Skip to main content
L11UG-5HaxD
Build your own custom outdoor 5 GHz CPE or AP with Wi-Fi 6, dual-core ARM CPU, PoE-in, Gigabit Ethernet and RouterOS v7! MMCX connectors allow creating versatile omnidirectional access points and powerful point-to-point links.
ARM
PoE
ROS v7
WiFi 6
L11UG-5HaxD
Product image
Product image
Product image
Product image thumbnail
Remember the thrill of crafting your custom solutions with our RouterBoard series? Get ready for even more DIY achievements: we’re refreshing the RB product line with Wi-Fi 6! Like the trusty RB911, our brand new L11UG-5HaxD is going to be your best friend when it comes to building low-cost outdoor CPEs or APs! This tiny board features a modern Qualcomm Maple CPU based on the ARM architecture, 256 MB of RAM, a USB port for extra storage or other needs, and a Gigabit Ethernet port with PoE-in.
The powerful Wi-Fi 6 radio with MMCX connectors enables further customization: add a HGO-antenna-OUT and you’ve got yourself an excellent omnidirectional AP… or try the mANT30 PA antenna to create a powerful long-range point-to-point link!
You can integrate L11UG-5HaxD in a variety of setups, such as vending machines, ATM’s, ticket stations, and more, but for a standalone build you might want to order one of our aluminum cases. The same ones you would use for RB411, 911, 912 and 922, so they are reusable. You can save the planet and your wallet at the same time!
If you’ve read this far, here’s a little bonus feature: we’ve kept the good old beeper for various alarms or creative outputs.
Video thumbnail
Specification
Specifications
  • Product code L11UG-5HaxD
  • Suggested price $79.00
  • Architecture ARM 32bit
  • CPU IPQ-5010
  • CPU core count 2
  • CPU nominal frequency 800 MHz
  • CPU Threads count 2
  • RouterOS license 4
  • Operating System RouterOS v7
  • Size of RAM 256 MB
  • Storage size 128 MB
  • Storage type NAND
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 12-28 V
  • Max power consumption 15 W
  • Max power consumption without attachments 6 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 18-28 V
Wireless specifications
  • Wireless 5 GHz Max data rate 2400 Mbit/s
  • Wireless 5 GHz Number of chains 2
  • Wireless 5 GHz standards 802.11a/n/ac/ax
  • Wireless 5 GHz chip model QCN-6102
  • Wireless 5 GHz generation Wi-Fi 6
Ethernet
  • 10/100/1000 Ethernet ports 1
Peripherals
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB type A
  • Max USB current (A) 1.5
Other
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Beeper Yes
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
  • IP 00
Note
Wireless Specification
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.5 download files for arm devices.
System Package
Default Packages
More in download page
