Skip to main content
Discontinued
CCR1009-8G-1S-1S+
1U rackmount, 8x Gigabit Ethernet, 1xSFP cage, 1xSFP+ cage, 9 cores x 1.2GHz CPU, 2GB RAM, LCD panel, Dual Power supplies, SmartCard slot, RouterOS L6
Outdoors
PoE
SFP/SFP+
CCR1009-8G-1S-1S+
Product image
Product image thumbnail
The CCR1009 is a powerful Ethernet router based on the cutting edge TILERA 9 core CPU.
CCR1009-8G-1S-1S+ comes with 2GB of RAM, eight Gigabit Ethernet ports (Ether1-4 are in a Switch group), one SFP port and one SFP+ port with 10G support (SFP module not included).
CCR1009-8G-1S-1S+ model have dual power supplies built in for redundancy (if one power line fails, the other one will take over automatically).
Also, CCR1009-8G-1S-1S+ supports a Smart card, to store your private key for use in all features that support Certificate based authentication.
SFP+ port supports SFP (1.25G) modules as well.
Specification
Specifications
  • Product code CCR1009-8G-1S-1S+
  • Suggested price $495.00
  • Architecture TILE
  • CPU TLR4-00980
  • CPU core count 9
  • CPU nominal frequency 1.2 GHz
  • CPU Threads count 9
  • Switch chip model AR8327
  • Dimensions 444x175x44mm
  • RouterOS license 6
  • Operating System RouterOS
  • Size of RAM 2 GB
  • Storage size 128 MB
  • Storage type NAND
  • Tested ambient temperature -20°C to 60°C
Powering
  • Number of AC inputs 2
  • AC input range 100-240
  • Number of DC inputs 1 (PoE-IN)
  • Number of PSU slots 2
  • Frequency (Hz) 50-60
  • Max power consumption 35 W
  • PoE in Passive PoE
  • Cooling type 2 fans
  • PoE in input Voltage 14-57 V
Ethernet
  • 10/100/1000 Ethernet ports 8
Fiber
  • SFP DDMI Yes
  • SFP ports 1
  • SFP+ ports 1
Peripherals
  • Number of SIM slots 1 Smart card (Mini SIM)
  • Serial console port RS232 + Header
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type microUSB type AB
  • Max USB current (A) 1
Other
  • CPU temperature monitor Yes
  • Current Monitor Yes
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Beeper Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
Included parts
Note
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.5 download files for tile devices.
More in download page
