Products
Products
    New products
    cAP XL ac NEW
    The ceiling AP on steroids! Our bestseller cAP is back – juiced up and stronger than ever. Compared to the previous cAP models, the improved high-gain antenna increases the covered area by up to 100%!
    Compare
    $99.00
    KNOT LR8 kit NEW
    An out-of-the-box 863-870 MHz IoT Gateway solution for LoRa® technology. For ultimate versatility and cost-effectiveness. The first gateway with a CAT-M interface for LoRa®!
    Compare
    $199.00
    KNOT LR9 kit NEW
    An out-of-the-box 902-928 MHz IoT Gateway solution for LoRa® technology. For ultimate versatility and cost-effectiveness. The first gateway with a CAT-M interface for LoRa®!
    Compare
    $199.00
    RB5009UG+S+IN NEW
    The ultimate heavy-duty home lab router with USB 3.0, 1G and 2.5G Ethernet and a 10G SFP+ cage. You can mount four of these new routers in a single 1U rackmount space! Unprecedented processing power in such a small form factor.
    Compare
    $219.00
    netFiber 9 NEW
    A remarkable outdoor switch for setting up an optical 10G network that can even perform some light routing. The spiritual successor to the beloved FiberBox. Gigabit Ethernet, SFP/SFP+, PoE.
    Compare
    $249.00
    CCR2004-16G-2S+ NEW
    This powerful and affordable router crushes all previous CCR models in single-core performance. 16x Gigabit Ethernet ports, 2x10G SFP+ cages, active cooling and the best single-core performance per watt & best overall performance per watt among all the CCR devices.
    Compare
    $465.00
    CCR2116-12G-4S+ NEW
    Forget about CPU limitations in 10G setups with this powerful 16-core ARM CPU based CCR. Double the performance of our previous 36- core CCR, 6x faster BGP performance. Includes an M.2 PCIe slot.
    Compare
    $995.00
    Ethernet routers
    RB5009UG+S+IN
    RB5009UG+S+IN NEW
    Compare
    $219.00
    CCR2004-16G-2S+
    CCR2004-16G-2S+ NEW
    Compare
    $465.00
    CCR2116-12G-4S+
    CCR2116-12G-4S+ NEW
    Compare
    $995.00
    hEX lite
    hEX lite
    5x Ethernet, Small plastic case, 850MHz CPU, 64MB RAM, Most affordable MPLS router, RouterOS L4
    Compare
    $39.95
    hEX
    hEX
    5x Gigabit Ethernet, Dual Core 880MHz CPU, 256MB RAM, USB, microSD, RouterOS L4
    Compare
    $59.95
    hEX PoE lite
    hEX PoE lite
    5xEthernet with PoE output for four ports, USB, 650MHz CPU, 64MB RAM, RouterOS L4
    Compare
    $59.95
    PowerBox
    PowerBox
    650MHz CPU, 64MB RAM, 5xEthernet with PoE output for four ports, RouterOS L4, outdoor case, PSU
    Compare
    $69.00
    hEX S
    hEX S
    5x Gigabit Ethernet, SFP, Dual Core 880MHz CPU, 256MB RAM, USB, microSD, RouterOS L4, IPsec hardware encryption support and The Dude server package
    Compare
    $69.00
    hEX PoE
    hEX PoE
    5x Gigabit Ethernet with PoE output for four ports, SFP, USB, 800MHz CPU, 128MB RAM, RouterOS L4
    Compare
    $79.00
    RB2011iL-IN
    RB2011iL-IN
    Desktop metal case, 5xEthernet, 5xGigabit Ethernet, PoE out on port 10, 600MHz CPU, 64MB RAM, RouterOS L4
    Compare
    $99.00
    RB2011iL-RM
    RB2011iL-RM
    1U rackmount, 5xEthernet, 5xGigabit Ethernet, PoE out on port 10, 600MHz CPU, 64MB RAM, RouterOS L4
    Compare
    $99.00
    PowerBox Pro
    PowerBox Pro
    Five Gigabit Ethernet Router with 4xPoE-out ports, SFP cage and outdoor enclosure
    Compare
    $99.00
    RB2011iLS-IN
    RB2011iLS-IN
    Desktop metal case, 5xEthernet, 5xGigabit Ethernet, SFP cage, PoE out on port 10, 600MHz CPU, 64MB RAM, RouterOS L4
    Compare
    $109.00
    RB2011UiAS-IN
    RB2011UiAS-IN
    Desktop metal case, 5xEthernet, 5xGigabit Ethernet, USB, LCD, PoE out on port 10, 600MHz CPU, 128MB RAM, RouterOS L5
    Compare
    $119.00
    RB2011UiAS-RM
    RB2011UiAS-RM
    1U rackmount, 5xEthernet, 5xGigabit Ethernet, USB, LCD, PoE out on port 10, 600MHz CPU, 128MB RAM, RouterOS L5
    Compare
    $119.00
    RB3011UiAS-RM
    RB3011UiAS-RM
    1U rackmount, 10xGigabit Ethernet, SFP, USB 3.0, LCD, PoE out on port 10, 2x1.4GHz CPU, 1GB RAM, RouterOS L5
    Compare
    $179.00
    RB4011iGS+RM
    RB4011iGS+RM
    Powerful 10xGigabit port router with a Quad-core 1.4Ghz CPU, 1GB RAM, SFP+ 10Gbps cage and desktop case with rack ears
    Compare
    $199.00
    RB1100AHx4
    RB1100AHx4
    Powerful 1U rackmount router with 13x Gigabit Ethernet ports
    Compare
    $299.00
    RB1100AHx4 Dude Edition
    Powerful 1U rackmount router with 13x Gigabit Ethernet ports, 60GB M.2 drive for Dude database
    Compare
    $349.00
    CCR1009-7G-1C-PC
    CCR1009-7G-1C-PC
    7x Gigabit Ethernet, 1x Combo port (SFP or Gigabit Ethernet), 9 cores x 1GHz CPU, 1GB RAM, passive cooling case, RouterOS L6
    Compare
    $425.00
    CCR1009-7G-1C-1S+PC
    CCR1009-7G-1C-1S+PC
    7x Gigabit Ethernet, 1x Combo port (SFP or Gigabit Ethernet), 1xSFP+ cage, 9 cores x 1GHz CPU, 2GB RAM, LCD panel, passive cooling desktop enclosure, SmartCard slot, RouterOS L6, PSU
    Compare
    $495.00
    CCR1009-7G-1C-1S+
    CCR1009-7G-1C-1S+
    1U rackmount, 7x Gigabit Ethernet, 1x Combo port (SFP or Gigabit Ethernet), 1xSFP+ cage, 9 cores x 1.2GHz CPU, 2GB RAM, LCD panel, Dual Power supplies, SmartCard slot, RouterOS L6
    Compare
    $495.00
    CCR2004-1G-12S+2XS
    CCR2004-1G-12S+2XS
    The Connectivity Router - your best companion when it comes to SFP, SFP+ and SFP28 management! 1, 10 and 25 Gbps ports in a single device to make your life easier.
