Skip to main content
Discontinued
LHG HP5
Dual chain High Power 24.5dBi 5GHz CPE/Point-to-Point Integrated Antenna
Outdoors
PoE
LHG HP5
Product image
Product image thumbnail
The LHG is a compact and light 5GHz 802.11 a/n wireless device with an integrated dual polarization 24.5 dBi grid antenna. LHG HP5 comes with two times more output power than our regular LHG 5, and is designed to reach up to 60% longer distances.
The grid design ensures protection against wind, and the fact that the antenna element is built into the wireless unit means no loss on cables.
We have two versions available.
LHG HP5-US (USA) is factory locked for 5170-5250MHz and 5725-5835MHz frequencies. This lock can not be removed.
LHG HP5 (International) supports 5150MHz-5875MHz range (Specific frequency range can be limited by country regulations).
Specification
Specifications
  • Product code RBLHG-5HPnD
  • Suggested price $79.00
  • Architecture MIPSBE
  • CPU AR9344
  • CPU core count 1
  • CPU nominal frequency 600 MHz
  • Dimensions Ø 391 x 222 mm;
  • RouterOS license 3
  • Operating System RouterOS
  • Size of RAM 64 MB
  • Storage size 16 MB
  • Storage type FLASH
Powering
  • Number of DC inputs 1 (PoE-IN)
  • Max power consumption 7 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 10-28 V
Wireless specifications
  • Wireless 5 GHz Max data rate 300 Mbit/s
  • Wireless 5 GHz Number of chains 2
  • Wireless 5 GHz standards 802.11a/n
  • Antenna gain dBi for 5 GHz 24.5
  • Wireless 5 GHz chip model AR9344
  • Wireless 5 GHz generation Wi-Fi 4
Ethernet
  • 10/100 Ethernet ports 1
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
Included parts
Note
Wireless Specification
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.2 download files for mipsbe devices.
System Package
More in download page
