Skip to main content
Discontinued
RB433GL
680MHz CPU, 128MB RAM, 3x Gigabit Ethernet, 3x miniPCI, USB, RouterOS L5
Outdoors
PoE
RB433GL
Product image
Product image thumbnail
The RB433GL has three miniPCI slots, three Gigabit Ethernet ports and one USB port for storage or a 3G modem.
Three Gigabit Ethernet ports and three miniPCI slots gives you plenty of options- it can be high speed Gigabit Router, sector AP, wireless backhaul, firewall etc. Powerful Atheros 680MHz CPU, 128MB of RAM and Level5 RouterOS license provides required horsepower.
Differences between RB433GL and RB433AH can be seen in the file (RB411L differences) in the left hand menu.
Specification
Specifications
  • Product code RB433GL
  • Suggested price $139.00
  • Architecture MIPSBE
  • CPU AR7161
  • CPU core count 1
  • CPU nominal frequency 680 MHz
  • Switch chip model AR8327-BL1A
  • Dimensions 105 mm x 154 mm,
  • RouterOS license 5
  • Operating System RouterOS
  • Size of RAM 128 MB
  • Storage size 64 MB
  • Storage type NAND
  • Tested ambient temperature -40°C .. +70°C tested
Powering
  • Number of DC inputs 1
  • PoE in Passive PoE
Ethernet
  • 10/100/1000 Ethernet ports 3
Peripherals
  • MiniPCI slots 3
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB type A
Other
  • Voltage Monitor Yes
  • Beeper Yes
Note
Ethernet test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.2 download files for mipsbe devices.
More in download page
Related Products