    Compare
    $595.00
    CCR1016-12G
    CCR1016-12G
    1U rackmount, 12x Gigabit Ethernet, LCD, 16 cores x 1.2GHz CPU, 2GB RAM, 17.8mpps fastpath, Up to 12Gbit/s throughput, RouterOS L6, Dual PSU
    Compare
    $645.00
    CCR1016-12S-1S+
    CCR1016-12S-1S+
    1U rackmount, 12xSFP cage, 1xSFP+ cage, 16 cores x 1.2GHz CPU, 2GB RAM, LCD panel, Dual Power supplies, RouterOS L6
    Compare
    $745.00
    CCR1036-12G-4S
    CCR1036-12G-4S
    1U rackmount, 12x Gigabit Ethernet, 4xSFP cages, LCD, 36 cores x 1.2GHz CPU, 4GB RAM, 24 mpps fastpath, Up to 16Gbit/s throughput, RouterOS L6, Dual PSU
    Compare
    $995.00
    CCR1036-8G-2S+
    CCR1036-8G-2S+
    1U rackmount, 8x Gigabit Ethernet, 2xSFP+ cages, LCD, 36 cores x 1.2GHz CPU, 4GB RAM, 41.5mpps fastpath, Up to 28Gbit/s throughput, RouterOS L6, Dual PSU
    Compare
    $1095.00
    CCR1036-12G-4S-EM
    CCR1036-12G-4S-EM
    1U rackmount, 12x Gigabit Ethernet, 4xSFP cages, LCD, 36 cores x 1.2GHz CPU, 8GB RAM, 24 mpps fastpath, Up to 16Gbit/s throughput, RouterOS L6, Dual PSU
    Compare
    $1195.00
    CCR1036-8G-2S+EM
    CCR1036-8G-2S+EM
    1U rackmount, 8x Gigabit Ethernet, 2xSFP+ cages, LCD, 36 cores x 1.2GHz CPU, 8GB RAM, 41.5mpps fastpath, Up to 28Gbit/s throughput, RouterOS L6, Dual PSU
    Compare
    $1295.00
    CCR1072-1G-8S+
    CCR1072-1G-8S+
    1U rackmount, 1x Gigabit Ethernet, 8xSFP+ cages, LCD, 72 cores x 1GHz CPU, 16GB RAM, up to 120 million packets per second, 80Gbps throughput, RouterOS L6
    Compare
    $3050.00
    Switches
    netFiber 9
    netFiber 9 NEW
    Compare
    $249.00
    RB260GS
    RB260GS
    5x Gigabit Ethernet Smart Switch, SFP cage, plastic case, SwOS
    Compare
    $39.95
    RB260GSP
    RB260GSP
    5x Gigabit PoE out Ethernet Smart Switch, SFP cage, plastic case, SwOS
    Compare
    $55.95
    CRS106-1C-5S
    CRS106-1C-5S
    Smart Switch, 5x SFP cages, 1x Combo port (SFP or Gigabit Ethernet), 400MHz CPU, 128MB RAM, desktop case, RouterOS L5
    Compare
    $59.00
    CSS610-8G-2S+IN
    CSS610-8G-2S+IN
    Eight 1G Ethernet ports and two SFP+ ports for 10G fiber connectivity. Portable, powerful and extremely cost-effective – this switch is an instant classic!
    Compare
    $99.00
    netPower Lite 7R
    netPower Lite 7R
    An outdoor reverse PoE switch with Gigabit Ethernet and 10G SFP+ ports.
    Compare
    $129.00
    CRS112-8G-4S-IN
    CRS112-8G-4S-IN
    8x Gigabit Ethernet Smart Switch, 4x SFP cages, 400MHz CPU, 128MB RAM, desktop case, RouterOS L5
    Compare
    $139.00
    CRS109-8G-1S-2HnD-IN
    8x Gigabit Smart Switch, 1x SFP cage, LCD, 802.11b/g/n Dual Chain wireless, 600MHz CPU, 128MB RAM, Metal desktop case, RouterOS L5, supports 10-57V, 802.3af/at compliant
    Compare
    $149.00
    CRS305-1G-4S+IN
    CRS305-1G-4S+IN
    Five-port desktop switch with one Gigabit Ethernet port and four SFP+ 10Gbps ports
    Compare
    $149.00
    netPower 15FR
    netPower 15FR
    An outdoor 18 port switch with 15 reverse PoE ports and SFP. Cut costs, not speed – choose GPEN over GPON!
    Compare
    $149.00
    CSS326-24G-2S+RM
    CSS326-24G-2S+RM
    SwOS powered 24 port Gigabit Ethernet switch with two SFP+ ports in 1U rackmount case
    Compare
    $159.00
    CRS112-8P-4S-IN
    CRS112-8P-4S-IN
    8x Gigabit Ethernet Smart Switch with PoE-out, 4x SFP cages, 400MHz CPU, 128MB RAM, desktop case, RouterOS L5
    Compare
    $189.00
    CRS326-24G-2S+IN
    CRS326-24G-2S+IN
    24 Gigabit ports, 2 SFP+ cages and a desktop case – server room power for your home!
    Compare
    $199.00
    CRS125-24G-1S-2HnD-IN
    24x Gigabit Ethernet layer 3 Smart Switch, 1x SFP cage, LCD, 802.11b/g/n Dual Chain wireless, 600MHz CPU, 128MB RAM, Metal desktop case, RouterOS L5
    Compare
    $209.00
    CRS326-24G-2S+RM
    CRS326-24G-2S+RM
    24 Gigabit port switch with 2 x SFP+ cages in 1U rackmount case, Dual boot (RouterOS or SwitchOS)
    Compare
    $209.00
    CRS212-1G-10S-1S+IN
    CRS212-1G-10S-1S+IN
    Smart Switch, 1x Gigabit LAN, 10x SFP cages, 1x SFP+ cage, LCD, 400MHz CPU, 64MB RAM, Metal desktop case, RouterOS L5
    Compare
    $219.00
    CRS309-1G-8S+IN
    CRS309-1G-8S+IN
    Desktop switch with one Gigabit Ethernet port and eight SFP+ 10Gbps ports
    Compare
    $269.00
    netPower 16P
    netPower 16P
    An outdoor 18 port switch with 16 Gigabit PoE-out ports and 2 SFP+. Power all your access points anywhere!
