Skip to main content
hAP ax lite
Gen6 wireless on a budget – tiny, fast, and strong enough to harvest the power of RouterOS v7!
ARM
ROS v7
WiFi 6
hAP ax lite
Product image
Product image
Product image
Product image
Product image thumbnail
hAP ax lite is the perfect tiny solution when you’ve got to cut costs but can’t afford to sacrifice performance. Our latest Gen6 AX wireless chip allows you to squeeze the traditional 2.4 GHz wireless spectrum like a lemon! Depending on your overall setup, you can expect an increase in speed of up to 90%!
Very useful in scalable setups like hotels or expanding offices – the appealing price point, compact size, and a strong set of features allows adding more devices without a doubt! And – speaking of hotels – why not pack a hAP ax lite for your vacation? It takes up almost no space in your suitcase and allows you to break free from the restrictive guest networks.
Our hAP lite devices have always been about value. With 256 MB of RAM , a modern ARM CPU running at 800 MHz, 4x Gigabit Ethernet ports , much higher dual-chain antenna gain (up to 4.3 dBi!), and a complete visual redesign, the new hAP ax lite is a real trailblazer of value and affordable networking.
Video thumbnail
Specification
Specifications
  • Product code L41G-2axD
  • Suggested price $59.00
  • Architecture ARM 32bit
  • CPU IPQ-5010
  • CPU core count 2
  • CPU nominal frequency 800 MHz
  • CPU Threads count 2
  • Switch chip model MT7531BE
  • RouterOS license 4
  • Operating System RouterOS v7
  • Size of RAM 256 MB
  • Storage size 128 MB
  • Storage type NAND
Wireless capabilities
  • Wireless 2.4 GHz Max data rate 574 Mbit/s
  • Wireless 2.4 GHz standards 802.11b/g/n/ax
  • Antenna gain dBi for 2.4 GHz 4.3
  • Wireless 2.4 GHz chip model IPQ-5010
  • Wireless 2.4 GHz generation Wi-Fi 6
  • WiFi speed AX600
Ethernet
  • 10/100/1000 Ethernet ports 4
Powering
  • Number of DC inputs 1 (USB-C) (USB-C)
  • Supported Voltage 5 V
  • Max power consumption 8 W
  • Cooling type Passive
  • USB C input Voltage 5 V
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
  • IP 20
Other
  • Mode button Yes
Included parts
Note
Wireless Specification
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.1 download files for arm devices.
System Package
Default Packages
More in download page
