Skip to main content
Discontinued
mANT30
Parabolic dish antenna for 5GHz, 30dBi gain
mANT30
Product image
Product image
Product image thumbnail
mANT30 is a professional class 5 GHz 30dBi dish antenna, built to the highest industry standards. Built to seamlessly accomodate our Basebox series products, but can be used for any pole mounted wireless device due to the adequate length of the included FlexGuide cable.
Two modifications are available - with a standard type mount (MTAD-5G-30D3), and with a precision alignment mount (MTAD-5G-30D3-PA). The antennas come packaged with all necessary accessories and cables.
Note: Basebox wireless device pictured for illustrative purposes. It is not included
Specification
Specifications
  • Product code MTAD-5G-30D3
  • Suggested price $165.00
  • Beamwidth +/-2.5 deg
  • Connector 2x RP-SMA Female (outside thread)
  • Cross Polarization >40 dB
  • Diameter x Depth 70 x 45cm (27.5 x 17.8in)
  • Elevation adjustment range +/- 20 deg
  • Frequency Range 4.7-5.875 GHz
  • Front-to-Back Ratio >30 dB
  • Impedance 50 ohms
  • Outdoor Rating ETSI EN 300 019-2-4
  • Packaged size 73x73x20cm (29x29x8in)
  • Packaged weight 7.5 kg (16.5 lbs)
  • Polarization Vertical and Horizontal
  • Pole Mount Diameter Range 3 to 7cm (1.2 to 2.75in)
  • Port to Port Isolation >40dB min
  • Power Rating 100W
  • Reflector Aluminum
  • Standards EN 302 326 DN1, DN2, DN3, DN5
  • Tested ambient temperature -50°C to 80°C(-49°F to 158°F)
  • VSWR ≤ 1.4 typ, ≤ 1.8 max
  • Weight 4.8kg (10.7 lbs)
  • Wind Load (125 mph) 181.4kg (400 lbs) at 125 mph, 50 kg at 40 m/s, 28 kg at 30 m/s
  • Wind Survivability 201kph (125mph)
Certification & Approvals
  • Certification CE, ROHS
Documents
Brochure
.PDF
Brochure PDF first page