    Compare
    $279.00
    CRS328-4C-20S-4S+RM
    CRS328-4C-20S-4S+RM
    Smart Switch, 20 x SFP cages, 4 x SFP+ cages, 4 x Combo ports (Gigabit Ethernet or SFP), 800MHz CPU, 512MB RAM, 1U rackmount case, Dual Power Supplies, RouterOS L5 or SwitchOS (Dual Boot)
    Compare
    $369.00
    CRS317-1G-16S+RM
    CRS317-1G-16S+RM
    Smart Switch, 1 x Gigabit LAN, 16 x SFP+ cages, Dual Core 800MHz CPU, 1GB RAM, 1U rackmount passive cooling case, Dual Power Supplies
    Compare
    $399.00
    CRS328-24P-4S+RM
    CRS328-24P-4S+RM
    24 port Gigabit Ethernet router/switch with four 10Gbps SFP+ ports in 1U rackmount case, Dual Boot and PoE output, 500W
    Compare
    $445.00
    CRS326-24S+2Q+RM
    CRS326-24S+2Q+RM
    Our fastest switch for the most demanding setups
    Compare
    $499.00
    CRS354-48G-4S+2Q+RM
    CRS354-48G-4S+2Q+RM
    Best price and best performance on the market – this 48 port switch will rock any setup, including 40 Gbps devices!
    Compare
    $499.00
    CRS312-4C+8XG-RM
    CRS312-4C+8XG-RM
    Switch of the future: the first MikroTik product with 10G RJ45 Ethernet ports and SFP+
    Compare
    $599.00
    CRS354-48P-4S+2Q+RM
    CRS354-48P-4S+2Q+RM
    The 48 port champion you’ve been waiting for - now with PoE-out!
    Compare
    $899.00
    CA433U
    CA433U
    Black aluminium indoor, Fits RB433 series and RBM33G
    Compare
    $20.00
    Wireless systems
    LDF 5
    LDF 5
    Dual chain 5GHz system for long distance links with satellite offset dish antennas
    Compare
    $39.00
    SXTsq Lite2
    SXTsq Lite2
    Low-cost small-size 10dBi 2.4GHz dual chain integrated CPE/Backbone
    Compare
    $39.00
    LDF 2
    LDF 2
    Dual chain 2.4GHz system for long distance links with satellite offset dish antennas
    Compare
    $39.00
    SXTsq Lite5
    SXTsq Lite5
    Low-cost small-size 16dBi 5GHz dual chain integrated CPE/Backbone
    Compare
    $46.00
    SXTsq 5 High Power
    SXTsq 5 High Power
    Low-cost High Power small-size 16dBi 5GHz dual chain integrated CPE/Backbone
    Compare
    $49.00
    DISC Lite5
    DISC Lite5
    Dual chain 21dBi 5GHz CPE/Point-to-Point Integrated Antenna, 600Mhz CPU, 64MB RAM
    Compare
    $55.00
    SXTsq 5 ac
    SXTsq 5 ac
    Low-cost small-size 16dBi 5GHz dual chain integrated CPE/Backbone with AC support and Gigabit Ethernet
    Compare
    $55.00
    LHG 2
    LHG 2
    Dual chain 18dBi 2.4GHz CPE/Point-to-Point Integrated Antenna, 600Mhz CPU, 64MB RAM
    Compare
    $58.00
    LDF 5 ac
    LDF 5 ac
    Dual chain 5GHz system with Gigabit Ethernet and 802.11ac support for long distance links with satellite offset dish antennas
    Compare
    $58.00
    Groove 52
    Groove 52
    2.4GHz/5GHz Backbone/CPE, N-male connector
    Compare
    $59.00
    LHG 5
    LHG 5
    Dual chain 24.5dBi 5GHz CPE/Point-to-Point Integrated Antenna, 600Mhz CPU, 64MB RAM
    Compare
    $59.00
    LHG XL 2
    LHG XL 2
    Dual chain 21dBi 2.4GHz CPE/Point-to-Point Integrated Antenna for longer distances
    Compare
    $68.00
    LHG HP5
    LHG HP5
    Dual chain High Power 24.5dBi 5GHz CPE/Point-to-Point Integrated Antenna
    Compare
    $69.00
    DISC Lite5 ac
    DISC Lite5 ac
    Outdoor 5GHz 802.11a/n/ac wireless device with a backfire type 21dBi integrated antenna and Gigabit Ethernet for longer distances
    Compare
    $69.00
    SXT 2
    SXT 2
    10dbi 60 degree integrated AP/Backbone/CPE, dual chain, Gigabit Ethernet
    Compare
    $79.00
    GrooveA 52
    GrooveA 52
    2.4GHz/5GHz AP/Backbone/CPE, N-male connector, includes 2.4GHz/5GHz 6dBi Omni Antenna
    Compare
    $79.00
    LHG XL HP5
    LHG XL HP5
    Dual chain eXtra Large High Power 27dBi 5GHz CPE/Point-to-Point Integrated Antenna
    Compare
    $79.00
    OmniTIK 5
    OmniTIK 5
    7.5dBi Integrated AP, 5GHz Dual chain, 5xEthernet ports
    Compare
    $89.00
    BaseBox 5
    BaseBox 5
    5Ghz integrated AP/Backbone/CPE, 2xRPSMA connectors, miniPCI-e slot, Gigabit Ethernet
    Compare
    $89.00
    BaseBox 2
    BaseBox 2
    2.4Ghz integrated AP/Backbone/CPE, 2xRPSMA connectors, miniPCI-e slot, Gigabit Ethernet
    Compare
    $89.00
    LHG 5 ac
    LHG 5 ac
    Dual chain 24.5dBi 5GHz CPE/Point-to-Point Integrated Antenna with AC support and Gigabit Ethernet
    Compare
    $89.00
    BaseBox 6
    BaseBox 6
    6GHz integrated AP/Backbone/CPE, 2xRPSMA connectors, miniPCI-e slot, Gigabit Ethernet
    Compare
    $89.00
    OmniTIK 5 PoE
    OmniTIK 5 PoE
    7.5dBi Integrated AP, 5GHz Dual chain, 5xEthernet ports with PoE output
    Compare
    $99.00
    SXT SA5
    SXT SA5
    14dBi integrated Sector AP, 90 degrees beamwidth, Gigabit Ethernet
    Compare
    $99.00
    GrooveA 52 ac
    GrooveA 52 ac
    2.4GHz/5GHz AP/Backbone/CPE with 802.11ac and Gigabit Ethernet, N-male connector + Omni antenna
    Compare
    $99.00
    SXT 6
    SXT 6
    Dual chain 16dBi 26 degree 5.9-6.4GHz Integrated antenna for licensed band
    Compare
    $99.00
    LHG XL 5 ac
    LHG XL 5 ac
    Dual chain Long Range 27dBi 5GHz CPE/Point-to-Point Integrated Antenna with AC support and Gigabit Ethernet
    Compare
    $99.00
    mANTBox 2 12s
    mANTBox 2 12s
