Skip to main content
Discontinued
PowerBox
650MHz CPU, 64MB RAM, 5xEthernet with PoE output for four ports, RouterOS L4, outdoor case, PSU
Outdoors
PoE
PowerBox
Product image
Product image
Product image
Product image thumbnail
The PowerBox is an outdoor five Ethernet port router with PoE output on four ports. You can use this device to supply power to four PoE capable devices such as our SXT or others.
Since the device has a waterproof outdoor case, you can mount it on a tower, or in other outdoor locations.
The unit has five shielded Ethernet ports, four of which can power other PoE capable devices with the same voltage as applied to the unit (max current out is 1A per port, max total out is 2A). Less power adapters and cables to worry about!
Specification
Specifications
  • Product code RB750P-PBr2
  • Suggested price $69.00
  • Architecture MIPSBE
  • CPU QCA9533
  • CPU core count 1
  • CPU nominal frequency 650 MHz
  • Switch chip model QCA9533
  • Dimensions 125x178x48mm
  • RouterOS license 4
  • Operating System RouterOS
  • Size of RAM 64 MB
  • Storage size 16 MB
  • Storage type FLASH
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 8-30 V
  • Max power consumption 50 W
  • Max power consumption without attachments 2 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 8-30 V
PoE-out
  • PoE-out ports Ether2-Ether5
  • PoE out Passive PoE
  • Low voltage PoE-Out current limit 1 A
  • Max total out (A) 2 A
Ethernet
  • 10/100 Ethernet ports 5
Other
  • Current Monitor Yes
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP 20
Included parts
Note
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.5 download files for mipsbe devices.
More in download page
Related Products
