Products
Products
    Q+85MP01D 40 Gbps 850nm optical QSFP+ module
    This is an optical module with MTP/MPO connector for 12-fiber array that requires Female-Female Type-B polarity MTP/MPO optical cable, which offers 4 independent full-duplex channels with up to 10 Gbps per channel bandwidth and aggregate bandwidth of 40 Gbps.
    It can provide a connection over 100 m on OM3 Multimode Fiber (MMF) and 150 m on OM4 MMF. The module has built-in digital diagnostic functions, including optical power monitoring, and will perform well in environments up to 70° C.
    It has been designed to meet the harshest conditions, including temperature, humidity and EMI interference, so we definitely recommend this as a reliable solution for all your 40 Gbps QSFP+ devices.
     Send purchase questions
    Product specifications
    Details
    Product code Q+85MP01D
    Connector 1x12 MTP/MPO
    Data Rate 40Gbps
    Distance 150m
    Format QSFP+
    MTBF Approximately 100'000 hours at 25C
    Mode MM
    Wavelength 850nm
    Suggested price $59
    BrochureOpen
    SFP compatibility listOpen
    High resolution images
    Related products
