Skip to main content
CRS804 DDQ
A compact 1U 400G switch built for AI clusters, storage fabrics, and high-speed aggregation, featuring four 400G QSFP56-DD ports, dual 10 Gigabit Ethernet, and RouterOS v7. With hot-swap power supplies, robust cooling, and low power consumption, it delivers ultra-high bandwidth, wire-speed performance, and future-proof scalability at an accessible price point.
Background image
4x
Background image
2x
1G/10G Ethernet ports
* QSFP-DD ports also support break-out modes to 1G/2.5G/5G/10G/25G/50G
CRS804 DDQ is the practical and cost-effective approach to
400 Gigabit speeds, AI, and future-proofing.
4 GB of RAM
Quad-core 2 GHz ARM CPU
Dual-redundanthot-swap power supplies
2x hot-swap cooling fans
RouterOS v7
Reach wire-speed on all ports
with the mighty Marvell switch-chip!
Background image
The CRS804 DDQ is a compact and reliable 400 Gigabit switch designed for modern AI workloads and next-generation network upgrades. With four 400G QSFP-DD ports and dual 1/10G Ethernet, it delivers exceptional bandwidth density in a quiet and efficient 1U form factor.
Background image
Inside, a Marvell 98DX7335 switch chip works together with a hefty quad-core 2.0 GHz ARM CPU, 4 GB of DDR4 RAM, and RouterOS v7. This provides advanced traffic control, high performance switching, and a familiar management environment trusted by users worldwide.
Background image
The CRS804 DDQ is designed for long-term reliability and low cost of ownership, supported by hot-swap power supplies (included!), robust cooling, and low power consumption that reaches only 123 W at full load with optics installed.
Where does it fit
AI and GPU clusters
A perfect building block for small to medium AI installations. It delivers predictable, low-latency performance and full wire-speed switching, keeping GPU nodes and storage traffic flowing without bottlenecks. The compact design and low power usage make it suitable for AI labs, research environments, and smaller rack deployments.
Future proofing for existing networks
The CRS804 DDQ can act as a high speed core or aggregation switch even in older racks. Each 400G QSFP-DD port is built from eight independent data lanes. This enables flexible breakout options, including two 200G links for AI workloads or lower-speed connections such as 100G or 40G. You can deploy the CRS804 DDQ in your existing network today and upgrade to higher speeds over time without replacing the switch. With the right breakout cables, the CRS804 DDQ can interconnect virtually any device with SFP or QSFP ports, regardless of generation.
All-flash storage fabrics
Use native 400G ports for fast storage uplinks or split them into dual 200G links. Ideal for media production, scientific workloads, and any environment where rapid data movement is essential.
Compact 400G fabrics in limited rack space
Create a powerful spine or backbone fabric using four 400G ports. Perfect for small datacenters, enterprise pods, edge compute installations, and environments where traditional 400G equipment would be too loud, too large, or too expensive.
CRS804 DDQ
Product image
Product image
Product image
Product image
Product image thumbnail
Specification
Specifications
  • Product code CRS804-4DDQ-hRM
  • Suggested price $1,295.00
  • Architecture ARM 64bit
  • CPU AL52400
  • CPU core count 4
  • CPU nominal frequency 2000 MHz
  • CPU Threads count 4
  • Switch chip model 98DX7335
  • RouterOS license 6
  • Operating System RouterOS v7
  • Size of RAM 4 GB
  • Storage size 512 MB
  • Storage type NAND
  • Tested ambient temperature -10°C to 60°C
Powering
  • Number of AC inputs 2
  • AC input range 100-240
  • Frequency (Hz) 50-60
  • Max power consumption 123 W
  • Max power consumption without attachments 92 W
  • Cooling type 2 fans
Ethernet
  • Number of 1G/2.5G/5G/10G Ethernet ports 2 (supported: 10M/100M/1G/10G)
  • Number of 400G QSFP56-DD ports 4
Peripherals
  • Serial console port RJ45
Other
  • CPU temperature monitor Yes
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP 20
Included parts
Note
Switching results
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.5 download files for arm64 devices.
System Package
Default Packages
More in download page
