Skip to main content
Discontinued
DISC Lite5
Dual chain 21dBi 5GHz CPE/Point-to-Point Integrated Antenna, 600Mhz CPU, 64MB RAM
IP 54
Outdoors
PoE
DISC Lite5
Product image
Product image
Product image
Product image thumbnail
DISC Lite5 is an integrated 21dBi Dual Chain 802.11n CPE with a 600MHz CPU, 64MB RAM, 1x 10/100Mbps Ethernet port and RouterOS L3 installed. The DISC uses a backfire type antenna which allows to reach 21dBi gain in such a low cost and compact package.
The device comes complete with a power supply, PoE injector and mounting kit for a ultra low cost at $48!
The RouterOS Level3 allows to use the DISC Lite5 as CPE or Point-to-Point 5GHz links.
We have two versions available.
- DISC Lite5 US (USA) is factory locked for 5170-5250MHz and 5725-5835MHz frequencies. This lock can not be removed.
- DISC Lite5 (International) supports 5150MHz-5875MHz range (Specific frequency range can be limited by country regulations).
Specification
Specifications
  • Product code RBDisc-5nD
  • Suggested price $55.00
  • Architecture MIPSBE
  • CPU AR9344
  • CPU core count 1
  • CPU nominal frequency 600 MHz
  • Dimensions ⌀ 265mm, height: 80mm
  • RouterOS license 3
  • Operating System RouterOS
  • Size of RAM 64 MB
  • Storage size 16 MB
  • Storage type FLASH
Powering
  • Number of DC inputs 1 (PoE-IN)
  • Max power consumption 6 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 10-30 V
Wireless specifications
  • Wireless 5 GHz Max data rate 300 Mbit/s
  • Wireless 5 GHz Number of chains 2
  • Wireless 5 GHz standards 802.11a/n
  • Antenna gain dBi for 5 GHz 21
  • Wireless 5 GHz chip model AR9344
  • Wireless 5 GHz generation Wi-Fi 4
Ethernet
  • 10/100 Ethernet ports 1
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
  • IP IP54
Included parts
Note
Wireless Specification
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.2 download files for mipsbe devices.
System Package
More in download page
Related Products
