Skip to main content
Discontinued
BaseBox 6
6GHz integrated AP/Backbone/CPE, 2xRPSMA connectors, miniPCI-e slot, Gigabit Ethernet
IP 54
Mini PCI-e
Outdoors
PoE
BaseBox 6
Product image
Product image
Product image thumbnail
The BaseBox 6 in an outdoor wireless device, based on our popular RB912 model, fitted with two SMA connectors for antennas, and a cable hood for protection against moisture. Also available are three additional places for antenna connectors, in case you wish to use the BaseBox miniPCIe slot for one more wireless interface to make a dual band device, or a 3G/4G modem.
Designed to use as an 6GHz AP with our 6GHz CPEs, like DynaDish 6 and SXT 6.
IMPORTANT! Product is available for 5.9-6.4GHz license holders only, you would need to show your license to Distributor to be able to place your order.
This product is not suitable for unlicensed ISM bands. Device use is subject to country regulations. Availability might be limited depending on distributor stock and country regulations.
Specification
Specifications
  • Product code RB912UAG-6HPnD-OUT
  • Suggested price $89.00
  • Architecture MIPSBE
  • CPU AR9342
  • CPU core count 1
  • CPU nominal frequency 600 MHz
  • Dimensions 246 x 135 x 50 mm
  • RouterOS license 4
  • Operating System RouterOS
  • Size of RAM 64 MB
  • Storage size 128 MB
  • Storage type NAND
Powering
  • Number of DC inputs 1 (PoE-IN)
  • Max power consumption 23 W
  • Max power consumption without attachments 12 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 10-30 V
Wireless specifications
  • Wireless 6 GHz Max data rate 300 Mbit/s
  • Wireless 6 GHz Number of chains 2
  • Wireless 6 GHz standards 802.11a/n
  • Wireless 6 GHz chip model AR9342
  • Wireless 6 GHz generation Wi-Fi 4
Ethernet
  • 10/100/1000 Ethernet ports 1
Peripherals
  • Number of SIM slots 1 Modem (Mini SIM)
  • MiniPCI-e slots 1
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB type A
  • Max USB current (A) 1
Other
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Beeper Yes
Certification & Approvals
  • Certification EAC
  • IP IP54
Included parts
Note
Wireless Specification
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.5 download files for mipsbe devices.
System Package
More in download page