    2.4GHz 120 degree 12dBi dual polarization sector Integrated antenna with 600Mhz CPU, 64MB RAM, Gigabit Ethernet, PSU and PoE
    Compare
    $99.00
    NetBox 5
    NetBox 5
    802.11ac support for up to 540Mbits, waterproof enclosure, high output
    Compare
    $109.00
    OmniTIK 5 ac
    OmniTIK 5 ac
    7.5dBi Integrated AP, 5GHz Dual chain with 802.11ac support, 5x Gigabit Ethernet ports
    Compare
    $109.00
    SEXTANT G
    SEXTANT G
    18dBi integrated CPE/Backbone, Gigabit Ethernet
    Compare
    $110.00
    SXT SA5 ac
    SXT SA5 ac
    802.11ac up to 540Mbit, high output, wide beamwidth sector antenna
    Compare
    $119.00
    Metal 52 ac
    Metal 52 ac
    2.4/5GHz software selectable AP/Backbone/CPE with AC support, high TX power, N-male connector, Omni antenna included
    Compare
    $119.00
    OmniTIK 5 PoE ac
    OmniTIK 5 PoE ac
    7.5dBi Integrated AP, 5GHz Dual chain with 802.11ac support, 5x Gigabit Ethernet ports with PoE-out
    Compare
    $129.00
    mANTBox 15s
    mANTBox 15s
    5GHz 120 degree 15dBi dual polarization sector Integrated antenna with 720Mhz CPU, 128MB RAM, SFP, PSU and PoE
    Compare
    $139.00
    NetMetal 5
    NetMetal 5
    Dual chain 5GHz integrated 802.11a/n/ac AP/Backbone/CPE with an additional miniPCI-e slot, 2xRPSMA connectors, Gigabit Ethernet, waterproof metal enclosure
    Compare
    $149.00
    NetMetal 5SHP
    NetMetal 5SHP
    Dual chain 5GHz integrated 802.11ac AP/Backbone/CPE, 2xRPSMA connectors, high TX power, Gigabit Ethernet, waterproof metal enclosure
    Compare
    $159.00
    NetMetal 5 triple
    NetMetal 5 triple
    Triple chain 5GHz integrated 802.11ac AP/Backbone/CPE with an additional miniPCI-e slot, Gigabit Ethernet, waterproof metal enclosure
    Compare
    $159.00
    mANTBox 52 15s
    mANTBox 52 15s
    A dual-band 2.4/5 GHz base station with a powerful built-in sector antenna, PoE support, Gigabit Ethernet and SFP. One powerful package for all your outdoor network needs, perfect for camps, stadiums and parks!
    Compare
    $159.00
    QRT 5
    QRT 5
    5GHz AP/Backbone/CPE, dual-chain, Gigabit Ethernet
    Compare
    $169.00
    NetMetal 5SHP triple
    Triple chain 5GHz integrated 802.11ac AP/Backbone/CPE, 3xRPSMA connectors, high power, Gigabit Ethernet, waterproof metal enclosure
    Compare
    $169.00
    NetMetal ac²
    NetMetal ac²
    Our toughest long-range AP, now with dual-band support
    Compare
    $169.00
    DynaDish 5
    DynaDish 5
    Dual chain 5GHz 802.11a/n/ac QCA9892, 128MB RAM, 720 MHz CPU, 25dBi antenna gain
    Compare
    $179.00
    DynaDish 6
    DynaDish 6
    Dual chain 25dBi Long Range 5.9-6.4GHz Integrated antenna for licensed band
    Compare
    $179.00
    LHG XL 52 ac
    LHG XL 52 ac
    Extremely powerful dual-band backbone / CPE for long-distance connection without downtime
    Compare
    $189.00
    QRT 5 ac
    QRT 5 ac
    Dual chain 5GHz 802.11a/n/ac QCA9882, 128 MB RAM, 720 MHz CPU, 24 dBi antenna gain
    Compare
    $199.00
    mANTBox 19s
    mANTBox 19s
    5GHz 120 degree 19dBi dual polarization sector Integrated antenna with 720Mhz CPU, 128MB RAM, SFP, PSU and PoE
    Compare
    $199.00
    Wireless for home and office
    cAP XL ac
    cAP XL ac NEW
    Compare
    $99.00
    hAP mini
    hAP mini
    Tiny size home 2.4Ghz AP with three LAN ports
    Compare
    $22.95
    hAP lite
    hAP lite
    Low cost home wireless AP with dual chain 2.4GHz wireless, powered by USB
    Compare
    $24.95
    hAP lite TC
    hAP lite TC
    Small home AP with four ethernet ports and a colorful enclosure.
    Compare
    $24.95
    mAP lite
    mAP lite
    Tiny size 2.4GHz Dual Chain access point with a 650MHz CPU, 64MB RAM and one Ethernet
    Compare
    $25.00
    cAP lite
    cAP lite
    Low-cost dual-chain 2.4GHz AP with wall and ceiling enclosure
    Compare
    $29.00
    mAP
    mAP
    Dual-Chain 2.4GHz micro AP, 650MHz CPU, 64MB RAM, 2xEthernet, PoE out
    Compare
    $45.00
    hAP
    hAP
    2.4GHz AP, Five Ethernet ports, PoE-out on port 5, USB for 3G/4G support
    Compare
    $45.00
    wAP
    wAP
    Small weatherproof wireless access point for mounting on a ceiling, wall or pole
    Compare
    $45.00
    wAP BE
    wAP BE
    Small weatherproof wireless access point for mounting on a ceiling, wall or pole. In black
    Compare
    $45.00
    wsAP ac lite
    wsAP ac lite
    In-wall Dual Concurrent 2.4GHz / 5GHz wireless access point with three Ethernet ports and telephone jack pass through for hospitality networks
    Compare
    $49.00
    cAP
    cAP
    Ceiling AP, Dual-Chain 2.4GHz, 650MHz CPU, RouterOS L4, 802.3at/af support
    Compare
    $49.95
    hAP ac lite
    hAP ac lite
    Dual-Concurrent 2.4/5GHz AP, 802.11ac, Five Ethernet ports, PoE-out on port 5, USB for 3G/4G support
    Compare
    $49.95
    hAP ac lite TC
    hAP ac lite TC
    Dual-Concurrent 2.4/5GHz AP, 802.11ac, Five Ethernet ports, PoE-out on port 5, USB for 3G/4G support, universal tower case
    Compare
    $49.95
    RB951Ui-2HnD
    RB951Ui-2HnD
    2.4GHz AP with five Ethernet ports and PoE output on port 5. It has a 600MHz CPU, 128MB RAM and a USB port.
