Products
Products
    New products
    hAP ax S NEW
    Our most cost-effective Wi-Fi 6 access point yet. Triple-chain 5 GHz radio (up to 900 Mbit/s throughput), dual-band Wi-Fi 6, 5x Gigabit Ethernet ports, and a 2.5G SFP. Powered by a dual-core ARM CPU, with PoE-in/PoE-out flexibility, a standard DC jack, USB, and a sturdy high-end enclosure that can be mounted on the wall.
    Compare
    $79.00
    LHG XL 5 ax NEW
    Long-range outdoor CPEs with modern Wi-Fi 6 performance, rugged design, and unbeatable pricing. Available in two models (24.5 or 27 dBi), they’re ideal for point-to-point links over great distances. This is the XL 27 dBi version.
    Compare
    $119.00
    GPERx6 NEW
    Cut the cable clutter – extend power and fiber together, anywhere – with a single hybrid cable. At the far end, the GPERx6 splits it all neatly: SFP+ for further long-distance uplinks, PoE-out for powering other switches or access points, and DC outputs for IoT gear or specialized devices.
    Compare
    $139.00
    KNOT LR8G kit NEW
    An industrial-grade IoT gateway for smart asset tracking, remote monitoring, and efficient automation – now with enhanced LoRa® reception, concurrent GPS + LTE CAT-M, and a lower price. This is the 868 MHz version.
    Compare
    $179.00
    KNOT LR9G kit NEW
    An industrial-grade IoT gateway for smart asset tracking, remote monitoring, and efficient automation – now with enhanced LoRa® reception, concurrent GPS + LTE CAT-M, and a lower price. This is the 915 MHz version.
    Compare
    $179.00
    LtAP LR8G LTE6 kit NEW
    A rugged all-in-one device (LoRa®, 2.4 GHz Wireless, built-in GPS, fast Cat6 LTE mobile internet) with multiple powering options.
    Compare
    $249.00
    ATL 5G R16 NEW
    Our first outdoor 5G device with built-in eSIM support, powerful directional antennas, and a cutting-edge Release 16 modem – ideal for rural, urban, and IoT deployments. With Gigabit Ethernet, PoE-in, and instant MikroTik connectivity out of the box, it’s the smart, rugged choice for fast and flexible internet anywhere. IP66 certified.
    Compare
    $349.00
    Chateau 5G R17 ax NEW
    Get online instantly – even without a SIM card. The iconic MikroTik 5G home router gets its smartest upgrade yet... full eSIM support!
    Compare
    $349.00
    CRS418-8P-8G-2S+RM NEW
    You wanted a switch that could do more. So we built one that does everything! 16x (+1) Gigabit Ethernet ports (8x with PoE-out), dual 10G uplinks, and a powerful quad-core 2.2 GHz ARM CPU. Powerful enough to replace most small/medium office routers, ~3x faster than a CRS320 or a CRS328… and for a better price!
    Compare
    $449.00
    CRS418-8P-8G-2S+5axQ2axQ-RM NEW
    The Wi-Fi version of CRS418... with our strongest 4x4 MIMO Wi-Fi 6! L3 HW offloading, quad-core 2.2 GHz ARM CPU, 16x Gigabit Ethernet ports + a Gigabit management port with a direct CPU line, 2x 10G SFP+ ports, PoE-out.
    Compare
    $499.00
    CRS812 DDQ NEW
    This switch is your next leap forward – a powerful, efficient, and cost-effective way to bring 50G, 200G, and 400G into your rack. Quad-core 2 GHz ARM CPU, dual-redundant power supplies and 4x hot-swap cooling fans, 2x 10G Ethernet, 8x 50G SFP56, 2x 200G QSFP56, and 2x 400G QSFP56-DD ports.
    Compare
    $1295.00
    Ethernet routers
    hEX lite
    hEX lite
    5x Ethernet, Small plastic case, 850MHz CPU, 64MB RAM, Most affordable MPLS router, RouterOS L4
    Compare
    $39.95
    hEX
    hEX
    5x Gigabit Ethernet, Dual Core 880MHz CPU, 256MB RAM, USB, microSD, RouterOS L4
    Compare
    $59.95
    hEX PoE lite
    hEX PoE lite
    5xEthernet with PoE output for four ports, USB, 650MHz CPU, 64MB RAM, RouterOS L4
    Compare
    $59.95
    hEX refresh
    hEX refresh
    The classic hEX refresh: same price, twice the performance! The staple of affordable routing for every home is back – stronger than ever due to the modern ARM CPU and extra RAM.
    Compare
    $59.95
    hEX S (2025)
    hEX S (2025)
    A compact, affordable wired router featuring a 2.5G SFP port, 5x Gigabit Ethernet, PoE out, USB, and a fast dual-core CPU – ideal for homes, offices, or underfunded labs that need reliable performance.
    Compare
    $69.00
    hEX S
    hEX S
    5x Gigabit Ethernet, SFP, Dual Core 880MHz CPU, 256MB RAM, USB, microSD, RouterOS L4, IPsec hardware encryption support and The Dude server package
    Compare
    $79.00
    hEX PoE
    hEX PoE
    5x Gigabit Ethernet with PoE output for four ports, SFP, USB, 800MHz CPU, 128MB RAM, RouterOS L4
    Compare
    $89.00
    PowerBox Pro
    PowerBox Pro
    Five Gigabit Ethernet Router with 4xPoE-out ports, SFP cage and outdoor enclosure
    Compare
    $109.00
    L009UiGS-RM
    L009UiGS-RM
    L009 is more than just a router. This product line is up to 4 times faster than RB2011, it has a modern ARM CPU with container support, an innovative enclosure that allows mounting up to four routers in a single 1U space, more RAM, PoE, and 2.5G SFP support. This version comes with 1U rackmount accessories.
    Compare
    $119.00
    CCR2004-1G-2XS-PCIe
    CCR2004-1G-2XS-PCIe
    A smart PCIe network interface card that adds full-fledged router capabilities to your servers. The smart and easy way to create 25 Gigabit networks if you want to save space in your server room!
    Compare
    $199.00
    RB4011iGS+RM
    RB4011iGS+RM
    Powerful 10xGigabit port router with a Quad-core 1.4Ghz CPU, 1GB RAM, SFP+ 10Gbps cage and desktop case with rack ears
    Compare
    $219.00
    RB5009UG+S+IN
    RB5009UG+S+IN
    The ultimate heavy-duty home lab router with USB 3.0, 1G and 2.5G Ethernet and a 10G SFP+ cage. You can mount four of these new routers in a single 1U rackmount space! Unprecedented processing power in such a small form factor.
    Compare
    $219.00
    RB5009UPr+S+IN
    RB5009UPr+S+IN
    A new version of our popular heavy-duty RB5009 router with PoE-in and PoE-out on all ports. Perfect for small and medium ISPs. 2.5 Gigabit Ethernet & 10 Gigabit SFP+, numerous powering options.
