Skip to main content
MTP250-26V94-OD
Outdoor 26V 250W AC/DC power supply units for the MikroTik netPower product line. Built for situations when your outdoor switches need that extra juice. Pole/wall mount compatible!
IP 67
MTP250-26V94-OD
Product image
Product image
Product image thumbnail
While the MTP250-53V47-OD (see related products) can output 53V 250W, the MTP250-26V94-OD works with a 26V 250W output. Both power supplies come in a sturdy IP67 enclosure with extra protection from dust and moisture.
The voltage will depend on your setup – take a look at the “DC jack input Voltage” in the Power input specifications of the desired devices. In our example the home access points are designed for 12-30 V power supplies, so we are using the MTP250-26V94-OD. If you have a setup demanding higher voltage – like a net of PTZ security cameras, you could use the MTP250-53V47-OD instead. Always check the necessary voltage before powering your devices!
Specification
Specifications
  • Product code MTP250-26V94-OD
  • Suggested price $99.00
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP IP67
Documents
Brochure
.PDF
Brochure PDF first page
