Skip to main content
Discontinued
hAP ax lite LTE6
Our most affordable LTE home access point - tiny, fast, and strong enough to harvest the power of RouterOS v7!
ARM
LTE Cat6
ROS v7
WiFi 6
hAP ax lite LTE6
Product image
Product image
Product image
Product image thumbnail
Our hAP lite devices have always been about value. The new hAP ax lite LTE6 is no exception – the addition of a built-in LTE modem allows you to cut costs instead of corners like never before!
There are four Gigabit Ethernet ports. Combined with a speedy dual-core ARM CPU and 256 MB of RAM, you’ve got a solid SOHO router. With mobile connectivity. But the value train doesn’t stop here. As a bonus, we’ve added 2.4 GHz Wi-Fi 6 (802.11ax) wireless and a strong 4.3 dBi dual-chain antenna. It might not be the main feature here, but don’t underestimate it: our latest wireless chips allow you to squeeze the traditional 2.4 GHz wireless spectrum like a lemon! Depending on your overall setup, you can expect an increase in speed of up to 90%!
The freedom of LTE
Cable networks can no longer limit you. Mobile internet is there for you – wherever you choose to go. And it will never slow you down! You can reach consistent speeds of up to 300 Mbps with carrier aggregation, as the built-in CAT6 modem allows devices to use multiple bands simultaneously. That is a huge advantage in areas with many LTE users. hAP ax lite LTE6 provides better responsiveness in a crowded environment and higher efficiency for weaker signal situations in the countryside. Depending on the service provider, we have seen Internet speed doubling in rural areas after switching to carrier aggregation!
We offer significant project discounts and custom branding options on volume orders. The best price on the market becomes even better!
And don’t let the price fool you. hAP ax lite LTE6 is the real deal. It comes with all the extensive features of RouterOS 7. Our team takes pride in giving you the freedom to push our devices to the limit. Secure VPN tunneling, bandwidth shaping, firewall, user access control – you make the rules here. It’s your life. Your network. And your opportunity to start saving money like never before!
Video thumbnail
Specification
Specifications
  • Product code L41G-2axD&FG621-EA
  • Suggested price $99.00
  • Architecture ARM 32bit
  • CPU IPQ-5010
  • CPU core count 2
  • CPU nominal frequency 800 MHz
  • CPU Threads count 2
  • Switch chip model MT7531BE
  • RouterOS license 4
  • Operating System RouterOS v7
  • Size of RAM 256 MB
  • Storage size 128 MB
  • Storage type NAND
  • Tested ambient temperature 0°C to 60°C
Wireless capabilities
  • Wireless 2.4 GHz Max data rate 574 Mbit/s
  • Wireless 2.4 GHz standards 802.11b/g/n/ax
  • Antenna gain dBi for 2.4 GHz 4.3
  • Wireless 2.4 GHz chip model IPQ-5010
  • Wireless 2.4 GHz generation Wi-Fi 6
  • WiFi speed AX600
Mobile
  • 3G Category R8 (42.2Mbps Downlink, 11.2Mbps Uplink)
  • 3G bands 1 (2100MHz)
    3 (1800MHz)
    5 (850MHz)
    8 (900MHz)
  • LTE Category 6 (300Mbit/s Downlink, 50Mbit/s Uplink)
  • LTE FDD bands 1 (2100MHz)
    3 (1800MHz)
    5 (850MHz)
    7 (2600MHz)
    8 (900 MHz)
    20 (800MHz)
    28 (700MHz)
  • LTE TDD bands 38 (2600MHz)
    40 (2300MHz)
    41 (2500MHz)
  • TAC 86335904
Ethernet
  • 10/100/1000 Ethernet ports 4
Peripherals
  • Number of SIM slots 1 Modem (Micro SIM)
Powering
  • Number of DC inputs 1 (USB-C) (USB-C)
  • Supported Voltage 5 V
  • Max power consumption 12 W
  • Max power consumption without attachments 12 W
  • Cooling type Passive
  • USB C input Voltage 5 V
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP 20
Other
  • Mode button Yes
Included parts
Note
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.1 download files for arm devices.
System Package
Default Packages
More in download page