    Compare
    $299.00
    RB5009UPr+S+OUT
    RB5009UPr+S+OUT
    An outdoor version of our best-selling heavy-duty PoE router. Extensive power redundancy for the best price! 7x Gigabit Ethernet ports, 1x 2.5 Gigabit Ethernet, 10G SFP+, 1GB of RAM, 1GB NAND, modern quad-core CPU, 9 (!) powering options, durable IP66 waterproof enclosure.
    Compare
    $319.00
    RB1100AHx4
    RB1100AHx4
    Powerful 1U rackmount router with 13x Gigabit Ethernet ports
    Compare
    $329.00
    RB1100AHx4 Dude Edition
    Powerful 1U rackmount router with 13x Gigabit Ethernet ports, 60GB M.2 drive for Dude database
    Compare
    $385.00
    CCR2004-16G-2S+
    CCR2004-16G-2S+
    This powerful and affordable router crushes all previous CCR models in single-core performance. 16x Gigabit Ethernet ports, USB, 2x10G SFP+ cages, active cooling and the best single-core performance per watt & best overall performance per watt among all the CCR devices.
    Compare
    $465.00
    CCR2004-16G-2S+PC
    CCR2004-16G-2S+PC
    Up to 300% faster than the previous CCR1009 routers - in a blissful silence! Luxury you deserve for the price you can afford. 16x Gigabit Ethernet ports, 2x10G SFP+ cages.
    Compare
    $465.00
    CCR2004-1G-12S+2XS
    CCR2004-1G-12S+2XS
    The Connectivity Router - your best companion when it comes to SFP, SFP+ and SFP28 management! 1, 10 and 25 Gbps ports in a single device to make your life easier.
    Compare
    $595.00
    CCR2116-12G-4S+
    CCR2116-12G-4S+
    Forget about CPU limitations in 10G setups with this powerful 16-core ARM CPU based CCR. Double the performance of our previous 36- core CCR, 6x faster BGP performance. Includes an M.2 PCIe slot.
    Compare
    $995.00
    ROSE Data server (RDS)
    RDS is a high-performance, all-in-one storage, 100G networking, and container platform designed for enterprise environments. Featuring 20 U.2 NVMe storage slots and a special RouterOS Edition for Storage & Compute (ROSE).
    Compare
    $1950.00
    CCR2216-1G-12XS-2XQ
    CCR2216-1G-12XS-2XQ
    The new MikroTik flagship with the power of a whole fleet. Unleash the power of 100 Gigabit networking with L3 Hardware Offloading! This router can be a handy drop-in upgrade for existing CCR1072 setups.
    Compare
    $2795.00
    Switches
    GPERx6
    GPERx6 NEW
    Compare
    $139.00
    CRS418-8P-8G-2S+RM
    Compare
    $449.00
    Compare
    $499.00
    CRS812 DDQ
    CRS812 DDQ NEW
    Compare
    $1295.00
    RB260GS
    RB260GS
    5x Gigabit Ethernet Smart Switch, SFP cage, plastic case, SwOS
    Compare
    $39.95
    RB260GSP
    RB260GSP
    5x Gigabit PoE out Ethernet Smart Switch, SFP cage, plastic case, SwOS
    Compare
    $55.95
    CRS106-1C-5S
    CRS106-1C-5S
    Smart Switch, 5x SFP cages, 1x Combo port (SFP or Gigabit Ethernet), 400MHz CPU, 128MB RAM, desktop case, RouterOS L5
    Compare
    $59.00
    CSS610-8G-2S+IN
    CSS610-8G-2S+IN
    Eight 1G Ethernet ports and two SFP+ ports for 10G fiber connectivity. Portable, powerful and extremely cost-effective – this switch is an instant classic!
    Compare
    $119.00
    netPower Lite 7R
    netPower Lite 7R
    An outdoor reverse PoE switch with Gigabit Ethernet and 10G SFP+ ports.
    Compare
    $139.00
    CSS318-16G-2S+IN
    CSS318-16G-2S+IN
    With 16 Gigabit Ethernet ports and 2 SFP+ 10G uplink ports, you get all the connectivity you need without unnecessary bulk. Stack two units side by side in a single 1U rack space for even greater flexibility and scalability.
    Compare
    $139.00
    CRS305-1G-4S+IN
    CRS305-1G-4S+IN
    Five-port desktop switch with one Gigabit Ethernet port and four SFP+ 10Gbps ports
    Compare
    $149.00
    CSS326-24G-2S+RM
    CSS326-24G-2S+RM
    SwOS powered 24 port Gigabit Ethernet switch with two SFP+ ports in 1U rackmount case
    Compare
    $159.00
    netPower 15FR
    netPower 15FR
    An outdoor 18 port switch with 15 reverse PoE ports and SFP. Cut costs, not speed – choose GPEN over GPON!
    Compare
    $169.00
    CRS326-24G-2S+IN
    CRS326-24G-2S+IN
    24 Gigabit ports, 2 SFP+ cages and a desktop case – server room power for your home!
    Compare
    $199.00
    CRS310-1G-5S-4S+IN
    CRS310-1G-5S-4S+IN
    10 Gigabit fibre connectivity way over a 100 meters – for small offices or ISPs. Hardware offloaded VLAN-filtering and even some L3 routing on a budget!
    Compare
    $199.00
    CRS304-4XG-IN
    CRS304-4XG-IN
    Compact, powerful, and ready to simplify your 10 Gigabit network setups with 4x10G Ethernet ports ready to use out-of-the-box. No extra modules needed!
    Compare
    $199.00
    CRS326-24G-2S+RM
    CRS326-24G-2S+RM
    24 Gigabit port switch with 2 x SFP+ cages in 1U rackmount case, Dual boot (RouterOS or SwitchOS)
    Compare
    $209.00
    CRS112-8P-4S-IN
    CRS112-8P-4S-IN
    8x Gigabit Ethernet Smart Switch with PoE-out, 4x SFP cages, 400MHz CPU, 128MB RAM, desktop case, RouterOS L5
    Compare
    $209.00
    CRS310-8G+2S+IN
    CRS310-8G+2S+IN
    Take advantage of the blazing fast 2.5/10 Gigabit combo and upgrade your workspace! This switch can utilize the full potential of RouterOS v7: run VLANs, Jumbo frames, link aggregation, ACL rules, and so much more!
    Compare
    $219.00
    CSS610-8P-2S+IN
    CSS610-8P-2S+IN
    Your compact, affordable PoE powerhouse with 8x Gigabit PoE-out ports and 2x 10 Gigabit SFP+ ports.
    Compare
    $229.00
    FiberBox Plus
    FiberBox Plus
    Ultimate value pick for 10 Gigabit outdoor networking. High masts, poles, or towers – your connection will be safe! A powerful budget version of the netFiber 9.
