Skip to main content
Discontinued
CCR1009-8G-1S-1S+PC
8x Gigabit Ethernet, 1xSFP cage, 1xSFP+ cage, 9 cores x 1GHz CPU, 2GB RAM, LCD panel, passive cooling desktop enclosure, SmartCard slot, RouterOS L6, PSU
PoE
SFP/SFP+
CCR1009-8G-1S-1S+PC
Product image
Product image
Product image thumbnail
Our popular 9-core Cloud Core Router is now available in a new passive cooling enclosure.
This CCR1009 unit is equipped with two heat-pipes and a specially designed heat-sink, so its completely silent.
The unit is powered by an external 24v 2.5A AC/DC adapter and supports power redundancy if you also power it from the PoE input port.
The device comes with a desktop enclosure, but special rackmount brackets are also included, so it can be used either on desk or in rack.
Specification
Specifications
  • Product code CCR1009-8G-1S-1S+PC
  • Suggested price $495.00
  • Architecture TILE
  • CPU TLR4-00980
  • CPU core count 9
  • CPU nominal frequency 1 GHz
  • CPU Threads count 9
  • Switch chip model AR8327-BL1A-R
  • Dimensions 272x190x47mm
  • RouterOS license 6
  • Operating System RouterOS
  • Size of RAM 2 GB
  • Storage size 128 MB
  • Storage type NAND
  • Tested ambient temperature -20°C to 60°C
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 14-57 V
  • Max power consumption 30 W
  • Max power consumption without attachments 30W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 14-57 V
Ethernet
  • 10/100/1000 Ethernet ports 8
Fiber
  • SFP ports 1
  • SFP+ ports 1
Peripherals
  • Number of SIM slots 1 Smart card (Mini SIM)
  • Serial console port RS232
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type microUSB type AB
  • Max USB current (A) 1
Other
  • CPU temperature monitor Yes
  • Current Monitor Yes
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Beeper Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
Included parts
Note
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.5 download files for tile devices.
More in download page
