Skip to main content
Discontinued
LHG 4G kit
LHG 4G/LTE High gain 21dBi CPE for very remote areas, LTE modem for bands 3, 7, 20, 31, 41n, 42 and 43
IP 54
LTE Cat4
Mini PCI-e
Outdoors
PoE
LHG 4G kit
Product image
Product image
Product image
Product image
Product image thumbnail
The LHG 4G kit is a device for remote locations that are within cellular network coverage. Mount it outdoors, on a pole, mast or any high enough structure, and connect even where cell phones can’t. Due to it’s large sized high gain 21dBi antenna, the device is capable to connect to cell towers in extreme rural locations, giving you the ability to provide last mile internet access where nothing else is available.
The unit is equipped with one Ethernet port, has a built in high quality Category 4 modem for speeds of up to 150 Mbit/s downlink and 50 Mbit/s uplink.
RBLHGR&R11e-4G includes LTE modem that supports LTE FDD bands 3 (1800MHz), 7 (2600MHz), 20 (800MHz) and 31 (450MHz), as well as LTE TDD bands 41n (2500MHz), 42 (3500MHz) and 43 (3700MHz).
Specification
Specifications
  • Product code RBLHGR&R11e-4G
  • Suggested price $169.00
  • Architecture MIPSBE
  • CPU QCA9531
  • CPU core count 1
  • CPU nominal frequency 650 MHz
  • Dimensions 391 x 391 x 227 mm
  • RouterOS license 3
  • Operating System RouterOS
  • Size of RAM 64 MB
  • Storage size 16 MB
  • Storage type FLASH
  • Tested ambient temperature -40°C to 60°C
Powering
  • Number of DC inputs 1 (PoE-IN)
  • Max power consumption 5 W
  • PoE in 802.3af/at
  • Cooling type Passive
  • PoE in input Voltage 12-57 V
Mobile
  • LTE Category 4 (150Mbps Downlink, 50Mbps Uplink)
  • LTE FDD bands 3 (1800MHz)
    7 (2600MHz)
    20 (800MHz)
    31 (450MHz)
  • LTE TDD bands 41n (2500MHz)
    42 (3500MHz)
    43 (3700MHz)
  • TAC 35914709
Ethernet
  • 10/100 Ethernet ports 1
Peripherals
  • Number of SIM slots 1 Modem (Micro SIM)
  • MiniPCI-e slots 1
Other
  • Mode button Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP IP54
Included parts
Note
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.5 download files for mipsbe devices.
System Package
More in download page