    Compare
    $59.95
    cAP ac
    cAP ac
    Dual-band 2.4 / 5GHz wireless access point for mounting on a ceiling or wall with two Gigabit Ethernet ports (one with PoE output), 802.11ac support and IPsec hardware encryption support
    Compare
    $69.00
    hAP ac²
    hAP ac²
    Dual-Concurrent 2.4/5GHz AP, 802.11a/b/g/n/ac, Five Gigabit Ethernet ports, USB for 3G/4G support, universal tower case and IPsec hardware encryption support
    Compare
    $69.00
    wAP R
    wAP R
    Small weatherproof wireless access point with LTE antennas and miniPCI-e slot
    Compare
    $79.00
    RB951G-2HnD
    RB951G-2HnD
    2.4Ghz AP, 5xGigabit Ethernet, USB, 600MHz CPU, 128MB RAM
    Compare
    $79.95
    wAP ac
    wAP ac
    wAP ac – a small dual-band weatherproof wireless access point for mounting on a pole, wall, or the ceiling. The new revision features 2x Gigabit Ethernet ports, enhanced wireless antenna performance, more RAM, and a powerful quad-core CPU!
    Compare
    $89.00
    hAP ac³
    hAP ac³
    A wireless dual-band router with 5 Gigabit Ethernet ports and external high gain antennas for more coverage
    Compare
    $99.00
    KNOT
    KNOT
    IoT Gateway for the most versatile and cost-effective setups
    Compare
    $99.00
    RB2011UiAS-2HnD-IN
    RB2011UiAS-2HnD-IN
    2.4GHz AP, 5x Ethernet, 5x Gigabit Ethernet, SFP cage, USB, LCD, PoE output on Eth10, 600MHz CPU, 128MB RAM
    Compare
    $129.00
    hAP ac
    hAP ac
    Dual concurrent triple chain 2.4/5GHz AP, 802.11ac/a/n/b/g, Five Gigabit Ethernet ports, PoE-out on port 5, SFP, USB for 3G/4G support or storage
    Compare
    $129.00
    Audience
    Audience
    Tri-band (one 2.4 GHz & two 5 GHz) home access point with meshing technology
    Compare
    $169.00
    hAP ac³ LTE6 kit
    hAP ac³ LTE6 kit
    A wireless dual-band router with LTE support and 5 Gigabit Ethernet ports. The right choice for most homes!
    Compare
    $219.00
    Chateau LTE12
    Chateau LTE12
    One router to delight them all – introducing the ultimate home AP with LTE support
    Compare
    $229.00
    RB4011iGS+5HacQ2HnD-IN
    Powerful 10xGigabit port router with a Quad-core 1.4Ghz CPU, 1GB RAM, SFP+ 10Gbps cage, dual band 2.4GHz / 5GHz 4x4 MIMO 802.11a/b/g/n/ac wireless and desktop case
    Compare
    $249.00
    Audience LTE6 kit
    Audience LTE6 kit
    Tri-band (one 2.4 GHz & two 5 GHz) home access point with LTE CAT6 support and meshing technology
    Compare
    $279.00
    Chateau 5G
    Chateau 5G
    One router to delight them all – introducing the ultimate home AP with ultra-fast LTE/5G support
    Compare
    $530.00
    wAP ac
    wAP ac
    Compare
    $89.00
    LTE/5G products
    wAP R
    Compare
    $79.00
    SXT R
    10.5dBi 60 degree LTE antenna with 2x Ethernet ports (one with PoE out), WITHOUT LTE modem
    Compare
    $79.00
    LtAP mini
    Small weatherproof wireless access point with LTE antennas, two SIM slots, integrated GPS and miniPCI-e slot
    Compare
    $89.00
    LHG R
    High gain 21dBI LTE antenna for very remote areas, WITHOUT LTE modem
    Compare
    $109.00
    wAP LTE kit
    Small weatherproof wireless access point with International LTE modem
    Compare
    $119.00
    wAP LTE kit US
    Small weatherproof wireless access point with United States LTE modem
    Compare
    $119.00
    LtAP mini LTE kit
    Small weatherproof wireless access point with International LTE modem, two SIM slots and GPS
    Compare
    $129.00
    LtAP mini LTE kit-US
    Small weatherproof wireless access point with United States LTE modem, two SIM slots and GPS
    Compare
    $129.00
    SXT LTE kit
    SXT 2G/3G/4G/LTE CPE, 9dBi 60 degree antenna, 2x Ethernet ports (one with PoE out), two SIM, 650MHz CPU, 64MB RAM, enclosure, PoE and PSU (RouterOS L3), International bands
    Compare
    $129.00
    SXT LTE kit-US
    SXT 3G/4G/LTE CPE, 10.5dBi 60 degree antenna, 2x Ethernet ports (one with PoE out), two SIM, 650MHz CPU, 64MB RAM, enclosure, PoE and PSU (RouterOS L3), US bands
    Compare
    $129.00
    wAP 4G kit
    Small weatherproof wireless access point with LTE modem for bands 3, 7, 20, 31, 41n, 42 and 43
    Compare
    $129.00
    wAP R ac
    Small weatherproof Dual Band 2.4 / 5 GHz wireless access point with LTE antennas and miniPCI-e slot
    Compare
    $129.00
    SXT LTE6 kit
    The evolution of affordable connectivity in remote areas
    Compare
    $149.00
    LDF LTE6 kit
    This outdoor wireless system with a built-in antenna can provide a connection even in the most remote locations. Tiny, powerful, can be used with any satellite TV dish with an offset mount.
    Compare
    $149.00
    LHG LTE kit
    LHG 2G/3G/4G/LTE High gain 17dBI CPE for very remote areas, International bands
    Compare
    $159.00
    LHG LTE kit-US
    LHG 3G/4G/LTE High gain 17dBI CPE for very remote areas, US bands
    Compare
    $159.00
    LHG 4G kit
    LHG 4G/LTE High gain 21dBi CPE for very remote areas, LTE modem for bands 3, 7, 20, 31, 41n, 42 and 43
    Compare
    $169.00
    wAP ac LTE kit
    Small weatherproof Dual Band 2.4 / 5 GHz wireless access point with LTE antennas and modem for International LTE bands 1,2,3,7,8,20,38 and 40.
    Compare
    $169.00
    wAP ac 4G kit
    Small weatherproof Dual Band 2.4 / 5 GHz wireless access point with LTE antennas and modem for International bands 3, 7, 20, 31, 41n, 42 and 43
    Compare
    $169.00
    LHG LTE6 kit
    Great solution for great distances
    Compare
    $179.00
    wAP ac LTE6 kit
    Powerful and versatile dual-band wireless access point with CAT6 LTE support
    Compare
    $189.00
    LtAP
    A heavy-duty 2.4GHz access point with two miniPCI-e slots, three SIM slots and GNSS support (GPS, GLONASS, BeiDou, Galileo)
    Compare
    $199.00
    LHGG LTE6 kit
    LHGG LTE6 KIT – a great solution for great distances. With Gigabit Ethernet, an upgraded dual-core CPU, a powerful 17 dBi antenna, and a massive heat sink, you can trust the LHGG LTE6 kit to handle any challenge!
