Skip to main content
Discontinued
SXT R
10.5dBi 60 degree LTE antenna with 2x Ethernet ports (one with PoE out), WITHOUT LTE modem
Mini PCI-e
Outdoors
PoE
SXT R
Product image
Product image
Product image thumbnail
The SXT R is an integrated low-cost 10.5dBi LTE antenna WITHOUT LTE modem (free miniPCI-e slot). In the case, if for any reason you don't want to use one of our own LTE modems, you can simply buy the SXT R and install the modem of your choice.
The SXT R is a device for remote locations that are within cellular network coverage. However, due to it’s professional LTE chip design and high gain antenna, it can provide connectivity for your building even where cell phones can’t.
The unit is equipped with two Ethernet ports (the second port has PoE-out functionality), so you can use it to power up another device. The unit includes a 24 V power supply, but can support full range of 12-57 V and 18-57 V with PoE-Out and is 802.3af/at compliant.
*) the device has no built in LTE modem, the SIM slot can only be used, if an LTE modem is installed (not included with the product).
Specification
Specifications
  • Product code RBSXTR
  • Suggested price $89.00
  • Architecture MIPSBE
  • CPU QCA9531
  • CPU core count 1
  • CPU nominal frequency 650 MHz
  • Switch chip model QCA9531
  • RouterOS license 3
  • Operating System RouterOS
  • Size of RAM 64 MB
  • Storage size 16 MB
  • Storage type FLASH
  • Tested ambient temperature -40°C to 60°C
Powering
  • Number of DC inputs 1 (PoE-IN)
  • PoE in 802.3af/at
  • Cooling type Passive
  • PoE in input Voltage 12-57 V
PoE-out
  • PoE-out ports Ether2
  • PoE out Passive PoE up to 57V
  • Low voltage PoE-Out current limit 600 mA
  • High voltage PoE-Out current limit 400 mA
  • Max total out (A) 600 mA
Ethernet
  • 10/100 Ethernet ports 2
Peripherals
  • Number of SIM slots 2 Modem (Micro SIM)
  • MiniPCI-e slots 1
Other
  • Mode button Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
Included parts
Note
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.1 download files for mipsbe devices.
System Package
More in download page
