Skip to main content
Discontinued
CRS125-24G-1S-RM
24x Gigabit Ethernet layer 3 Smart Switch, 1x SFP cage, LCD, 600MHz CPU, 128MB RAM, 1U rackmount, RouterOS L5
PoE
SFP/SFP+
CRS125-24G-1S-RM
Product image
Product image thumbnail
Cloud Router Switch is our new Smart Switch series. It combines the best features of a fully functional router and a Layer 3 switch, is powered by the familiar RouterOS. All the specific Switch configuration options are available in a special Switch menu, but if you want, ports can be removed from the switch configuration, and used for routing purposes.
Choose ports for Wire speed switching, or for routing purposes.
Perfect SOHO gateway router, switch, all in one box:
• Ethernet, Fiber, or 4G (with optional USB modem) gateway connection to Internet
• RouterOS gateway/firewall/VPN router with passive cooling
• up to twenty-five gigabit switch ports (1xSFP and 24xRJ45)
Box includes: Cloud Router Switch, 1U rackmount enclosure, power supply
Specification
Specifications
  • Product code CRS125-24G-1S-RM
  • Suggested price $199.00
  • Architecture MIPSBE
  • CPU AR9344
  • CPU core count 1
  • CPU nominal frequency 600 MHz
  • Switch chip model QCA8513L-2L1E
  • Dimensions 443x142x44mm
  • RouterOS license 5
  • Operating System RouterOS
  • Size of RAM 128 MB
  • Storage size 128 MB
  • Storage type NAND
  • Tested ambient temperature -30°C to 65°C
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 8-28 V
  • Max power consumption 15 W
  • Max power consumption without attachments 15W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 8-28 V
Ethernet
  • 10/100/1000 Ethernet ports 24
Fiber
  • SFP DDMI Yes
  • SFP ports 1
Peripherals
  • Serial console port RJ45
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type microUSB type AB
  • Max USB current (A) 1
Other
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Beeper Yes
Included parts
Note
Switching results
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.5 download files for mipsbe devices.
More in download page