    Compare
    $199.00
    hAP ac³ LTE6 kit
    Compare
    $219.00
    Chateau LTE12
    Compare
    $229.00
    LtAP LTE kit
    A heavy-duty 2.4GHz access point with extra miniPCI-e slot, three SIM slots, GNSS support (GPS, GLONASS, BeiDou, Galileo) and LTE modem for International bands 1,2,3,7,8,20,38 and 40
    Compare
    $249.00
    LtAP LTE6 kit
    An upgrade of the heavy-duty LTE access point with GPS support
    Compare
    $269.00
    Audience LTE6 kit
    Compare
    $279.00
    LtAP LR8 LTE kit
    LtAP LR8 LTE - a compact all-in-one solution with LTE, GPS and wireless support for LoRa® in a rugged heavy-duty case
    Compare
    $339.00
    Chateau 5G
    Compare
    $530.00
    ACSMAUFL
    U.fl - SMA female pigtail
    Compare
    $9.00
    SMASMA
    1m SMA male to SMA male cable
    Compare
    $9.00
    ACGPSA
    Active GPS antenna for LtAP series products
    Compare
    $9.00
    DINrail PRO
    DIN rail mounting bracket for LtAP mini series
    Compare
    $9.00
    mANT LTE 5o
    5dBi LTE antenna with 2 x SMA connectors
    Compare
    $19.00
    R11e-LTE-US
    LTE miniPCI-e card for United States frequency bands
    Compare
    $69.00
    R11e-LTE
    LTE miniPCI-e card for International bands
    Compare
    $75.00
    R11e-LTE6
    2G/3G/4G/LTE miniPCI-e card with carrier aggregation support (up to 300 Mbps) for bands 1/2/3/5/7/8/12/17/20/25/26/38/39/40/41n
    Compare
    $99.00
    Intercell 10 B38+B39
    Outdoor TDD-LTE dual carriers base station for bands 38 and 39
    Compare
    $3500.00
    Data over Powerlines
    PWR-LINE US
    Power adapter with PWR-LINE functionality for microUSB powered MikroTik router (Type A power plug)
    Compare
    $29.00
    PWR-LINE AP (EU plug)
    802.11b/g/n WiFi AP with a single Ethernet port and capability to connect to other PWR-LINE devices through the electrical lines in your premises (Type C plug, European)
    Compare
    $42.00
    PWR-LINE AP (US plug)
    802.11b/g/n WiFi AP with a single Ethernet port and capability to connect to other PWR-LINE devices through the electrical lines in your premises (Type A plug, US plug)
    Compare
    $42.00
    PWR-LINE EU
    Power adapter with PWR-LINE functionality for microUSB powered MikroTik router (Type C power plug)
    Compare
    $29.00
    PWR-LINE PRO
    Next level product for even faster power-line connection without long LAN cables
    Compare
    $59.00
    IoT products
    TG-BT5-IN NEW
    Indoor Bluetooth tags for the MikroTik KNOT or other IoT asset-tracking/telemetry setups.
    Compare
    $10.00
    TG-BT5-OUT NEW
    An outdoor heavy-duty Bluetooth tag for the MikroTik KNOT or other IoT asset-tracking/telemetry setups. Built-in temperature sensors and accelerometer. Cast in industrial grade molds for maximum protection.
    Compare
    $18.00
    868 Omni antenna NEW
    The upgrade of our antenna kit for LoRa® with a 6.5 dBi Omni antenna for 824-960 MHz, 1m long SMA cable and mechanical holder for quick and easy mast attachment. Smaller size, increased durability, and added IP66 water resistance.
    Compare
    $49.00
    TOF-2400-8V-4 Omni antenna NEW
    A 2.4 GHz 8 dBi Omni Antenna for the wAP LR2 kit. If necessary, this antenna can be used for any 2.4 GHz device.
    Compare
    $49.00
    R11e-LR2 NEW
    A new Concentrator Gateway card for LoRa® technology in mini PCIe form – so you can create or customize your own 2.4 GHz IoT projects.
    Compare
    $69.00
    wAP LR2 kit NEW
    Our newest out-of-the-box solution for LoRa® technology. Works with the 2.4 GHz frequency for LoRa®. Doesn’t interfere with the 2.4 GHz WLAN signal!
    Compare
    $149.00
    KNOT LR8 kit NEW
    Compare
    $199.00
    KNOT LR9 kit NEW
    Compare
    $199.00
    KNOT
    Compare
    $99.00
    wAP LR8 kit
    An out-of-the-box gateway solution for LoRa® technology , 863-870 MHz
    Compare
    $169.00
    wAP LR9 kit
    An out-of-the-box gateway solution for LoRa® technology, 902-928 MHz
    Compare
    $169.00
    LtAP LR8 LTE kit
    Compare
    $339.00
    Antenna kit for LoRa®
    Compare
    $49.00
    R11e-LR8
    Concentrator gateway card for LoRa® technology in mini PCIe form factor for 863-870 MHz
    Compare
    $89.00
    R11e-LR9
    Concentrator gateway card for LoRa® technology in mini PCIe form factor for 902-928 MHz
    Compare
    $89.00
    60 GHz products
    Cube Lite60
    The most affordable 60 GHz CPE for crowded wireless spectrum
    Compare
    $69.00
    wAP 60G
    60 GHz CPE with Phase array 60° beamforming Integrated antenna, 716 Mhz CPU, 256 MB RAM, PSU and PoE, RouterOS L3
    Compare
    $99.00
    Cube 60G ac
    A high-speed 60 GHz CPE with Gigabit Ethernet and a 5 GHz failover. The easy and affordable way of eliminating interference and downtime!
    Compare
    $124.00
    wAP 60G AP
    60 GHz Base Station with Phase array 60° beamforming Integrated antenna, 716 Mhz CPU, 256 MB RAM, PSU and PoE, RouterOS L4
    Compare
    $129.00
    LHG 60G
    For use as 60GHz CPE in Point -to-Multipoint setups for connections up to 800m with a 60GHz Base Stations, with Gigabit Ethernet port for speeds up to 1Gbps
    Compare
    $149.00
    Wireless Wire
    1 Gbps full duplex without cables!
    Compare
    $198.00
    wAP 60Gx3 AP
    60 GHz Base Station with Phase array 180° beamforming Integrated antenna, specially designed for Multipoint connections.
    Compare
    $199.00
    Wireless Wire Dish
    2 Gb/s aggregate link up to 1500m+ without cables!
    Compare
    $298.00
    Wireless Wire nRAY
    The most compact wireless 2 Gb/s aggregate link in the 1500 m range or more! Improved snow-resistant design is perfect for harsh weather environments. Cables can no longer limit you!
    Compare
    $298.00
    Wireless Wire Cube
    A 2 Gb/s 60 GHz aggregate link with a 5 GHz failover. Forget about wires or downtime!