    Compare
    $229.00
    netFiber 9
    netFiber 9
    A remarkable outdoor switch for setting up an optical 10G network that can even perform some light routing. The spiritual successor to the beloved FiberBox. Gigabit Ethernet, SFP/SFP+, PoE.
    Compare
    $249.00
    CRS309-1G-8S+IN
    CRS309-1G-8S+IN
    Desktop switch with one Gigabit Ethernet port and eight SFP+ 10Gbps ports
    Compare
    $269.00
    netPower 16P
    netPower 16P
    An outdoor 18 port switch with 16 Gigabit PoE-out ports and 2 SFP+. Power all your access points anywhere!
    Compare
    $279.00
    CRS328-4C-20S-4S+RM
    CRS328-4C-20S-4S+RM
    Smart Switch, 20 x SFP cages, 4 x SFP+ cages, 4 x Combo ports (Gigabit Ethernet or SFP), 800MHz CPU, 512MB RAM, 1U rackmount case, Dual Power Supplies, RouterOS L5 or SwitchOS (Dual Boot)
    Compare
    $449.00
    CRS328-24P-4S+RM
    CRS328-24P-4S+RM
    24 port Gigabit Ethernet router/switch with four 10Gbps SFP+ ports in 1U rackmount case, Dual Boot and PoE output, 500W
    Compare
    $489.00
    CRS320-8P-8B-4S+RM
    CRS320-8P-8B-4S+RM
    The first MikroTik high-power PoE++ switch – for easy and cost-effective powering of industry standard 802.3af/at/bt devices. Forget about countless power cables – create a cleaner space with PoE++!
    Compare
    $489.00
    CRS317-1G-16S+RM
    CRS317-1G-16S+RM
    Smart Switch, 1 x Gigabit LAN, 16 x SFP+ cages, Dual Core 800MHz CPU, 1GB RAM, 1U rackmount passive cooling case, Dual Power Supplies
    Compare
    $499.00
    CRS326-24S+2Q+RM
    CRS326-24S+2Q+RM
    One of our faster switches for the most demanding setups.
    Compare
    $599.00
    CRS354-48G-4S+2Q+RM
    CRS354-48G-4S+2Q+RM
    Best price and best performance on the market – this 48 port switch will rock any setup, including 40 Gbps devices!
    Compare
    $599.00
    CRS312-4C+8XG-RM
    CRS312-4C+8XG-RM
    Switch of the future: the first MikroTik product with 10G RJ45 Ethernet ports and SFP+
    Compare
    $699.00
    CRS504-4XQ-IN
    CRS504-4XQ-IN
    Your most affordable, compact, energy-efficient doorway to the world of 100 Gigabit networking. This switch is the next step in upgrading existing 10 or 25 Gigabit networks. Multiple powering options, dual hot-swap power supplies.
    Compare
    $799.00
    CRS504-4XQ-OUT
    CRS504-4XQ-OUT
    Affordable, compact, energy-efficient 100 Gbps networking anytime, ANYWHERE! IP66 weatherproof enclosure, 4x 100 Gigabit ports, multiple powering options.
    Compare
    $899.00
    CRS354-48P-4S+2Q+RM
    CRS354-48P-4S+2Q+RM
    The 48 port champion you’ve been waiting for - now with PoE-out!
    Compare
    $999.00
    CRS510-8XS-2XQ-IN
    CRS510-8XS-2XQ-IN
    A versatile 100 Gigabit switch that offers speed, value, and diverse connectivity options. 2x 100 Gigabit QSFP28 ports, 8x 25 Gigabit SFP28 ports, dual hot-swap power supplies.
    Compare
    $999.00
    CRS326-4C+20G+2Q+RM
    CRS326-4C+20G+2Q+RM
    Our top-of-the-line switch with incredible 2.5 Gigabit port density, combo ports, and even a pair of 40 Gbps QSFP+ cages. Enterprise-level gamechanger… for the price of a smartphone!
    Compare
    $999.00
    CRS518-16XS-2XQ-RM
    CRS518-16XS-2XQ-RM
    A 100 Gigabit switch for enterprise networks and data centers. Hot-swappable parts and insane port density with 1.2 Tbps switching capacity!
    Compare
    $1595.00
    CRS520-4XS-16XQ-RM
    CRS520-4XS-16XQ-RM
    An ultra-fast enterprise switch with extra processing power due to the CCR series CPU & the best price per 100 Gigabit port on the market!
    Compare
    $2195.00
    Wireless systems
    LHG XL 5 ax
    LHG XL 5 ax NEW
    Compare
    $119.00
    SXTsq Lite2
    SXTsq Lite2
    Low-cost small-size 10dBi 2.4GHz dual chain integrated CPE/Backbone
    Compare
    $39.00
    SXTsq Lite5
    SXTsq Lite5
    Low-cost small-size 16dBi 5GHz dual chain integrated CPE/Backbone
    Compare
    $46.00
    LDF 5
    LDF 5
    Dual chain 5GHz system for long distance links with satellite offset dish antennas
    Compare
    $49.00
    Groove 52
    Groove 52
    2.4GHz/5GHz Backbone/CPE, N-male connector
    Compare
    $59.00
    SXTsq 5 ac
    SXTsq 5 ac
    Low-cost small-size 16dBi 5GHz dual chain integrated CPE/Backbone with AC support and Gigabit Ethernet
    Compare
    $65.00
    SXTsq 5 ax
    SXTsq 5 ax
    A compact outdoor Wi-Fi 6 CPE with a powerful 16 dBi antenna, AP mode, and multiple mounting options – perfect for masts, poles, or rooftop deployments.
    Compare
    $65.00
    LHG 5
    LHG 5
    Dual chain 24.5dBi 5GHz CPE/Point-to-Point Integrated Antenna, 600Mhz CPU, 64MB RAM
    Compare
    $69.00
    GrooveA 52
    GrooveA 52
    2.4GHz/5GHz AP/Backbone/CPE, N-male connector, includes 2.4GHz/5GHz 6dBi Omni Antenna
    Compare
    $79.00
    BaseBox 5
    BaseBox 5
    5Ghz integrated AP/Backbone/CPE, 2xRP-SMA Female connectors, miniPCI-e slot, Gigabit Ethernet
    Compare
    $89.00
    LHG XL HP5
    LHG XL HP5
    Dual chain eXtra Large High Power 27dBi 5GHz CPE/Point-to-Point Integrated Antenna
    Compare
    $89.00
    GrooveA 52 ac
    GrooveA 52 ac
    2.4GHz/5GHz AP/Backbone/CPE with 802.11ac and Gigabit Ethernet, N-male connector + Omni antenna
    Compare
    $99.00
    mANTBox 2 12s
    mANTBox 2 12s
    2.4GHz 120 degree 12dBi dual polarization sector Integrated antenna with 600Mhz CPU, 64MB RAM, Gigabit Ethernet, PSU and PoE
    Compare
    $99.00
    LHG 5 ax
    LHG 5 ax
    Long-range outdoor CPEs with modern Wi-Fi 6 performance, rugged design, and unbeatable pricing. Available in two models (24.5 or 27 dBi), they’re ideal for point-to-point links over great distances. This is the 24.5 dBi version.
