Skip to main content
Discontinued
SXTsq-mount
A simple, durable alignment attachment for the SXTsq series products.
SXTsq-mount
Product image
Product image
Product image thumbnail
Attach it to the back of the SXTsq using a Ph1 screwdriver, mount everything on a pole using the provided U bolt and an 8 mm ratchet, then place the bolt in one of the three positions - these enable fine adjustments up to 45 degrees in both directions!
Specification
Specifications
  • Product code SXTsq-mount
  • Suggested price $9.00
Documents
Brochure
.PDF
Brochure PDF first page
Related Products