    Compare
    $248.00
    RouterBOARD
    RBM11G
    Small size powerful OEM board with one Gigabit LAN and one miniPCIe slot
    Compare
    $39.00
    911 Lite5 dual
    600Mhz CPU, 64MB RAM, 1xEthernet, onboard 5Ghz Dual chain wireless, RouterOS L3
    Compare
    $45.00
    911 Lite5 ac
    650Mhz CPU, 64MB RAM, 1xEthernet, onboard 5Ghz dual chain wireless with AC, RouterOS L3
    Compare
    $49.00
    RBM33G
    Powerful OEM board with three Gigabit LAN and two miniPCIe slots
    Compare
    $49.00
    RB911G-5HPnD
    600MHz CPU, 32MB RAM, 1xGigabit Ethernet, onboard 5GHz wireless, RouterOS L3
    Compare
    $55.00
    RB912UAG-5HPnD
    600MHz CPU, 64MB RAM, 1xGigabit Ethernet, onboard 5Ghz wireless, miniPCI-express, USB, SIM slot, RouterOS L4
    Compare
    $79.00
    RB912UAG-2HPnD
    600MHz CPU, 64MB RAM, 1xGigabit Ethernet, onboard 2.4Ghz wireless, miniPCI-express, USB, SIM slot, RouterOS L4
    Compare
    $79.00
    RB911G-5HPacD
    720Mhz CPU, 128MB RAM, 1xGigabit Ethernet, onboard 802.11ac Two Chain 5Ghz wireless, RouterOS L3
    Compare
    $79.00
    RB922UAGS-5HPacD
    720Mhz CPU, 128MB RAM, 1xGigabit Ethernet, 1xSFP cage, 1xminiPCI-e, 1xSIM, onboard 802.11ac Two Chain 5Ghz wireless, RouterOS L4
    Compare
    $99.00
    RB450Gx4
    Four core 716MHz CPU, 1GB RAM, 5xGigabit Ethernet, PoE out on port #5, RouterOS L5
    Compare
    $99.00
    Enclosures
    CA411-711
    Black aluminium indoor, fits RB411, RB911, RB912 and RB922 series, set of front panels
    Compare
    $15.00
    CA150
    Black aluminium indoor case that fits the RB450 and RB850 series devices
    Compare
    $19.00
    CA493
    Black aluminium indoor, Fits RB493 series
    Compare
    $20.00
    Interfaces
    XS+2733LC15D NEW
    A kit of two combined 1.25G SFP, 10G SFP+ and 25G SFP28 modules. 15 km, 1270nm + 1330nm.
    Compare
    $349.00
    S-85DLC05D
    SFP (1.25G) module, 550m, Multi Mode
    Compare
    $22.00
    S-31DLC20D
    SFP (1.25G) module, 20KM, Single Mode
    Compare
    $29.00
    S-RJ01
    RJ45 SFP 10/100/1000M copper module
    Compare
    $29.00
    Q+DA0001
    40 Gbps direct attach QSFP+ cable
    Compare
    $29.00
    XS+DA0001
    Direct attach cable that supports not only SFP 1G and SFP+ 10G, but also the 25G SFP28 standard!
    Compare
    $29.00
    S-C47DLC40D
    SFP CWDM module 1.25G 40km 1470nm
    Compare
    $34.00
    S-C51DLC40D
    SFP CWDM module 1.25G 40km 1510nm
    Compare
    $34.00
    S-C53DLC40D
    SFP CWDM module 1.25G 40km 1530nm
    Compare
    $34.00
    S-C55DLC40D
    SFP CWDM module 1.25G 40km 1550nm
    Compare
    $34.00
    S-C57DLC40D
    SFP CWDM module 1.25G 40km 1570nm
    Compare
    $34.00
    S-C59DLC40D
    SFP CWDM module 1.25G 40km 1590nm
    Compare
    $34.00
    S-C61DLC40D
    SFP CWDM module 1.25G 40km 1610nm
    Compare
    $34.00
    R11e-5HnD
    5Ghz miniPCI-express, 802.11a/n dual chain, 2x MMCX
    Compare
    $39.00
    R11e-2HPnD
    2Ghz miniPCI-express, 802.11b/g/n dual chain, 2x MMCX
    Compare
    $39.00
    R11e-2HnD
    2Ghz miniPCI-express, 802.11b/g/n dual chain, 2x u.Fl
    Compare
    $39.00
    S-55DLC80D
    SFP 1.25G module for 80km links with Dual LC-connector
    Compare
    $39.00
    XS+DA0003
    Compare
    $39.00
    R11e-5HacD
    5Ghz miniPCI-express, 802.11ac/a/n dual chain, 2x MMCX
    Compare
    $49.00
    S+AO0005
    SFP+ Active Optics direct attach cable, 5m
    Compare
    $49.00
    R5SHPn
    5Ghz miniPCI 802.11a/n single chain, MMCX connector
    Compare
    $59.00
    S+85DLC03D
    SFP+ (10Gbit), 300m, Multi Mode
    Compare
    $59.00
    R11e-5HacT
    5Ghz miniPCI-e, 802.11ac/a/n tripple chain, 3x MMCX
    Compare
    $59.00
    R52HnD
    2.4/5Ghz miniPCI 802.11a/b/g/n dual chain, 2x MMCX
    Compare
    $59.00
    Q+85MP01D
    40 Gbps 850nm optical QSFP+ module
    Compare
    $59.00
    Q+BC0003-S+
    40 Gbps QSFP+ break-out cable to 4x10G SFP+
    Compare
    $59.00
    S+RJ10
    6-speed RJ-45 module for up to 10 Gbps
    Compare
    $65.00
    S-3553LC20D
    Two SFP (1.25G) module kit, 20Km, single mode
    Compare
    $79.00
    S-4554LC80D
    Pair of SFP 1.25G module for 80km links with Single LC-connectors
    Compare
    $89.00
    S+C47DLC10D
    SFP+ CWDM module 10G 10km 1470nm
    Compare
    $129.00
    S+C49DLC10D
    SFP+ CWDM module 10G 10km 1490nm
    Compare
    $129.00
    S+C51DLC10D
    SFP+ CWDM module 10G 10km 1510nm
    Compare
    $129.00
    S+C53DLC10D
    SFP+ CWDM module 10G 10km 1530nm
    Compare
    $129.00
    S+C55DLC10D
    SFP+ CWDM module 10G 10km 1550nm
    Compare
    $129.00
    S+C57DLC10D
    SFP+ CWDM module 10G 10km 1570nm
    Compare
    $129.00
    S+C59DLC10D
    SFP+ CWDM module 10G 10km 1590nm
    Compare
    $129.00
    S+C61DLC10D
    SFP+ CWDM module 10G 10km 1610nm
    Compare
    $129.00
    XS+31LC10D
    A combined 1.25G SFP, 10G SFP+ and 25G SFP28 module.