    Compare
    $99.00
    NetBox 5 ax
    NetBox 5 ax
    A Wi-Fi 6 upgrade of the popular NetBox 5. AP/CPE/Point-to-point – it can do it all! PoE-in, DC jack, Gigabit Ethernet, durable outdoor enclosure, modern dual-core ARM CPU, Wi-Fi-6 5GHz wireless.
    Compare
    $109.00
    LHG XL 5 ac
    LHG XL 5 ac
    Dual chain Long Range 27dBi 5GHz CPE/Point-to-Point Integrated Antenna with AC support and Gigabit Ethernet
    Compare
    $117.00
    SXT SA5 ac
    SXT SA5 ac
    802.11ac up to 540Mbit, high output, wide beamwidth sector antenna
    Compare
    $119.00
    Metal 52 ac
    Metal 52 ac
    2.4/5GHz software selectable AP/Backbone/CPE with AC support, high TX power, N-male connector, Omni antenna included
    Compare
    $119.00
    OmniTIK 5 PoE ac
    OmniTIK 5 PoE ac
    7.5dBi Integrated AP, 5GHz Dual chain with 802.11ac support, 5x Gigabit Ethernet ports with PoE-out
    Compare
    $139.00
    NetMetal 5
    NetMetal 5
    Dual chain 5GHz integrated 802.11a/n/ac AP/Backbone/CPE with an additional miniPCI-e slot, 2xRPSMA connectors, Gigabit Ethernet, waterproof metal enclosure
    Compare
    $149.00
    QRT 5
    QRT 5
    5GHz AP/Backbone/CPE, dual-chain, Gigabit Ethernet
    Compare
    $169.00
    NetMetal ax
    NetMetal ax
    The Mars rover of networking. Our toughest long-range outdoor access point – now with Wi-Fi 6!
    Compare
    $169.00
    mANTBox ax 15s
    mANTBox ax 15s
    A drop-in Wi-Fi 6 upgrade for the popular mANTBox dual-band sector antenna base stations. One powerful package for all your outdoor network needs, perfect for camps, stadiums and parks.
    Compare
    $179.00
    Wireless for home and office
    hAP ax S
    hAP ax S NEW
    Compare
    $79.00
    hAP lite
    hAP lite
    Low cost home wireless AP with dual chain 2.4GHz wireless, powered by USB
    Compare
    $24.95
    hAP lite TC
    hAP lite TC
    Small home AP with four ethernet ports and a colorful enclosure.
    Compare
    $24.95
    cAP lite
    cAP lite
    Low-cost dual-chain 2.4GHz AP with wall and ceiling enclosure
    Compare
    $29.00
    mAP lite
    mAP lite
    Tiny size 2.4GHz Dual Chain access point with a 650MHz CPU, 64MB RAM and one Ethernet
    Compare
    $30.00
    mAP
    mAP
    Dual-Chain 2.4GHz micro AP, 650MHz CPU, 64MB RAM, 2xEthernet, PoE out
    Compare
    $45.00
    hAP
    hAP
    2.4GHz AP, Five Ethernet ports, PoE-out on port 5, USB for 3G/4G support
    Compare
    $45.00
    cAP
    cAP
    Ceiling AP, Dual-Chain 2.4GHz, 650MHz CPU, RouterOS L4, 802.3at/af support
    Compare
    $49.95
    hAP ac lite
    hAP ac lite
    Dual-Concurrent 2.4/5GHz AP, 802.11ac, Five Ethernet ports, PoE-out on port 5, USB for 3G/4G support
    Compare
    $59.00
    hAP ac lite TC
    hAP ac lite TC
    Dual-Concurrent 2.4/5GHz AP, 802.11ac, Five Ethernet ports, PoE-out on port 5, USB for 3G/4G support, universal tower case
    Compare
    $59.00
    hAP ax lite
    hAP ax lite
    Gen6 wireless on a budget – tiny, fast, and strong enough to harvest the power of RouterOS v7!
    Compare
    $59.00
    RB951Ui-2HnD
    RB951Ui-2HnD
    2.4GHz AP with five Ethernet ports and PoE output on port 5. It has a 600MHz CPU, 128MB RAM and a USB port.
    Compare
    $59.95
    hAP ac²
    hAP ac²
    Dual-Concurrent 2.4/5GHz AP, 802.11a/b/g/n/ac, Five Gigabit Ethernet ports, USB for 3G/4G support, universal tower case and IPsec hardware encryption support
    Compare
    $79.00
    cAP ac
    cAP ac
    Dual-band 2.4 / 5GHz wireless access point for mounting on a ceiling or wall with two Gigabit Ethernet ports (one with PoE output), 802.11ac support and IPsec hardware encryption support
    Compare
    $85.00
    wAP R
    wAP R
    Small weatherproof wireless access point with LTE antennas and miniPCI-e slot
    Compare
    $89.00
    wAP ax
    wAP ax
    wAP ax brings fast and reliable Wi-Fi 6 to your countryside getaway or any other challenging environments – like a rural gas station or a bus stop.
    Compare
    $89.00
    KNOT
    KNOT
    IoT Gateway for the most versatile and cost-effective setups
    Compare
    $99.00
    cAP XL ac
    cAP XL ac
    The ceiling AP on steroids! Our bestseller cAP is back – juiced up and stronger than ever. Compared to the previous cAP models, the improved high-gain antenna increases the covered area by up to 100%!
    Compare
    $99.00
    hAP ax²
    hAP ax²
    A Generation 6 version of the legendary hAP ac². With PoE-in and PoE-out, much faster wireless, more RAM, and a modern CPU. The smallest fully-fledged AX router on the market!
    Compare
    $99.00
    hAP ax lite LTE6
    hAP ax lite LTE6
    Our most affordable LTE home access point - tiny, fast, and strong enough to harvest the power of RouterOS v7!
    Compare
    $99.00
    hAP ac³
    hAP ac³
    A wireless dual-band router with 5 Gigabit Ethernet ports and external high gain antennas for more coverage.
    Compare
    $109.00
    hAP ac
    hAP ac
    Dual concurrent triple chain 2.4/5GHz AP, 802.11ac/a/n/b/g, Five Gigabit Ethernet ports, PoE-out on port 5, SFP, USB for 3G/4G support or storage
    Compare
    $129.00
    cAP ax
    cAP ax
    The best-selling ceiling access point is back – stronger than ever! A new generation of wireless greatness for your office, hotel, mall, or any other setups in crowded areas. Modern quad-core CPU, 1GB of RAM, 2x Gigabit Ethernet ports, PoE, Gen 6 802.11ax wireless, PSU – included!
