Skip to main content
NetMetal ax
The Mars rover of networking. Our toughest long-range outdoor access point – now with Wi-Fi 6!
ARM
IP 66
Mini PCI-e
Outdoors
PoE
ROS v7
SFP/SFP+
WiFi 6
Dual-band
Gigabit ethernet with passive PoE Input
2.5 Gigabit SFP for fiber connectivity
USB
IP66 water and dust protection
Dual-Core ARM CPU
Nano-SIM slot
MiniPCIe – add your own... LoRa? LTE?
Our latest dual-band, dual-chain Wi-Fi 6 radio
Video thumbnail
Meet one of your most versatile companions: the NetMetal ax – a powerful long-range outdoor access point that thrives in any environment. Designed for extra durability, it can be installed almost anywhere with ease – you can open and close the case with one hand. The rated IP66 protection will keep the device safe from dust and powerful water jets - in damp attics and elevator shafts, bustling docks, or coastal tower structures. No terrain is too rough for the NetMetal ax – the Mars rover of networking!
Background image
Background image
It features a modern dual-core ARM CPU, Gigabit Ethernet and 2.5 Gigabit SFP for fiber connectivity, a USB port, and a free miniPCIe slot that allows further customization. You could, for example, add an LTE modem for a mobile internet backup – we’ve added a NanoSIM slot on the NetMetal! But there are other options, like adding a gateway for LoRa IoT setups, such as our R11e-LR8!
Background image
A powerful dual-band, dual-chain Wi-Fi 6 radio offers increased speed, stability, security, roaming, power management, and other features, compared to the previous wireless protocols. Two RP-SMA female connectors allow adding an antenna of your choice for distances up to 30 kilometers.*. If necessary, you can adapt the NetMetal ax for lower range use with such antennas as our HGO-antenna-OUT screw-on omni antenna unit. It provides 3.3 dBi gain for the 2.4 GHz band and 5.5-7.1 dBi gain for the 5 GHz band. If you’ve read this far, here’s a little bonus feature: we’ve kept the good old beeper for various alarms or creative outputs.
*It’s important to note that while longer links are feasible, their reliability may vary. Additionally, the distance achievable greatly depends on the antenna selected for use.
NetMetal ax
Product image
Product image
Product image
Product image
Product image
Product image thumbnail
Specification
Specifications
  • Product code L23UGSR-5HaxD2HaxD-NM
  • Suggested price $169.00
  • Architecture ARM 32bit
  • CPU IPQ-5010
  • CPU core count 2
  • CPU nominal frequency 800 MHz
  • CPU Threads count 2
  • RouterOS license 4
  • Operating System RouterOS v7
  • Size of RAM 256 MB
  • Storage size 128 MB
  • Storage type NAND
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 12-28 V
  • Max power consumption 25 W
  • Max power consumption without attachments 12 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 18-28 V
Wireless specifications
  • Wireless 2.4 GHz Max data rate 574 Mbit/s
  • Wireless 2.4 GHz standards 802.11b/g/n/ax
  • Wireless 2.4 GHz chip model IPQ-5010
  • Wireless 2.4 GHz generation Wi-Fi 6
  • Wireless 5 GHz Max data rate 2400 Mbit/s
  • Wireless 5 GHz Number of chains 2
  • Wireless 5 GHz standards 802.11a/n/ac/ax
  • Wireless 5 GHz chip model QCN-6102
  • Wireless 5 GHz generation Wi-Fi 6
Ethernet
  • 10/100/1000 Ethernet ports 1
Fiber
  • SFP ports 1 (2.5G supported)
Peripherals
  • Number of SIM slots 1 Modem (Nano SIM)
  • MiniPCI-e slots 1
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB type A
  • Max USB current (A) 1.5
Other
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Beeper Yes
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
  • IP 66
Included parts
Note
Wireless Specification
Ethernet test results
Download
Latest RouterOS stable release v7.24.5 download files for arm devices.
System Package
Default Packages
More in download page
