Double your fiber reach with the new multi-rate SFP28 module! Supporting 1G, 10G, and 25G over distances up to 40 km, it's ideal for ISP networks, remote sites, and long-distance links. Features DDM and an extended −40°C to +85°C temperature range.
A multi-rate SFP/SFP+/SFP28 optical module for long-distance single-mode fiber connections.
Extend your fiber links up to 40 km without giving up flexibility. The XS+31LC40D supports 1.25G, 10G, and 25G connectivity in a single module, making it a practical choice for connecting distant network sites, expanding ISP infrastructure, and building high-speed links across longer routes.
Operating at 1310 nm, the module features digital diagnostic monitoring (DDM) for keeping track of optical performance and an extended operating temperature range of −40°C to +85°C.
ISP distribution and aggregation
Connect distant points of presence, distribution switches, and network aggregation sites over single-mode fiber.
Remote facilities and industrial networks
Extend high-speed connectivity to offices, production facilities, and other locations separated by long fiber routes.
Flexible network upgrades/scalability
Run 1G or 10G links today and move to 25G when the connected equipment supports it – without replacing the optical module.
CRS310-8G+2S+IN
a compact switch with two 10G SFP+ ports for distribution and remote-site connections.
CCR2004-1G-12S+2XS
a versatile router with twelve 10G SFP+ and two 25G SFP28 ports for mixed-speed networks
CRS510-8XS-2XQ-IN
a high-capacity switch with eight 25G SFP28 ports and two 100G QSFP28 ports for aggregation infrastructure.
The module includes built-in digital diagnostics (DDM) for monitoring optical power, voltage, temperature, laser bias current, and other key parameters. These functions help detect abnormal activity or when customizable operating limits are exceeded. Monitoring makes it easier to plan ahead, make informed decisions, and schedule upgrades or maintenance based on real performance data.
