Skip to main content
hAP ax²
A Generation 6 version of the legendary hAP ac². With PoE-in and PoE-out, much faster wireless, more RAM, and a modern CPU. The smallest fully-fledged AX router on the market!
ARM64
Quad-core CPU
PoE
ROS v7
WiFi 6
Dual-band
hAP ax²
Product image
Product image
Product image thumbnail
It’s time to supercharge your home network with the Generation 6 wireless network and our latest addition to the beloved hAP series. hAP ax² has everything you might need in a primary home access point – and more! Forget endless reviews and comparisons – this is the perfect device for 99% of homes.
Wireless signal is now stronger than ever. Here are the two main ingredients of hAP ax’s success: a state-of-the-art dual-band, dual-chain 4-4.5 dBi radio, and the 802.11ax standard with Wave2 support. Let’s compare it to the previous generation: depending on your overall setup, that means up to 40% higher speed in the 5 GHz and up to 90% higher speed in the 2.4 GHz spectrum!
Some might ask – why do we even need higher wireless speeds? Well, countless use cases have been previously impossible or difficult to pull off. For example, working with large media files over the wireless network – without the need to download and upload everything. Do you really have the time to wait? Grab a hAP ax² and save more time for the essential things in life!
The modern quad-core CPU running at 864 MHz combined with a solid GB of RAM packs a hefty punch when it comes to heavy operations like complex firewall rules, IPsec hardware encryption, using more threads or experimenting with the most advanced RouterOS features. And with the addition of WPA3 advanced encryption support, you’re safer than ever before.
Like the previous models, hAP ax² can be mounted vertically, horizontally, or even on the wall – without sacrificing the strong signal.
With so many products and features on the market, even an experienced user can become confused. So it’s time for a simple truth for a simple choice: you can’t go wrong with a hAP ax² in most homes.
Video thumbnail
Specification
Specifications
  • Product code C52iG-5HaxD2HaxD-TC
  • Suggested price $99.00
  • Architecture ARM 64bit
  • CPU IPQ-6010
  • CPU core count 4
  • CPU nominal frequency 864 MHz
  • CPU Threads count 4
  • Switch chip model IPQ-6010
  • RouterOS license 4
  • Operating System RouterOS v7
  • Size of RAM 1 GB
  • Storage size 128 MB
  • Storage type NAND
  • Tested ambient temperature -40°C to 50°C
Wireless capabilities
  • Wireless 2.4 GHz Max data rate 574 Mbit/s
  • Wireless 2.4 GHz standards 802.11b/g/n/ax
  • Antenna gain dBi for 2.4 GHz 4
  • Wireless 2.4 GHz chip model QCN-5022
  • Wireless 2.4 GHz generation Wi-Fi 6
  • Wireless 5 GHz Max data rate 1200 Mbit/s
  • Wireless 5 GHz Number of chains 2
  • Wireless 5 GHz standards 802.11a/n/ac/ax
  • Antenna gain dBi for 5 GHz 4.5
  • Wireless 5 GHz chip model QCN-5052
  • Wireless 5 GHz generation Wi-Fi 6
  • WiFi speed AX1800
Ethernet
  • 10/100/1000 Ethernet ports 5
  • Number of 1G Ethernet ports with PoE-out 1
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 12-28 V
  • Max power consumption 27 W
  • Max power consumption without attachments 12 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 18-28 V
PoE-out
  • PoE-out ports Ether 1
  • PoE out Passive PoE
  • Low voltage PoE-Out current limit 600 mA
  • Max total out (A) 0.6 A
  • Total output current 0.6
  • Total output power 16.8W
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
  • IP 20
Other
  • CPU temperature monitor Yes
  • Mode button Yes
Included parts
Note
Wireless Specification
Ethernet test results
IPsec test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25 download files for arm64 devices.
System Package
Default Packages
More in download page
