Skip to main content
New
G1394-0350WNA
The G1394-0350WNA is a 12VDC 27.5A 350W hot-swap power supply designed for the CRS804 DDQ switch.
G1394-0350WNA
Product image
Product image thumbnail
It serves as a direct replacement power module, allowing you to restore full power redundancy or replace a failed unit without shutting down the device. The module can be installed or replaced while the switch is running, ensuring uninterrupted operation in critical environments.
This power supply is ideal for data centers, enterprise racks, labs, and any deployment where standard AC mains power is used.
Specification
Specifications
  • Product code G1394-0350WNA
  • Suggested price $119.00
Documents
Related Products
