Skip to main content
CCR2004-1G-2XS-PCIe
A smart PCIe network interface card that adds full-fledged router capabilities to your servers. The smart and easy way to create 25 Gigabit networks if you want to save space in your server room!
ARM64
Quad-core CPU
ROS v7
CCR2004-1G-2XS-PCIe
Product image
Product image
Product image
Product image
Product image
Product image
Product image
Product image thumbnail
Save space in your server room by adding a real CCR2004.. within the server itself! This unique product combines a simple 2x 25 Gigabit PCIe Ethernet adapter with the impressive capabilities of a fully-fledged router.
By default, the PCIe interface will show up as four virtual Ethernet interfaces. Two interfaces in passthrough mode to the 25G SFP28 cages. Remaining two virtual Ethernet-PCIe interfaces are bridged with the Gigabit Ethernet port for management access. The user can configure all interfaces and settings freely since we are running fully functional RouterOS here.
To get this CCR device to work as an NIC, a new Passthrough mode was implemented. Basically, a FastForward FastPath mode that can also pass hardware link statuses.
This NIC can reach wire-speed (100Gbps) with Jumbo frames. It ensures that in most server setups this CCR network card will not be the bottleneck.
With 4 GB of RAM, 128 MB of NAND storage, and a powerful quad-core ARMv8 64-bit CPU, this device can handle a lot: firewalls, user management and access control for home media and file servers, and even some traffic control in data centers – without the need for a stand-alone router.
This form-factor does come with certain limitations that you should keep in mind. The CCR NIC card needs some time to boot up compared to ASIC-based setups. If the host system is up before the CCR card, it will not appear among the available devices. You should add a PCIe device initialization delay after power-up in the BIOS. Or you will need to re-initialize the PCIe devices from the HOST system.
We are looking forward to see your unique use-cases for this unconventional device: a simple high-speed networking card combined with a powerful Cloud Core Router.
Unleash the potential of your server with the fierce power of RouterOS!
*The device is supported on Linux (minimum kernel 5.15.25) and RouterOS (minimum version 7.x) hosts
Video thumbnail
Specification
Specifications
  • Product code CCR2004-1G-2XS-PCIe
  • Suggested price $199.00
  • Architecture ARM 64bit
  • CPU AL52400
  • CPU core count 4
  • CPU nominal frequency 1500 MHz
  • CPU Threads count 4
  • Dimensions 170 x 69 x 18 mm
  • RouterOS license 6
  • Operating System RouterOS v7
  • Size of RAM 4 GB
  • Storage size 128 MB
  • Storage type NAND
  • Tested ambient temperature -20°C to 60°C
Powering
  • Max power consumption 29 W
  • Max power consumption without attachments 22 W
  • Cooling type 1 fan
Ethernet
  • 10/100/1000 Ethernet ports 1
Fiber
  • Number of 25G SFP28 ports 2
Other
  • CPU temperature monitor Yes
  • Current Monitor Yes
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP 20
Included parts
Note
Ethernet test results
IPsec test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.5 download files for arm64 devices.
System Package
More in download page
Related Products
