Skip to main content
QMP-LHG
Advanced wall mount adapter for LHG
QMP-LHG
Product image
Product image thumbnail
The quickMOUNT pro LHG is a advanced wall or pole mount adapter for our new LHG antennas.
The quickMOUNT pro gives possibility to turn antenna within 140° both in horizontal and vertical plane. With the quickMOUNT pro
it is possible to perfectly set antenna alignment using integrated graduated scale. Compatible with any LHG product except the XL
Specification
Specification
  • Product code QMP-LHG
  • Suggested price $9.50
Documents
Brochure
.PDF
Brochure PDF first page
