Skip to main content
CME Gateway
A rugged low-cost, low-bandwidth modem to connect Ethernet devices to CAT-M mobile network... on the tightest budget ever!
GPS
IP 66
Outdoors
PoE
ROS v7
CME Gateway
Product image
Product image
Product image
Product image thumbnail
Are you tired of wired sensor limitations? Wouldn’t it be nice if legacy devices - like electricity meters - could send their data over the mobile network, like our phones do? With CME Gateway you can achieve just that – and more!
It has two Ethernet ports, an on-board CPU, some RAM, and the crown jewel: a powerful built-in CAT-M narrow-band LTE modem. For extremely efficient, low-cost, low-bandwidth mobile internet connectivity. Sure, the narrowband won’t be able to stream YouTube videos, but it serves a different purpose: it offers better network coverage and transmits data via the most affordable data plans in the world.
With the IP66 water resistance rating, the sturdy unit can survive a variety of harsh environments and setups: damp attics, rainy forests, farming equipment and so on. It has PoE-in, PoE-out, and a 2-pin DC terminal for handy powering. And to make management even easier - we’ve added a simple single-chain 2.4 GHz wireless - so you can use the MikroTik smartphone app to configure everything.
Also, a fun bonus: the board supports GPS, so if you know your way around RouterOS scripting, you can try collecting weekly, daily or even hourly location data as well!
Video thumbnail
Specification
Specifications
  • Product code CME22-2n-BG77
  • Suggested price $89.00
  • Architecture MIPSBE
  • CPU QCA9531
  • CPU core count 1
  • CPU nominal frequency 650 MHz
  • Switch chip model QCA9531
  • RouterOS license 4
  • Operating System RouterOS v7
  • Size of RAM 64 MB
  • Storage size 16 MB
  • Storage type FLASH
Powering
  • Number of DC inputs 2 (PoE-IN, 2-pin terminal)
  • 2-pin terminal input Voltage 12-57 V
  • Max power consumption 31 W
  • Max power consumption without attachments 6 W
  • PoE in 802.3af/at
  • PoE in input Voltage 18-57 V
PoE-out
  • PoE-out ports Ether2
  • PoE out Passive PoE up to 57V
  • Low voltage PoE-Out current limit 600 mA
  • High voltage PoE-Out current limit 450 mA
  • Max total out (A) 0.6 A
Wireless specifications
  • Wireless 2.4 GHz Max data rate 150 Mbit/s
  • Wireless 2.4 GHz Number of chains 1
  • Wireless 2.4 GHz standards 802.11b/g/n
  • Antenna gain dBi for 2.4 GHz 2
  • Wireless 2.4 GHz chip model QCA9531
  • Wireless 2.4 GHz generation Wi-Fi 4
Ethernet
  • 10/100 Ethernet ports 2
Peripherals
  • Number of SIM slots 1 Modem (Nano SIM)
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
  • IP 66
Included parts
Note
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.5 download files for mipsbe devices.
System Package
Default Packages
More in download page
