Skip to main content
CRS418-8P-8G-2S+5axQ2axQ-RM
The Wi-Fi version of CRS418... with our strongest 4x4 MIMO Wi-Fi 6! L3 HW offloading, quad-core 2.2 GHz ARM CPU, 16x Gigabit Ethernet ports + a Gigabit management port with a direct CPU line, 2x 10G SFP+ ports, PoE-out.
4x4 MIMO
L3 HW Offloading
Mighty Quad-core 2.2 GHz ARM CPU
Dual-redundant power supplies
1 GB RAM
USB 3
Dual-band Wi-Fi 6
PoE Ouput
2x 10G SFP+ ports
More than a switch!
Why settle for just a simple switch when you can have PoE Output, high-speed fiber uplinks, USB storage compatibility, advanced network control/monitoring, and enough processing power even for some routing or L3 HW offloading... in a single 1U device and for the best price on the market?
Background image
Background image
16 x Gbit, 2x 10G SFP+ and more
The CRS418-8P-8G-2S+RM combines 16 Gigabit Ethernet ports (eight of them with PoE Output!), two 10G SFP+ cages, USB 3 connectivity. Also, there’s a Gigabit management port with a direct CPU line.
Background image
Quad-core CPU
Powerful quad-core 2.2 GHz CPU in a clean, durable rackmount enclosure.
This is a serious upgrade for anyone looking to replace a jungle of devices with one smart multitasker – built for real routing workloads, high-bandwidth uplinks, and clean cable management. Whether you’re powering up access points and CCTV cameras, running a fast NAS with a bunch of modern workstations, or managing the routing in your mid-sized office, CRS418 handles it all with ease – and on a budget!
Background image
Why CRS418?
It is perfect for hybrid Layer 2/3 environments – whether you’re segmenting your network with VLANs or routing between them. Here’s why:
Powerful enough to replace most small/medium office routers
Thanks to its 2.2 GHz quad-core ARM CPU, L3 hardware offloading, and RouterOS v7, you can use it as an internet gateway, firewall, and even a CAPsMAN controller.
2x 10G SFP+ cages
Connect to media servers, fast ISP fiber networks, core switches, or high-speed storage.
1U rackmount case with redundant power inputs
Space-saving and secure with dual AC inputs for extra peace of mind.
8x PoE Output ports (802.3af/at and 24V Passive PoE Ouput)
Power your devices directly from the switch with up to 150 W total output
USB 3 for extra storage or configuration tools
Perfect for backups, logs, databases, or pushing large files around your organization.
17 Gigabit Ethernet ports
Organize all your gear with a mix of PoE and standard Gigabit ports in one rack-mountable unit. Having a nice, clean server room is easy – if you have the right tools.
RouterOS v7
Use all the advanced switching and routing features MikroTik is known for. No subscriptions, no paywalls, the only limit is your imagination. VLANs, ACLs, SNMP, advanced monitoring & traffic shaping, and so much more!
It’s a real multi-tasking champion that keeps your network lean and your server room clean.
Wi-Fi where it matters
The all-in-one switch/routing champion also delivers 4×4 MIMO dual-band Wi-Fi 6 – for fast, reliable connectivity wherever you need it. The perfect solution to simplify basement server room setups or medium-sized offices on a tight budget – now you don’t need to carry a separate access point!
We know rackmounts are not famous for great wireless coverage. That’s why the CRS418 Wi-Fi edition includes dedicated holes in the back for pigtails, so you can place antennas outside the case if needed.
Background image
Product image
Product image
Product image
Product image thumbnail
Specification
Specifications
  • Product code CRS418-8P-8G-2S+5axQ2axQ-RM
  • Suggested price $499.00
  • Architecture ARM 64bit
  • CPU IPQ-8072A
  • CPU core count 4
  • CPU nominal frequency 2208 MHz
  • CPU Threads count 4
  • Switch chip model 98DX226S
  • RouterOS license 5
  • Operating System RouterOS v7
  • Size of RAM 1 GB
  • Storage size 128 MB
  • Storage type NAND
  • Tested ambient temperature -20°C to 70°C
Powering
  • Number of AC inputs 2
  • AC input range 100-240
  • Number of PSU slots 2
  • Frequency (Hz) 50-60
  • Max power consumption 227 W
  • Max power consumption without attachments 43 W
  • Cooling type 4 fans
PoE-out
  • PoE-out ports Ether9-Ether16
  • PoE out 802.3af/at
  • Low voltage PoE-Out current limit 1.1 A
  • High voltage PoE-Out current limit 0.56 A
  • Total output power 150
Wireless specifications
  • Wireless 2.4 GHz Max data rate 1148 Mbit/s
  • Wireless 2.4 GHz Number of chains 4
  • Wireless 2.4 GHz standards 802.11b/g/n/ax
  • Antenna gain dBi for 2.4 GHz 5
  • Wireless 2.4 GHz chip model QCN-5024
  • Wireless 2.4 GHz generation Wi-Fi 6
  • Wireless 5 GHz Max data rate 2400 Mbit/s
  • Wireless 5 GHz Number of chains 4
  • Wireless 5 GHz standards 802.11a/n/ac/ax
  • Antenna gain dBi for 5 GHz 6
  • Wireless 5 GHz chip model QCN-5054
  • Wireless 5 GHz generation Wi-Fi 6
Ethernet
  • 10/100/1000 Ethernet ports 17
  • Number of 1G Ethernet ports with PoE-out 8
Fiber
  • SFP+ ports 2
Peripherals
  • Serial console port RJ45
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB 3.0 type A
  • Max USB current (A) 1
Other
  • CPU temperature monitor Yes
  • Current Monitor Yes
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Mode button Yes
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
  • IP 20
Included parts
Note
Switching results
Ethernet test results
IPsec test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.5 download files for arm64 devices.
System Package
Default Packages
More in download page
