Skip to main content
MT-HotSwapFan-V2
Hot-swap fan module for CRS804 DDQ.
MT-HotSwapFan-V2
Product image
Product image thumbnail
Be prepared for the unexpected with the MT-HotSwapFan-V2, a hot-swappable replacement fan module designed for the CRS804 DDQ.
If a fan needs servicing, you can replace it without powering down the switch, avoiding unnecessary downtime in critical environments. This makes it an ideal choice for AI clusters, storage networks, and high-speed backbones where continuous operation matters.
The MT-HotSwapFan-V2 helps maintain proper airflow and cooling performance, ensuring reliable operation even under sustained high-speed workloads.
Specification
Specifications
  • Product code MT-HotSwapFan-V2
  • Suggested price $29.00
Documents
Brochure
.PDF
Brochure PDF first page
Related Products
