Skip to main content
SolidRack 10
SolidRack 10 is a 19” 10U desktop rack with adjustable angle and additional space for cable management.
SolidRack 10
Product image
Product image thumbnail
Mount it under the table or put it on the table – like we do it in our testing department. You can even attach a multi-plug extension cord to the back of this sturdy and lightweight aluminium rack.
The package includes screws for 10 devices, as well as nuts and screws for mounting the rack itself. While this is not a revolutionary product, we hope it can make the lives of system administrators, engineers, and testers a little bit easier.
Compatible with all MikroTik (and other vendor!) devices that would fit in a standard 19” rack. But there’s more! With the small K-79 accessory kit, you can fit up to four RB5009UG+S+IN routers in a single 1U rackmount space or up to 40 routers in total!
Video thumbnail
Specification
Specifications
  • Product code SR-10U
  • Suggested price $49.00
Documents
Brochure
.PDF
Brochure PDF first page
