MikroTik is bringing you new, powerful products for LoRa® for the fraction of the cost you would expect.
R11e-LR8 is a new concentrator Gateway card for LoRa® technology in mini PCIe form factor based on Semtech SX1301 chipset. It enables LoRa® connectivity for any MikroTik product that has mPCIe slot with connected USB lines.
With the support of 8 different channels, Listen Before Talk (LBT) and spectral scan features this product will astound you with its enticing price point.
Operates in 863-870 MHz frequency (used in European Union, Russia, India etc.)
Send purchase questionsDetails | |
Product code | R11e-LR8 |
MTBF | Approximately 100'000 hours at 25C |
Tested ambient temperature | -40°C to 70°C |
Suggested price | $89.00 |
Details | |
Max power consumption | 2 W |
Details | |
Certification | CE, ROHS |
Download: Full CE declaration (PDF)
Information about R11e-LR8
[BG] Bulgarian | С настоящето, "Mikrotikls SIA", декларира, че R11e-LR8 е в съответствие със съществените изисквания и другитеприложими разпоредби на Директива 2014/53/EC. |
[CZ] Czech | "Mikrotikls SIA" tímto prohlašuje, že R11e-LR8 splňuje základní požadavky a všechna příslušná ustanoveni Směrnice 2014/53/ES. |
[DK] Danish | Undertegnede "Mikrotikls SIA" erklærer herved, at følgende udstyr R11e-LR8 overholder de væsentlige krav og øvrige relevante krav i direktiv 2014/53/EF. |
[DE] German | Hiermit erklärt "Mikrotikls SIA", dass sich das Gerät R11e-LR8 in Übereinstimmung mit den grundlegenden Anforderungen und den übrigen einschlägigen Bestimmungen der Richtlinie 2014/53/EG befindet. |
[EE] Estonian | Käesolevaga kinnitab "Mikrotikls SIA" seadme R11e-LR8 vastavust direktiivi 2014/53/EÜ põhinõuetele ja nimetatud direktiivist tulenevatele teistele asjakohastele sätetele. |
[GR] Greek | ΜΕ ΤΗΝ ΠΑΡΟΥΣΑ Ο ΚΑΤΑΣΚΕΥΑΣΤΗΣ "Mikrotikls SIA" ΔΗΛΩΝΕΙ ΟΤΙ R11e-LR8 ΣΥΜΜΟΡΦΩΝΕΤΑΙ ΠΡΟΣ ΤΙΣ ΟΥΣΙΩΔΕΙΣ ΑΠΑΙΤΗΣΕΙΣ ΚΑΙ ΤΙΣ ΛΟΙΠΕΣ ΣΧΕΤΙΚΕΣ ΔΙΑΤΑΞΕΙΣ ΤΗΣ ΟΔΗΓΙΑΣ 2014/53/ΕΚ |
[EN] English | Hereby, "Mikrotikls SIA", declares that this R11e-LR8 is in compliance with the essential requirements and other relevant provisions of Directive 2014/53/EC. |
[ES] Spanish | Por la presente, "Mikrotikls SIA", declara que este R11e-LR8 cumple con los requisitos esenciales y otras exigencias relevantes de la Directiva 2014/53/EC. |
[IT] Italian | Con la presente "Mikrotikls SIA" dichiara che questo R11e-LR8 è conforme ai requisiti essenziali ed alle altre disposizioni pertinenti stabilite dalla direttiva 2014/53/CE. |
[LV] Latvian | Ar šo "Mikrotikls SIA" deklarē, ka R11e-LR8 atbilst Direktīvas 2014/53/EK būtiskajām prasībām un citiem ar to saistītajiem noteikumiem. |
[LT] Lithuanian | Šiuo "Mikrotikls SIA" deklaruoja, kad šis R11e-LR8 atitinka esminius reikalavimus ir kitas 2014/53/EB Direktyvos nuostatas |
[HU] Hungarian | A "Mikrotikls SIA" ezzennel kijelenti, hogy a R11e-LR8 típusú beren-dezés teljesíti az alapvető követelményeket és más 2014/53/EK irányelvben meghatározott vonatkozó rendelkezéseket. |
[NL] Dutch | Hierbij verklaart "Mikrotikls SIA" dat het toestel l R11e-LR8 in overeenstemming is met de essentiële eisen en de andere relevante bepalin-gen van richtlijn 2014/53/EG. |
[PL] Polish | Niniejszym "Mikrotikls SIA" deklaruje że R11e-LR8 jest zgodny z zasadniczymi wymaganiami i innymi właściwymi postanowieniami Dyrektywy 2014/53/EC. |
[PT] Portuguese | Eu, "Mikrotikls SIA", declaro que o R11e-LR8 cumpre os requisitos essenciais e outras provisões relevantes da Directiva 2014/53/EC. |
[RO] Romanian | Prin prezenta, "Mikrotikls SIA", declară că aparatul R11e-LR8 este în conformitate cu cerinţele esenţiale şi cu alte prevederi pertinente ale Directivei 2014/53/CE.. |
[SK] Slovak | "Mikrotikls SIA" týmto vyhlasuje, že R11e-LR8 spĺňa základné požiadavky a všetky príslušné ustanovenia Smernice 2014/53/ES. |
[SI] Slovenian | "Mikrotikls SIA" izjavlja, da je ta R11e-LR8 v skladu z bistvenimi zahtevami in drugimi relevantnimi določili direktive 2014/53/ES. |
[FI] Finish | "Mikrotikls SIA" vakuuttaa täten että R11e-LR8 tyyppinen laite on direktiivin 2014/53/EY oleellisten vaatimusten ja sitä koskevien direktiivin muiden ehtojen mukainen. |
[SE] Swedish | Denna utrustning är i överensstämmelse med de väsentliga kraven och andra relevanta bestämmelser i direktiv 2014/53/EC. |
[NO] Norwegian | "Mikrotikls SIA", Erklærer herved at R11e-LR8 er i samsvar med de grunnleggende krav og øvrige relevante krav i direktiv 2014/53/EF. |