    Compare
    $129.00
    L009UiGS-2HaxD-IN
    L009UiGS-2HaxD-IN
    L009 is more than just a router. This product line is up to 4 times faster than RB2011, it has a modern ARM CPU with container support, an innovative enclosure that allows mounting up to four routers in a single 1U space, more RAM, PoE, and 2.5G SFP support. This version comes with 2.4 GHz ax dual-chain wireless.
    Compare
    $129.00
    hAP ax³
    hAP ax³
    Our top-of-the-line AX home access point. With all the processing power and speed your household might ever need. Gen 6 wireless, 2.5 Gigabit Ethernet, PoE, WPA3, and more!
    Compare
    $139.00
    Chateau LTE6
    Chateau LTE6
    Your best friend when it comes to affordable mobile networks. Amazing in the hands of seasoned system administrators. Or in a household with zero IT skills. Chateau can do it all. For mobile operators who want the best for their clients without breaking the bank.
    Compare
    $149.00
    Audience
    Audience
    Tri-band (one 2.4 GHz & two 5 GHz) home access point with meshing technology
    Compare
    $169.00
    Chateau LTE6-US
    Chateau LTE6-US
    US carrier-certified (AT&T, T-Mobile) home access point with LTE6 support for speeds up to 300 Mbps. With 5x Gigabit Ethernet ports, a powerful quad-core CPU, and a refreshingly tasteful design, this device is the right choice for most homes.
    Compare
    $189.00
    Chateau PRO ax
    Chateau PRO ax
    A Wi-Fi 6 home access point for the advanced users – it comes with an exceptionally powerful wireless system and a matching CPU.
    Compare
    $199.00
    RB4011iGS+5HacQ2HnD-IN
    Powerful 10xGigabit port router with a Quad-core 1.4Ghz CPU, 1GB RAM, SFP+ 10Gbps cage, dual band 2.4GHz / 5GHz 4x4 MIMO 802.11a/b/g/n/ac wireless and desktop case
    Compare
    $275.00
    Chateau LTE18 ax
    Chateau LTE18 ax
    The best home AP just got even better. Generation 6 version of the Chateau LTE18. Much faster wireless, improved CPU, and now – with 2.5 Gigabit Ethernet!
    Compare
    $299.00
    LTE/5G products
    ATL 5G R16 NEW
    Compare
    $349.00
    Compare
    $349.00
    wAP R
    Compare
    $89.00
    CME Gateway
    A rugged low-cost, low-bandwidth modem to connect Ethernet devices to CAT-M mobile network... on the tightest budget ever!
    Compare
    $89.00
    LtAP mini
    Small weatherproof wireless access point with LTE antennas, two SIM slots, integrated GPS and miniPCI-e slot
    Compare
    $99.00
    KNOT
    Compare
    $99.00
    hAP ax lite LTE6
    Compare
    $99.00
    wAP LTE kit
    A refresh of the classic weatherproof wAP LTE kit – with a new LTE modem that brings the PRICE DOWN and the performance UP! Disruptive pricing: the best OUTDOOR LTE/WI-FI deal on the market if you’re on a tight budget.
    Compare
    $99.00
    LtAP mini LTE kit
    Tiny, affordable weatherproof access point with a built-in LTE modem and GPS. Add extensive networking and tracking options to your vehicle without breaking the bank! This is a 2024 refresh with added B28 band support.
    Compare
    $99.00
    SXT LTE6 kit
    Affordable mobile internet connectivity in remote areas. Lowest price ever – due to the brand new, cost-effective LTE modem.
    Compare
    $119.00
    Chateau LTE6
    Compare
    $149.00
    SXT LTE6 kit-US
    Affordable connectivity in remote areas. Even if your phone has no reception at all, SXT LTE6 kit can deliver due to its advanced LTE chip design and high-gain antenna. US carrier-certified! (AT&T, T-Mobile)
    Compare
    $169.00
    wAP ac LTE kit
    A refresh of the classic dual-band wAP LTE kit with Gigabit Ethernet – this time with a brand new LTE modem that brings the PRICE DOWN and the performance UP!
    Compare
    $169.00
    LHGG LTE6 kit
    An affordable last-mile-internet solution for the most remote areas. This is a 2024 refresh - with Gigabit Ethernet and the best price to date.
    Compare
    $179.00
    Chateau LTE12 (2025)
    Your best friend when it comes to mobile networks. Amazing in the hands of seasoned system administrators. Or in a household with zero IT skills. Or anything in between. Chateau can do it all. New modem by Quectel: added 4x4 MIMO for more bands: 1 / 3 / 7 / 38 / 40 / 41. 5x Gigabit Ethernet ports, 600 Mbps Cat12 LTE.
    Compare
    $179.00
    Chateau LTE6-US
    Compare
    $189.00
    Chateau LTE6 ax
    A supercharged Chateau LTE6 access point with even faster wireless and an improved CPU. For mobile network users who need that extra speed and responsiveness of Gen6 ax wireless. Perfect for large, busy households or medium-sized offices.
    Compare
    $199.00
    Chateau LTE6 ax
    Compare
    $199.00
    LtAP LTE6 kit
    A compact heavy-duty LTE access point with a built-in GPS. Add extensive networking and tracking options to your vehicle without breaking the bank! 3 MiniSIM slots, multiple powering options, extra miniPCI-e slot, console port.
    Compare
    $199.00
    wAP ac LTE6 kit
    Powerful and versatile dual-band wireless access point with CAT6 LTE support
    Compare
    $209.00
    cAP LTE12 ax
    A powerful ceiling access point that offers true Wi-Fi 6 mobility for your pop-up business - now with a CAT12 LTE modem!
    Compare
    $229.00
    LHG LTE18 kit
    Great distances, even greater speed – with the power of the ultra fast LTE Category 18 modem. Speeds up to one Gbps! Last-mile-internet solution for the most remote areas.
    Compare
    $279.00
    ATL LTE18 kit
    An advanced technology level (ATL) LTE solution with wide range MIMO 4x4 antennas for fast and stable connectivity in rural and urban areas. Make the most of your mobile coverage!
    Compare
    $279.00
    Chateau LTE18 ax
    Compare
    $299.00
    ACSMAUFL
    U.fl - SMA female pigtail
    Compare
    $9.00
    SMASMA
    1m SMA male to SMA male cable
    Compare
    $9.00
    ACGPSA
    Active GPS antenna for LtAP series products
    Compare
    $9.00
    HGO-LTE-W
    A handy IoT combo antenna for both LTE and LoRa® frequencies. Perfect for the MikroTik KNOT LR series!
