Skip to main content
Discontinued
CRS226-24G-2S+IN
24x Gigabit Ethernet layer 3 Smart Switch, 2x SFP+ cages, LCD, 400MHz CPU, 64MB RAM, Metal desktop case, RouterOS L5
PoE
SFP/SFP+
CRS226-24G-2S+IN
Product image
Product image thumbnail
Cloud Router Switch is our new member of our Smart Switch series. It combines the best features of a fully functional router and a Layer 3 switch, is powered by the familiar RouterOS. All the specific Switch configuration options are available in a special Switch menu, but if you want, ports can be removed from the switch configuration, and used for routing purposes. The CRS226 uses a new class of switch chips, which allows us to have two SFP+ ports for 10G connectivity.
Specification
Specifications
  • Product code CRS226-24G-2S+IN
  • Suggested price $289.00
  • Architecture MIPSBE
  • CPU QCA8519
  • CPU core count 1
  • CPU nominal frequency 400 MHz
  • Switch chip model QCA8519-AC2C
  • Dimensions 285x145x45mm
  • RouterOS license 5
  • Operating System RouterOS
  • Size of RAM 64 MB
  • Storage size 128 MB
  • Storage type NAND
  • Tested ambient temperature -35C to +65C
Powering
  • Number of DC inputs 1
  • Max power consumption 21 W
  • Max power consumption without attachments 21W
  • PoE in Passive PoE
Ethernet
  • 10/100/1000 Ethernet ports 24
Fiber
  • SFP DDMI Yes
  • SFP+ ports 2
Peripherals
  • Serial console port RJ45
Other
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Beeper Yes
Included parts
Note
Switching results
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.2 download files for mipsbe devices.
System Package
More in download page
