Skip to main content
Discontinued
LHG 2
Dual chain 18dBi 2.4GHz CPE/Point-to-Point Integrated Antenna, 600Mhz CPU, 64MB RAM
Outdoors
PoE
LHG 2
Product image
Product image
Product image
Product image thumbnail
The Light Head Grid (LHG) is a compact and light 2.4 GHz 802.11b/g/n wireless device with an integrated dual polarization 18 dBi grid antenna at a revolutionary price. It is perfect for point to point links or for use as a CPE at longer distances and supports Nv2 TDMA protocol.
The grid design ensures protection against wind, and the fact that the antenna element is built into the wireless unit means no loss on cables.
Specification
Specifications
  • Product code RBLHG-2nD
  • Suggested price $58.00
  • Architecture MIPSBE
  • CPU QCA9533
  • CPU core count 1
  • CPU nominal frequency 650 MHz
  • Dimensions Ø 391 x 222 mm
  • RouterOS license 3
  • Operating System RouterOS
  • Size of RAM 64 MB
  • Storage size 16 MB
  • Storage type FLASH
Powering
  • Number of DC inputs 1 (PoE-IN)
  • Max power consumption 5 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 10-30 V
Wireless specifications
  • Wireless 2.4 GHz Max data rate 300 Mbit/s
  • Wireless 2.4 GHz standards 802.11b/g/n
  • Antenna gain dBi for 2.4 GHz 18
  • Wireless 2.4 GHz chip model QCA9533
  • Wireless 2.4 GHz generation Wi-Fi 4
Ethernet
  • 10/100 Ethernet ports 1
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
Included parts
Note
Wireless Specification
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.2 download files for mipsbe devices.
System Package
More in download page
