Skip to main content
Discontinued
SXTsq 5 ac
Low-cost small-size 16dBi 5GHz dual chain integrated CPE/Backbone with AC support and Gigabit Ethernet
ARM
Quad-core CPU
IP 55
Outdoors
PoE
SXTsq 5 ac
Product image
Product image
Product image thumbnail
The SXTsq 5 ac is a compact and lightweight outdoor 5Ghz 802.11ac wireless device with an integrated antenna, perfect for point-to-point links or as a CPE unit. The device includes one 10/100/1000 Mbit Ethernet port to fully utilize speeds that 802.11ac protocol provides.
The SXTsq 5 ac retains a 16 dBi antenna like the SXT 5 ac, our previous model, yet the antenna design has been improved and the physical size has been dramatically reduced - the SXTsq is two times thinner.
- SXTsq 5 ac-US (USA) is factory locked for 5170-5250MHz and 5725-5835MHz frequencies. This lock can not be removed.
- SXTsq 5 ac (International) supports 5150MHz-5875MHz range (Specific frequency range can be limited by country regulations).
Specification
Specifications
  • Product code RBSXTsqG-5acD
  • Suggested price $65.00
  • Architecture ARM 32bit
  • CPU IPQ-4018
  • CPU core count 4
  • CPU nominal frequency 488-896 (auto) MHz
  • CPU Threads count 4
  • Dimensions 129 x 129 x 34 mm
  • RouterOS license 3
  • Operating System RouterOS
  • Size of RAM 256 MB
  • Storage size 16 MB
  • Storage type FLASH
Powering
  • Number of DC inputs 1 (PoE-IN)
  • Max power consumption 7 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 10-28 V
Wireless specifications
  • Wireless 5 GHz Max data rate 867 Mbit/s
  • Wireless 5 GHz Number of chains 2
  • Wireless 5 GHz standards 802.11a/n/ac
  • Antenna gain dBi for 5 GHz 16
  • Wireless 5 GHz chip model IPQ-4018
  • Wireless 5 GHz generation Wi-Fi 5
Ethernet
  • 10/100/1000 Ethernet ports 1
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
  • IP 55
Included parts
Note
Wireless Specification
Ethernet test results
IPsec test results
Download
Latest RouterOS stable release v7.24.5 download files for arm devices.
System Package
Default Packages
More in download page
Related Products
