Skip to main content
Discontinued
DynaDish 6
Dual chain 25dBi Long Range 5.9-6.4GHz Integrated antenna for licensed band
Outdoors
PoE
DynaDish 6
Product image
Product image
Product image
Product image
Product image thumbnail
The Dynadish 6 uses the same effective antenna design and enclosure as our successful 5 GHz model, but this new device operates in the licensed 6GHz frequency. This means less interference than the often saturated 5 GHz frequencies for higher speed and more reach. By operating above the most popular WiFi frequencies you are now able to build your wireless links from busy towers without suffering problems with noise.
It is a simple and completely integrated product with everything you need to quickly install a reliable point to point link.
This product is not suitable for unlicensed ISM bands. Device use is subject to country regulations. Availability might be limited depending on distributor stock and country regulations.
Specification
Specifications
  • Product code RBDynaDishG-6HnD
  • Suggested price $179.00
  • Architecture MIPSBE
  • CPU AR9344
  • CPU core count 1
  • CPU nominal frequency 600 MHz
  • Dimensions Ø 404 mm
  • RouterOS license 4
  • Operating System RouterOS
  • Size of RAM 64 MB
  • Storage size 16 MB
  • Storage type FLASH
Powering
  • Number of DC inputs 1 (PoE-IN)
  • Max power consumption 10 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 12-30 V
Wireless specifications
  • Wireless 6 GHz Max data rate 300 Mbit/s
  • Wireless 6 GHz Number of chains 2
  • Wireless 6 GHz standards 802.11a/n
  • Antenna gain dBi for 6 GHz 25
  • Wireless 6 GHz chip model AR9344
  • Wireless 6 GHz generation Wi-Fi 4
Ethernet
  • 10/100/1000 Ethernet ports 1
Other
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Beeper Yes
Certification & Approvals
  • Certification EAC
  • IP IP33
Included parts
Note
Wireless Specification
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.1 download files for mipsbe devices.
System Package
More in download page
Related Products