    Compare
    $9.00
    mANT LTE 5o
    5dBi LTE antenna with 2 x SMA connectors
    Compare
    $19.00
    R11eL-EC200A-EU
    An extra cost-effective upgrade of our previous R11 LTE4 modem. It offers the same speed (up to 150 Mbps) and features as the earlier version, but the price is even lower now! Also, it supports the popular B28 band.
    Compare
    $65.00
    R11eL-FG621-EA
    An extra cost-effective upgrade of our previous R11 LTE6 modem. It offers the same speed (up to 300 Mbps) and features as the earlier version, but the price is even lower. Also, it supports the popular B28 band.
    Compare
    $85.00
    Intercell 10 B38+B39
    Outdoor TDD-LTE dual carriers base station for bands 38 and 39
    Compare
    $3500.00
    IoT products
    R11e-LR8G NEW
    Enables LoRa® connectivity via miniPCIe in various MikroTik setups. Enhanced 868MHz Rx sensitivity for effective long-range communication ensures reliable long-range communication, built-in GPS.
    Compare
    $59.00
    R11e-LR9G NEW
    The R11e-LR9G is a next-generation concentrator card for 915 MHz LoRa® networks, compatible with any MikroTik device that has a miniPCIe slot and USB lines.
    Compare
    $59.00
    KNOT LR8G kit NEW
    Compare
    $179.00
    KNOT LR9G kit NEW
    Compare
    $179.00
    Compare
    $249.00
    CME Gateway
    Compare
    $89.00
    KNOT
    Compare
    $99.00
    wAP LR8G kit
    A compact, weatherproof gateway with 2.4 GHz Wireless, 868MHz LoRa®, and a built-in GPS
    Compare
    $149.00
    wAP LR9G kit
    The wAP LR9G kit is a rugged, out-of-the-box LoRa® 915 MHz gateway built into MikroTik’s proven wAP form factor.
    Compare
    $149.00
    KNOT LR9 kit
    An out-of-the-box 902-928 MHz IoT Gateway solution for LoRa® technology. For ultimate versatility and cost-effectiveness. The first gateway with a CAT-M interface for LoRa®!
    Compare
    $199.00
    TG-BT5-IN
    Indoor Bluetooth tags for the MikroTik KNOT or other IoT asset-tracking/telemetry setups.
    Compare
    $10.00
    TG-BT5-OUT
    An outdoor heavy-duty Bluetooth tag for the MikroTik KNOT or other IoT asset-tracking/telemetry setups. Built-in temperature sensors and accelerometer. Cast in industrial grade molds for maximum protection.
    Compare
    $18.00
    868 Omni antenna
    The upgrade of our antenna kit for LoRa® with a 6.5 dBi Omni antenna for 862-876 MHz, 1m long SMA cable and mechanical holder for quick and easy mast attachment. Smaller size, increased durability, and added IP66 water resistance.
    Compare
    $49.00
    TOF-2400-8V-4 Omni antenna
    A 2.4 GHz 8 dBi Omni Antenna for the wAP LR2 kit. If necessary, this antenna can be used for any 2.4 GHz device.
    Compare
    $49.00
    915 Omni antenna
    A 900 - 928 MHz IoT antenna for your LoRa setups in the U.S., Brazil, Australia, New Zealand, and other regions that prefer a 915 MHz signal over our previous 868 MHz antenna. Comes with a durable 1 m long SMA cable and a solid IP66 water resistance rating.
    Compare
    $49.00
    R11e-LR2
    A new Concentrator Gateway card for LoRa® technology in mini PCIe form – so you can create or customize your own 2.4 GHz IoT projects.
    Compare
    $69.00
    wAP LR2 kit
    Our newest out-of-the-box solution for LoRa® technology. Works with the 2.4 GHz frequency for LoRa®. Doesn’t interfere with the 2.4 GHz WLAN signal!
    Compare
    $149.00
    60 GHz products
    wAP 60G
    60 GHz CPE with Phase array 60° beamforming Integrated antenna, 716 Mhz CPU, 256 MB RAM, PSU and PoE, RouterOS L3
    Compare
    $114.00
    wAP 60G AP
    60 GHz Base Station with Phase array 60° beamforming Integrated antenna, 716 Mhz CPU, 256 MB RAM, PSU and PoE, RouterOS L4
    Compare
    $139.00
    LHG 60G
    For use as 60GHz CPE in Point -to-Multipoint setups for connections up to 800m with a 60GHz Base Stations, with Gigabit Ethernet port for speeds up to 1Gbps
    Compare
    $149.00
    Cube 60Pro ac
    A powerful point-to-point 60 GHz 802.11ay CPE for bridging distances up to 2.4 km.
    Compare
    $149.00
    CubeSA 60Pro ac
    A powerful sector antenna to connect multiple 60 GHz devices. Quick and easy networking for all kinds of pop-up events and distances up to 800m.
    Compare
    $199.00
    Wireless Wire
    1 Gbps full duplex without cables!
    Compare
    $228.00
    Wireless Wire Dish
    2 Gb/s aggregate link up to 1500m without cables!
    Compare
    $298.00
    Wireless Wire nRAY
    The most compact wireless 2 Gb/s aggregate link in the 1500 m range or more! Improved snow-resistant design is perfect for harsh weather environments. Cables can no longer limit you!
    Compare
    $298.00
    Wireless Wire Cube Pro
    A preconfigured kit of two Cube 60Pro ac (802.11ay 60 GHz) devices: the Wireless Wire Cube Pro. Just point the Cubes at one another and power them on! They will form a blazing fast encrypted wireless connection. Pure plug-and-play!
    Compare
    $298.00
    RouterBOARD
    RB911G-5HPnD
    600MHz CPU, 32MB RAM, 1xGigabit Ethernet, onboard 5GHz wireless, RouterOS L3
    Compare
    $55.00
    RBM33G
    Powerful OEM board with three Gigabit LAN and two miniPCIe slots
    Compare
    $59.00
    RB912UAG-5HPnD
    600MHz CPU, 64MB RAM, 1xGigabit Ethernet, onboard 5Ghz wireless, miniPCI-express, USB, SIM slot, RouterOS L4
    Compare
    $79.00
    RB912UAG-2HPnD
    600MHz CPU, 64MB RAM, 1xGigabit Ethernet, onboard 2.4Ghz wireless, miniPCI-express, USB, SIM slot, RouterOS L4
    Compare
    $79.00
    L11UG-5HaxD
    Build your own custom outdoor 5 GHz CPE or AP with Wi-Fi 6, dual-core ARM CPU, PoE-in, Gigabit Ethernet and RouterOS v7! MMCX connectors allow creating versatile omnidirectional access points and powerful point-to-point links.
