Skip to main content
Discontinued
mANT 19S
Dual-polarization 5Ghz 19dBi 120 degree beamwidth antenna with two RP-SMA connectors
mANT 19S
Product image
Product image
Product image
Product image
Product image
Product image thumbnail
The new sector mANT antennas are the perfect companion for the BaseBox, NetBox, NetMetal or any other outdoor wireless device.
The mANT is a dual-polarization 19dBi 120 degree beamwidth antenna with two RP-SMA connectors. It comes with metallic U bolt type mounts.
Specification
Specifications
  • Product code MTAS-5G-19D120
  • Suggested price $99.00
  • Beamwidth 120 deg (azimuth) 5 deg (elevation)
  • Connector two RP-SMA
  • Cross Polarization >30 dB
  • Diameter x Depth 152 x 598 x 78 mm
  • Frequency Range 5.17 - 5.825 GHz
  • Front-to-Back Ratio >30 dB
  • Polarization Vertical and horizontal
  • Port to Port Isolation >40 dB min
  • VSWR 1.43 typ, 1.8 max
  • Weight 1270 g
