Skip to main content
cAP LTE12 ax
A powerful ceiling access point that offers true Wi-Fi 6 mobility for your pop-up business - now with a CAT12 LTE modem!
ARM64
Quad-core CPU
LTE Cat12
MIMO 4x4
PoE
ROS v7
WiFi 6
Dual-band
cAP LTE12 ax
Product image
Product image
Product image thumbnail
cAP LTE12 ax
When it comes to providing reliable wireless connectivity in busy business environments, you need a solution that is both powerful and discreet. Whether you’re running an open-air pop-up store, a festival food stand, or a cozy coffee shop in the park, you need a device that can withstand the challenges of busy, high-traffic areas. You need cAP LTE12 ax – with its fast, reliable mobile internet and incredible Wi-Fi 6 coverage for you and your clients!
Elevate Your Connectivity:
Literally and Figuratively
In bustling high-traffic spaces, traditional access points can face numerous obstacles - devices get knocked over, misplaced, or even stolen. The cAP offers a simple yet effective solution: mount your access point on the ceiling. Not only does this method physically elevate the device, but it also ensures optimal signal distribution, minimizes interference from obstacles, and reduces the risk of theft. Also, you’ll have fewer cables and devices in your workspace to worry about – it’s a win-win scenario!
More Than Just an Access Point
With a powerful quad-core ARM CPU running at 1.8 GHz, a gigabyte of RAM, and the extremely flexible RouterOS v7 at its core, the cAP LTE12 ax is far more than just a simple access point. It offers a range of advanced features, including:
  • Complex firewall rules
  • IPsec hardware encryption and Wireguard support
  • Advanced routing and multiple VPN tunnels
  • Support for remote work and file-sharing
  • Even some light BGP action!
This makes it an ideal solution for businesses that require secure, high-performance mobile connectivity in challenging environments.
Unstoppable 802.11ax (Wi-Fi 6) Radio and Improved Security
With Wi-Fi 6, you can utilize the full potential of the speedy CAT12 600 Mbps LTE modem. We’re looking at up to 40% higher speed in the 5 GHz spectrum and up to 90% higher speed in the 2.4 GHz spectrum compared to previous generations. Additionally, Wi-Fi 6 offers significantly improved energy efficiency and security with OWE/WPA3-PSK/WPA3-EAP encryption and management frame protection. These features help prevent attacks like brute-forcing and deauthentication.
If you have multiple access points over a larger area, you’ll enjoy the improved seamless fast transition roaming – your devices will switch to the strongest signal... seamlessly!
PoE and Effortless Management
The cAP ax makes your office network installation and maintenance easier with PoE-in and PoE-out. That’s right – you can use cAP ax to power other devices, such as network switches, CCTV cameras, or even another cAP ax! And, speaking of easy office networks... Just a few clicks in our latest wifi-qcom CAPsMAN central management system - and you’re done setting up hundreds of cAP ax devices! You can use all sorts of MikroTik devices to run CAPsMAN effortlessly, for example - your main gateway.
Video thumbnail
Specification
Specifications
  • Product code cAPGi-5HaxD2HaxD&EG12-EA
  • Suggested price $229.00
  • Architecture ARM 64bit
  • CPU IPQ-6010
  • CPU core count 4
  • CPU nominal frequency auto (864 - 1800) MHz
  • CPU Threads count 4
  • Switch chip model IPQ-6010
  • RouterOS license 4
  • Operating System RouterOS v7
  • Size of RAM 1 GB
  • Storage size 128 MB
  • Storage type NAND
  • Tested ambient temperature -40°C to 50°C
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 18-57 V
  • Max power consumption 34 W
  • Max power consumption without attachments 13 W
  • PoE in 802.3af/at
  • Cooling type Passive
  • PoE in input Voltage 18-57 V
PoE-out
  • PoE-out ports Ether2
  • PoE out Passive PoE up to 57V
  • Low voltage PoE-Out current limit 0.6 A
  • High voltage PoE-Out current limit 0.4 A
  • Max total out (A) 0.6 A
  • Total output current 0.6
  • Total output power 22.8
Mobile
  • 3G Category R8 (42.2Mbps Downlink, 11.2Mbps Uplink)
  • 3G bands 1 (2100MHz)
    3 (1800MHz)
    5 (850MHz)
    8 (900MHz)
  • LTE Category 12 (600Mbps Downlink, 150Mbps Uplink)
  • MIMO DL 4x4
  • MIMO UL 1x1
  • LTE FDD bands 1 (2100MHz)
    3 (1800MHz)
    5 (850MHz)
    7 (2600MHz)
    8 (900 MHz)
    20 (800MHz)
    28 (700MHz)
  • LTE TDD bands 38 (2600MHz)
    40 (2300MHz)
    41 (2500MHz)
  • TAC 86056104
Wireless specifications
  • Wireless 2.4 GHz Max data rate 574 Mbit/s
  • Wireless 2.4 GHz standards 802.11b/g/n/ax
  • Antenna gain dBi for 2.4 GHz 6
  • Wireless 2.4 GHz chip model QCN-5022
  • Wireless 2.4 GHz generation Wi-Fi 6
  • Wireless 5 GHz Max data rate 1200 Mbit/s
  • Wireless 5 GHz Number of chains 2
  • Wireless 5 GHz standards 802.11a/n/ac/ax
  • Antenna gain dBi for 5 GHz 5.5
  • Wireless 5 GHz chip model QCN-5022
  • Wireless 5 GHz generation Wi-Fi 6
Ethernet
  • 10/100/1000 Ethernet ports 2
  • Number of 1G Ethernet ports with PoE-out 1
Peripherals
  • Number of SIM slots 1 Modem (Micro SIM)
Other
  • CPU temperature monitor Yes
  • Mode button Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP 20
Included parts
Note
Ethernet test results
IPsec test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.5 download files for arm64 devices.
System Package
Default Packages
More in download page
