Skip to main content
Discontinued
LHG Lite60
For use as 60GHz CPE in Point -to-Multipoint setups for connections up to 800m with wAP 60G AP, low cost version with 10/100Mbps Ethernet port
IP 54
Outdoors
PoE
LHG Lite60
Product image
Product image thumbnail
The LHG Lite60 is a new model in our 60 GHz lineup. This is a low cost CPE unit for connecting to a 60 GHz AP at longer distances, enabling you to build a cost effective point to multipoint setup in the clean 60 GHz wireless spectrum.
Connect up to eight of these CPE units to a 60 GHz access point, such as our wAP60G AP. For links up to 800 meters, this is the best alternative for wireless connections where 2 and 5 GHz wireless space is crowded and unreliable, at a fraction of the cost. Also, it's possible to make point-to-point link with two LHG Lite60.
Lightweight, compact and very affordable, this is a 60 GHz device like no other before.
Specification
Specifications
  • Product code RBLHG-60ad
  • Suggested price $99.00
  • Architecture MIPSBE
  • CPU QCA9531
  • CPU core count 1
  • CPU nominal frequency 650 MHz
  • Dimensions Ø 391 x 222 mm
  • RouterOS license 3
  • Operating System RouterOS
  • Size of RAM 64 MB
  • Storage size 16 MB
  • Storage type FLASH
  • Tested ambient temperature -40°C to 50°C
Powering
  • Number of DC inputs 1 (PoE-IN)
  • Max power consumption 4 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 12-30 V
Ethernet
  • 10/100 Ethernet ports 1
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
  • IP IP54
Included parts
Note
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.5 download files for mipsbe devices.
System Package
More in download page