    Compare
    $79.00
    RB922UAGS-5HPacD
    720Mhz CPU, 128MB RAM, 1xGigabit Ethernet, 1xSFP cage, 1xminiPCI-e, 1xSIM, onboard 802.11ac Two Chain 5Ghz wireless, RouterOS L4
    Compare
    $99.00
    RB450Gx4
    Four core 716MHz CPU, 1GB RAM, 5xGigabit Ethernet, PoE out on port #5, RouterOS L5
    Compare
    $99.00
    L23UGSR-5HaxD2HaxD
    Build your own custom outdoor Wi-Fi 6 access point or CPE! This modular wireless router comes with handy MMCX connectors, allowing you to create versatile omnidirectional access points and powerful point-to-point links.
    Compare
    $99.00
    Enclosures
    CA411-711
    Black aluminium indoor, fits RB411, RB911, RB912 and RB922 series, set of front panels
    Compare
    $15.00
    CA150
    Black aluminium indoor case that fits the RB450 and RB850 series devices
    Compare
    $19.00
    CA433U
    Black aluminium indoor, Fits RB433 series and RBM33G
    Compare
    $20.00
    Interfaces
    R11e-5HnD
    5Ghz miniPCI-express, 802.11a/n dual chain, 2x MMCX
    Compare
    $39.00
    R11e-2HPnD
    2Ghz miniPCI-express, 802.11b/g/n dual chain, 2x MMCX
    Compare
    $39.00
    R11e-2HnD
    2Ghz miniPCI-express, 802.11b/g/n dual chain, 2x u.Fl
    Compare
    $39.00
    R11e-5HacD
    5Ghz miniPCI-express, 802.11ac/a/n dual chain, 2x MMCX
    Compare
    $49.00
    Accessories
    TN19-0250-55 NEW
    Open Frame 250W replacement PSU for the CRS418 series.
    Compare
    $69.00
    G1251-0250WNA NEW
    Replacement 250W hot-swap power supply for the CRS812 DDQ.
    Compare
    $79.00
    SSD-U2-7-1TB NEW
    A 7mm U.2 NVMe 1 TB drive for the RDS2216 (ROSE Data Server). Fully tested and compatible!
    Compare
    $219.00
    GPEN21
    Smart power injector that serves as an advanced software controlled repeater
    Compare
    $40.00
    FTC11XG
    A weatherproof IP55 Fiber-to-Copper converter to transform your 10 Gigabit SFP+ fiber connections into RJ45 10 Gigabit Ethernet. It runs a full version of SwOS Lite and has its own switch-chip!
    Compare
    $139.00
    QM-X
    quickMOUNT-X – additional axis for pole-mounting SXTsq devices
    Compare
    $3.00
    RMK-2x10/19
    The RMK-2x10/19 accessory lets you mount two CSS318-16G-2S+IN switches side-by-side in a single 1U slot of a standard 19-inch rack.
    Compare
    $3.00
    RBPOE
    PoE injector, for 10/100Mbps products
    Compare
    $5.00
    K-65
    Rackmount ears for RB4011 series
    Compare
    $5.00
    nRayAIM-DH1
    An alignment and aiming attachment for the nRAY
    Compare
    $5.00
    QMP-LDF
    An advanced pole/mast mount adapter for our LDF series – for extra ease of use and versatility.
    Compare
    $5.00
    QM
    Basic wall mount adapter for small point to point and sector antennas
    Compare
    $6.00
    GPeR IP67 Case
    IP68 outdoor enclosure for the GPeR.
    Compare
    $7.00
    RB5009/L009 rackmount kit K-79
    Kit for mounting RB5009/L009 devices in 1U rackmounts.
    Compare
    $7.00
    RBGPOE
    PoE injector, for Gigabit LAN products
    Compare
    $8.00
    18POW
    24V 0.8A Power adapter
    Compare
    $9.00
    Flex-guide
    Low loss cable assembly, soldered on both ends, with silver plated copper and less than 0.65dB losses
    Compare
    $9.00
    ACMMCXRPSMA
    MMCX to RPSMA pigtail
    Compare
    $9.00
    ACSMAUFL
    Compare
    $9.00
    SMASMA
    Compare
    $9.00
    DINrail PRO
    DIN rail mounting bracket for LtAP mini series
    Compare
    $9.00
    RMK-2/10
    1U Dual or 10’’ rackmount kit
    Compare
    $9.00
    SXTsq-mount
    A simple, durable alignment attachment for the SXTsq series products.
    Compare
    $9.00
    QMP
    Advanced wall mount adapter for small point to point and sector antennas
    Compare
    $9.50
    QMP-LHG
    Advanced wall mount adapter for LHG
    Compare
    $9.50
    QME
    Advanced wall mount adapter for large point to point and sector antennas
    Compare
    $10.00
    RB4011 wall mount kit
    A simple solution for mounting the RB4011 in public locations to avoid accidental unplugging of cables.
    Compare
    $12.00
    MT48-480095-11DG
    48 V, 0.95 A power supply for long Ethernet cable runs
    Compare
    $12.00
    MT48-570080-11DG
    57 V, 0.8 A power supply for long Ethernet cable runs
    Compare
    $12.00
    SAW30-240-1200GA
    24v 1.2A power supply with straight plug
    Compare
    $12.00
    SAW30-240-1200GR2A
    24v 1.2A power supply with right angle plug
    Compare
    $12.00
    GESP+POE-IN
    GESP+PoE is a passive PoE injector with surge protection. Combine it with the GESP devices for maximum security and peace of mind.
    Compare
    $12.00
    GPEN11
    A power injector that can be mounted on a wall
    Compare
    $14.00
    LHG mount
    Basic pole mount adapter for LHG series, made from metal
    Compare
    $15.00
    24HPOW
    24V 2.5A adapter
    Compare
    $18.00
    48POW
    48V 1.46A 70W power adapter
    Compare
    $18.00
    solidMOUNT
    An advanced pole mount adapter for LHG series products
    Compare
    $29.00
    GESP
    New revision of Gigabit Ethernet Surge Protector in IP67 waterproof enclosure
    Compare
    $29.00
    GPeR
    Gigabit Passive Ethernet Repeater
    Compare
    $29.00
    GB60A-S12
    12V 5A internal power supply for CCR1016 series
    Compare
    $29.00
    APA-1
    Automotive Power Adapter with overvoltage protection and other safety features to protect your LtAP and other devices from aggressive vehicle environments.
    Compare
    $29.00
    RBGPOE-CON-HP
    48 to 24V 10/100/1000Mbps PoE converter 802.3af support, 802.3at PoE plus support
    Compare
    $30.00
    RBFTC11
    Fiber to Copper converter, Outdoor case, 12-57V PoE with 802.3af/at support
    Compare
    $39.00
    48V2A96W
    48 V 2 A 96 W power supply with plug
    Compare
    $39.00
    MT-HotSwapFan
    Be prepared for the unexpected with the backup hot-swappable fans for our newest devices, such as the flagship CCR2216 and CRS518.
