Cat 1 bis, and GNSS. Need Wi-Fi HaLow instead? The KNOT Gateway is also available in a 915 MHz HaLow version.
Gigabit Ethernet
PoE-In & surge protection
IP66
BLE 5.1
Dual-core ARM64 CPU
CAT1 bis LTE modem
Multi- GNSS GPS
SIM/eSIM
With the new KNOT Gateway, you can follow tagged equipment, pallets, containers, tools, and other assets as they pass through warehouses and terminals. But there’s more: you can tie various generations of tech together! The KNOT Gateway brings remote meters, sensors, and other IoT devices into your network with BLE and long-range sub-GHz connectivity.
Whatever language your IoT devices speak,
the KNOT gets the conversation going!
BLE 5.1
Turn Bluetooth broadcasts into useful, actionable data: track tagged assets, monitor telemetry, filter advertisements, and use RouterOS scripting to decide what happens next.
Long-range IoT
Go beyond Bluetooth with 868 MHz LoRa® on KNOT Gateway LR8 or 915 MHz Wi-Fi HaLow on KNOT Gateway HL9 – two sub-GHz options for IoT deployments that need to reach even further.
Three ways back to your servers
Use Gigabit Ethernet, 2.4 GHz Wi-Fi, or LTE Cat 1 bis for backhaul. Put the gateway where your devices are, without depending on Ethernet being available there.
RouterOS does the rest
Filter data locally, build your own logic with scripts, publish information using MQTT or HTTP, and integrate it into your preferred IoT platform with custom dashboards, notifications, and reports.
Build where it makes sense
IP66 protection, PoE-in, 12–57 V DC input, surge protection, and integrated antennas for BLE, Wi-Fi, LTE, Sub-GHz, and GNSS let you place KNOT closer to the devices it’s actually serving. External antenna connectors for BLE and Sub-GHz give you extra flexibility when the installation calls for it.
And eSIM/MikroTik connectivity gives you even more flexibility – no need for an existing internet connection. You can active data via a simple MikroTik account login!
MikroTik Connectivity offers preloaded eSIM profiles all over the world, multi-operator switching, and reliable remote management with multi-network access for roaming and backup purposes.
KNOT Gateway LR8
Product image
Product image
Product image
Product image thumbnail
Specification
Specifications
  • Product code L14G-2ax-BT5-LR8&EG800K
  • Suggested price $139.00
  • Architecture ARM 64bit
  • CPU IPQ-5010
  • CPU core count 2
  • CPU nominal frequency 800 MHz
  • CPU Threads count 2
  • RouterOS license 4
  • Operating System RouterOS v7
  • Size of RAM 256 MB
  • Storage size 128 MB
  • Storage type NAND
  • Tested ambient temperature -40°C to 50°C
Powering
  • Number of DC inputs 2 (PoE-IN, 2-pin terminal)
  • 2-pin terminal input Voltage 12-57 V
  • Max power consumption 9 W
  • PoE in 802.3af/at
  • Cooling type Passive
  • PoE in input Voltage 18-57 V
Mobile
  • LTE Category CAT 1 bis (DL: 10Mbps; UL: 5Mbps)
  • MIMO DL 1x1
  • MIMO UL 1x1
  • LTE FDD bands 1 (2100MHz)
    3 (1800MHz)
    5 (850MHz)
    7 (2600MHz)
    8 (900 MHz)
    20 (800MHz)
    28 (700MHz)
  • TAC 86684606
Wireless specifications
  • Wireless 2.4 GHz Max data rate 287 Mbit/s
  • Wireless 2.4 GHz Number of chains 1
  • Wireless 2.4 GHz standards 802.11b/g/n/ax
  • Antenna gain dBi for 2.4 GHz 3.9
  • Wireless 2.4 GHz chip model IPQ-5010
  • Wireless 2.4 GHz generation Wi-Fi 6
Ethernet
  • 10/100/1000 Ethernet ports 1
Peripherals
  • Number of SIM slots 1 Modem (Nano SIM)
Other
  • CPU temperature monitor Yes
  • Bluetooth version 5.1
  • Bluetooth RF connector type uUFL
  • eSIM Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP 66
Included parts
Note
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.2 download files for arm64 devices.
System Package
Default Packages
More in download page