    Compare
    $149.00
    CWDM-MUX8A
    A passive MUX/DEMUX unit that allows the combining of up to eight fiber links into one. And you can split it up again later! Upgraded version – featuring a handy EXP/1310 expansion port!
    Compare
    $299.00
    Accessories
    RB5009 rackmount kit K-79 NEW
    Kit for mounting RB5009 devices in 1U rackmounts.
    Compare
    $7.00
    HGO-LTE-W NEW
    A handy IoT combo antenna for both LTE and LoRa® frequencies. Perfect for the MikroTik KNOT LR series!
    Compare
    $9.00
    GESP+POE-IN NEW
    GESP+PoE is a passive PoE injector with surge protection. Combine it with the GESP devices for maximum security and peace of mind.
    Compare
    $12.00
    Rack-holder SR-10U NEW
    A 19” 10U desktop rack with adjustable angle and additional space for cable management.
    Compare
    $49.00
    G1040A-60WF NEW
    Hot-swap power supply: replace the CCR2004 power supply without having to turn off or even restart the router. Zero downtime!
    Compare
    $49.00
    MTP250-53V47-OD NEW
    Outdoor 53V 250W AC/DC power supply units for the MikroTik netPower product line. Built for situations when your outdoor switches need that extra juice. Pole/wall mount compatible!
    Compare
    $99.00
    MTP250-26V94-OD NEW
    Outdoor 26V 250W AC/DC power supply units for the MikroTik netPower product line. Built for situations when your outdoor switches need that extra juice. Pole/wall mount compatible!
    Compare
    $99.00
    QM-X
    quickMOUNT-X – additional axis for pole-mounting SXTsq devices
    Compare
    $3.00
    RBPOE
    PoE injector, for 10/100Mbps products
    Compare
    $5.00
    K-65
    Rackmount ears for RB4011 series
    Compare
    $5.00
    nRayAIM-DH1
    An alignment and aiming attachment for the nRAY
    Compare
    $5.00
    QM
    Basic wall mount adapter for small point to point and sector antennas
    Compare
    $5.50
    GPeR IP67 Case
    IP68 outdoor enclosure for the GPeR.
    Compare
    $7.00
    RBGPOE
    PoE injector, for Gigabit LAN products
    Compare
    $8.00
    ACMMCXRPSMA
    MMCX to RPSMA pigtail
    Compare
    $8.00
    ACOMNIRPSMA
    2.4Ghz 5dBi Dipole antenna with RPSMA connector
    Compare
    $8.00
    RB2011 Wall Mount Kit
    Wall mount kit for RB2011 desktop series, Protects cables, Powder coated steel
    Compare
    $8.95
    18POW
    24V 0.8A Power adapter
    Compare
    $9.00
    Flex-guide
    Low loss cable assembly, soldered on both ends, with silver plated copper and less than 0.65dB losses
    Compare
    $9.00
    HGO-antenna-OUT
    Dual-band screw-on outdoor antenna
    Compare
    $9.00
    QMP
    Advanced wall mount adapter for small point to point and sector antennas
    Compare
    $9.50
    QME
    Advanced wall mount adapter for large point to point and sector antennas
    Compare
    $9.50
    QMP-LHG
    Advanced wall mount adapter for LHG
    Compare
    $9.50
    GPEN11
    A power injector that can be mounted on a wall
    Compare
    $11.00
    RB4011 wall mount kit
    A simple solution for mounting the RB4011 in public locations to avoid accidental unplugging of cables.
    Compare
    $12.00
    MT48-480095-11DG
    48 V, 0.95 A power supply for long Ethernet cable runs
    Compare
    $12.00
    MT48-570080-11DG
    57 V, 0.8 A power supply for long Ethernet cable runs
    Compare
    $12.00
    SAW30-240-1200GA
    24v 1.2A power supply with straight plug
    Compare
    $12.00
    SAW30-240-1200GR2A
    24v 1.2A power supply with right angle plug
    Compare
    $12.00
    ACSWIM
    2.4/5Ghz Omni antenna, 4dBi gain, MMCX connector
    Compare
    $15.00
    LHG mount
    Basic pole mount adapter for LHG series, made from metal
    Compare
    $15.00
    GPeR
    Gigabit Passive Ethernet Repeater
    Compare
    $16.00
    24HPOW
    24V 2.5A adapter
    Compare
    $18.00
    48POW
    48V 1.46A 70W power adapter
    Compare
    $18.00
    Woobm-USB
    The Wireless out of band management USB stick
    Compare
    $22.00
    RBGPOE-CON-HP
    48 to 24V 10/100/1000Mbps PoE converter 802.3af support, 802.3at PoE plus support
    Compare
    $24.95
    solidMOUNT
    An advanced pole mount adapter for LHG series products
    Compare
    $29.00
    GESP
    New revision of Gigabit Ethernet Surge Protector in IP67 waterproof enclosure
    Compare
    $29.00
    GB60A-S12
    12V 5A internal power supply for CCR1016 series
    Compare
    $29.00
    MQS
    Mobile Quick Setup - system administrator’s best friend
    Compare
    $30.00
    GPEN21
    Smart power injector that serves as an advanced software controlled repeater
    Compare
    $37.00
    RBFTC11
    Fiber to Copper converter, Outdoor case, 12-57V PoE with 802.3af/at support
    Compare
    $39.00
    48V2A96W
    48 V 2 A 96 W power supply with plug
    Compare
    $39.00
    CWDM-CHASSIS-2
    1U Chassis bracket for CWDM MUX/DEMUX
    Compare
    $39.00
    UP1302C-12
    12V 10.8A internal power supply for CCR1036 series
    Compare
    $39.00
    PW48V-12V85W
    ±48V Open frame Power supply with 12V 7A output, for CCR since revision r2
    Compare
    $49.00
    12POW150
    Hot Swap power supply for CCR1072
    Compare
    $100.00
    PW48V-12V150W
    Hot Swap -48V DC telecom power supply for CCR1072. Supported input Voltage -36 .. -57V.
    Compare
    $100.00
    Antennas
    MTA Radome Kit
    Radome Cover Kit for mANT, reduces wind load, increases antenna operational life
    Compare
    $39.00
    mANT 15s
    Dual-polarization 5Ghz 15dBi 120 degree beamwidth antenna with two RP-SMA connectors
    Compare
    $49.00
    mANT 19S
    Dual-polarization 5Ghz 19dBi 120 degree beamwidth antenna with two RP-SMA connectors
    Compare
    $99.00
    mANT30
    Parabolic dish antenna for 5GHz, 30dBi gain
    Compare
    $129.00
    Sleeve30
    Sleeve30 kit for our mANT30 parabolic antenna to enhance point-to-point link performance
    Compare
    $129.00
    mANT30 PA
    Parabolic dish antenna for 5GHz, 30dBi gain. This model includes precision alignment mount
    Compare
    $149.00
    Product archive
    FiberBox
    An outdoor switch with five SFP ports
    Compare
    $79.00