    Compare
    $39.00
    PW48V-12V85W
    ±48V Open frame Power supply with 12V 7A output, for CCR since revision r2
    Compare
    $49.00
    SolidRack 10
    SolidRack 10 is a 19” 10U desktop rack with adjustable angle and additional space for cable management.
    Compare
    $49.00
    G1040A-60WF
    Hot-swap power supply: replace the CCR2004, CRS510 or CRS504 power supply without having to turn off or even restart the router. Zero downtime!
    Compare
    $49.00
    CADDY (NVMe drive trays)
    A 10-pack of replacement NVMe drive tray inserts for the ROSE Data server.
    Compare
    $49.00
    UP1302C-12
    12V 10.8A internal power supply for CCR1036 series
    Compare
    $59.00
    GPeRx4
    Effortlessly split a single high-power PoE port into multiple standard PoE connections with the compact and durable GPeRx4. Expand, extend, and power your network with ease!
    Compare
    $59.00
    FTC21
    A weatherproof IP55 Fiber-to-Copper converter with smart management capabilities for your fiber and Ethernet setups.
    Compare
    $59.00
    MTP250-53V47-OD
    Outdoor 53V 250W AC/DC power supply units for the MikroTik netPower product line. Built for situations when your outdoor switches need that extra juice. Pole/wall mount compatible!
    Compare
    $99.00
    MTP250-26V94-OD
    Outdoor 26V 250W AC/DC power supply units for the MikroTik netPower product line. Built for situations when your outdoor switches need that extra juice. Pole/wall mount compatible!
    Compare
    $99.00
    12POW150
    Hot Swap power supply for CCR1072/2216 and CRS518
    Compare
    $100.00
    PW48V-12V150W
    Hot Swap -48V DC telecom power supply for CCR1072, CCR2216 and CRS518. Supported input Voltage -36 .. -57V.
    Compare
    $100.00
    G1483-0600WNB
    Hot-swap 54.5V 10.35A 600W power supply for the CRS320-8P-8B-4S+RM PoE++ switch.
    Compare
    $139.00
    DPS-550AB-36G
    Replacement hot-swap power supply unit for the ROSE Data Server.
    Compare
    $139.00
    G1070
    Open Frame 500W replacement PSU for the CRS328-24P-4S+RM switch.
    Compare
    $199.00
    G1270
    Open Frame 750W replacement PSU for the CRS354-48P-4S+2Q+RM switch.
    Compare
    $259.00
    Antennas
    ACOMNIRPSMA
    2.4Ghz 5dBi Dipole antenna with RPSMA connector
    Compare
    $8.00
    ACGPSA
    Compare
    $9.00
    HGO-antenna-OUT
    Dual-band screw-on outdoor antenna
    Compare
    $9.00
    HGO-LTE-W
    Compare
    $9.00
    mANT LTE 5o
    Compare
    $19.00
    MTA Radome Kit
    Radome Cover Kit for mANT, reduces wind load, increases antenna operational life
    Compare
    $49.00
    868 Omni antenna
    Compare
    $49.00
    Compare
    $49.00
    915 Omni antenna
    Compare
    $49.00
    Sleeve30
    Sleeve30 kit for our mANT30 parabolic antenna to enhance point-to-point link performance
    Compare
    $149.00
    mANT30 PA
    Parabolic dish antenna for 5GHz, 30dBi gain. This model includes precision alignment mount
    Compare
    $219.00
    SFP/QSFP
    DDQ+DA0001 NEW
    A 400-Gigabit QSFP-DD direct attach cable, 1m long. Enables easy direct connectivity between ultra-fast devices like the CRS812!
    Compare
    $79.00
    DDQ+DA0003 NEW
    A 400-Gigabit QSFP-DD direct attach cable, 3m long. Enables easy direct connectivity between ultra-fast devices like the CRS812!
    Compare
    $109.00
    DDQ+85MP01D NEW
    QSFP-DD optical module for reliable 400G fiber connections within ultra-fast setups, like the CRS812!
    Compare
    $159.00
    S-85DLC05D
    SFP (1.25G) module, 550m, Multi Mode
    Compare
    $22.00
    S-31DLC20D
    SFP (1.25G) module, 20KM, Single Mode
    Compare
    $29.00
    S-RJ01
    RJ45 SFP 10/100/1000M copper module
    Compare
    $29.00
    XS+DA0001
    Direct attach cable that supports not only SFP 1G and SFP+ 10G, but also the 25G SFP28 standard!
    Compare
    $29.00
    S-55DLC80D
    SFP 1.25G module for 80km links with Dual LC-connector
    Compare
    $39.00
    XS+DA0003
    Compare
    $39.00
    XQ+DA0001
    A 40/100 Gbps QSFP28 direct attach cable, 1m long. Enables easy direct connectivity between two 100 Gigabit devices. Fairly flexible.
    Compare
    $39.00
    S+AO0005
    SFP+ Active Optics direct attach cable, 5m
    Compare
    $49.00
    S+85DLC03D
    SFP+ (10Gbit), 300m, Multi Mode
    Compare
    $59.00
    XQ+DA0003
    A longer version of our 40/100 Gigabit QSFP28 direct attach cable. This cable is 3 meters long – the perfect length to reach all the necessary spots while keeping your server room neat and tidy.
    Compare
    $59.00
    XQ+CM0000-XS+
    An economic QSFP28 to SFP28 converter that allows the use of SFP28 25G/10G/1G modules in QSFP28 100G/40G ports.
    Compare
    $59.00
    XS+85LC01D
    A cost-effective 1.25G SFP, 10G SFP+ and 25G SFP28 module for the 100 meter range.
    Compare
    $59.00
    S+RJ10
    6-speed RJ-45 module for up to 10 Gbps
    Compare
    $65.00
    S-3553LC20D
    Two SFP (1.25G) module kit, 20Km, single mode
    Compare
    $79.00
    XQ+BC0003-XS+
    A QSFP28 to 4x SFP28 break-out cable. Allows connecting multiple 25 Gigabit devices to your CCR2216/CRS504 devices.
    Compare
    $79.00
    S-4554LC80D
    Pair of SFP 1.25G module for 80km links with Single LC-connectors
    Compare
    $89.00
    XQ+85MP01D
    The MikroTik 40/100 Gigabit product line keeps growing: QSFP28 module for distances up to 100m
    Compare
    $89.00
    XS+31LC10D
    A combined 1.25G SFP, 10G SFP+ and 25G SFP28 module.
    Compare
    $149.00
    XQ+31LC02D
    A QSFP28 module for distances up to 2km in your 100 Gigabit setups. 1271, 1291, 1311, 1331 nm
    Compare
    $229.00
    XS+2733LC15D
    A kit of two 1.25G SFP, 10G SFP+ and 25G SFP28 modules. 15 km, 1270nm + 1330nm.
    Compare
    $349.00
    XQ+31LC10D
    A 100 Gigabit QSFP28 module for impressive distances up to 10 km!
    Compare
    $349.00
