Skip to main content
Discontinued
LHG LTE kit-US
LHG 3G/4G/LTE High gain 17dBI CPE for very remote areas, US bands
LTE Cat4
Mini PCI-e
Outdoors
PoE
LHG LTE kit-US
Product image
Product image
Product image
Product image
Product image thumbnail
The LHG LTE kit is a device for remote locations that are within cellular network coverage. Mount it outdoors, on a pole, mast or any high enough structure, and connect even where cell phones can’t. Due to it’s large sized high gain antenna, the device is capable to connect to cell towers in extreme rural locations, giving you the ability to provide last mile internet access where nothing else is available.
The unit is equipped with one Ethernet port, has a built in high quality Category 4 modem for speeds of up to 150 Mbit/s downlink and 50 Mbit/s uplink.
RBLHGR&R11e-LTE-US includes LTE modem that supports LTE bands 2, 4, 5 and 12, mostly used by mobile operators in United States, Canada and Latin America.
Specification
Specifications
  • Product code RBLHGR&R11e-LTE-US
  • Suggested price $159.00
  • Architecture MIPSBE
  • CPU QCA9531
  • CPU core count 1
  • CPU nominal frequency 650 MHz
  • Dimensions 391 x 391 x 227 mm
  • RouterOS license 3
  • Operating System RouterOS
  • Size of RAM 64 MB
  • Storage size 16 MB
  • Storage type FLASH
  • Tested ambient temperature -40°C to 60°C
Powering
  • Number of DC inputs 1 (PoE-IN)
  • Max power consumption 6 W
  • PoE in 802.3af/at
  • Cooling type Passive
  • PoE in input Voltage 12-57 V
Mobile
  • 3G Category R7 (21Mbps Downlinks, 5.76Mbps Uplink) / R8 (42.2Mbps Downlink, 5.76Mbps Uplink)
  • 3G bands 2 (1900MHz)
    5 (850MHz)
  • LTE Category 4 (150Mbps Downlink, 50Mbps Uplink)
  • LTE FDD bands 2 (1900MHz)
    4 (1700MHz)
    5 (850MHz)
    12 (700MHz)
  • TAC 35550909
Ethernet
  • 10/100 Ethernet ports 1
Peripherals
  • Number of SIM slots 1 Modem (Micro SIM)
  • MiniPCI-e slots 1
Other
  • Mode button Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
Included parts
Note
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.5 download files for mipsbe devices.
System Package
More in download page
