Skip to main content
New
hAP be³ Media
hAP be³ Media – the professional all-in-one platform for routing, services, containers, and modern network workloads. This is a powerful Wi-Fi 7 hybrid router and media hub combining triple-band wireless, five 2.5G Ethernet ports, built-in Matter/Thread smart automation/IoT support, and a quad-core ARM CPU for containers, storage, and advanced networking. Coming soon!
Triple band 2x2 MIMO Wi-Fi 7
5 x 2.5G Ethernet
Quad-core up to 1.5 GHz ARM CPU
USB-C + 2x USB-A
Thread radio
PoE Input and DC jack
Bluetooth 5.4
Container support
microSD card slot
Triple-band 2x2 MIMO Wi-Fi 7
Is this heaven?
The hAP be³ Media delivers true Wi-Fi 7 performance across the 2.4, 5, and 6 GHz bands.
Expect higher throughput, lower latency, improved security, and better spectral efficiency. The wide 6 GHz band offers more clean spectrum, helping reduce congestion in busy environments
Also, hAP be³ Media supports Wi-Fi 7 Multi-Link Operation (MLO) in TR-MLMR (AP mode).
Whether you are running a multi-device setup, a network lab, workstations, VR headsets, NAS backups, cloud sync, or high-resolution media streaming, everything can run simultaneously without competing for airtime. More bands mean more capacity, smoother performance, and a wireless experience that finally keeps up with modern workloads.
Background image
2.5 Gigabit Ethernet on all ports
That’s right – no more bottlenecks! Ultra-fast ISP uplink, NAS servers, workstations – you can have it all
Background image
A modern hybrid media center
With USB-C, two USB-A ports, and a microSD card slot, hAP be³ Media becomes the heart of your local media storage. Use flash storage for backups, photos, video surveillance or a private family cloud
Self-hosted password managers, documents and services – that is the way in 2026, if you care about privacy and security. Store automation data and container workloads without relying on external servers. Everything stays fast, local, and fully under your control. Also, with the MikroTik BTH app and the improved File share functionality in WinBox, you can share large files without worrying about expired links, delays or privacy.
Matter matters
smart Internet-of-things integration has never been easier
With Wi-Fi 7, Bluetooth 5.4, and RouterOS v7,
hAP be³ Media provides a solid foundation for modern IoT setups.
A built-in Thread radio and full container support allow users to deploy Thread IoT automation solutions that remain local, private, and fully customizable.
Impressive quad-core performance
for container-heavy, creative workflows
Background image
Powered by a modern 1.5 GHz quad core CPU and built on an efficient ARM64 architecture, hAP be³ Media is ready for far more than traditional networking. Containers, local dashboards, scripting, complex firewall rules, encryption, multiple VPNs, BGP and advanced routing all run smoothly on a single, compact device. This is performance you can rely on today, and capacity that will stay ahead of your everyday needs for years to come.
Background image
And if you think containers are complicated – think again! We’ve included a simple one-click setup page in WinBox where you can enable the desired container apps.
From visualizing network topology and hosting lightweight websites to running custom dashboards, security tools or even experimental local AI assistants, containers open the door to a whole new set of possibilities
As always, the full feature set of hAP be³ Media is available to you
without any subscriptions or paywalls.
You buy it – you own it, that’s a MikroTik guarantee!
hAP be³ Media
Product image
Product image
Product image
Product image
Product image
Product image
Product image
Product image thumbnail
Specification
Specifications
  • Product code MA53UG+HbeH
  • Suggested price $179.00
  • Architecture ARM 64bit
  • CPU IPQ-5322
  • CPU core count 4
  • CPU nominal frequency Up to 1.5 GHz (auto)
  • CPU Threads count 4
  • Switch chip model QCA8386
  • RouterOS license 6
  • Operating System RouterOS v7
  • Size of RAM 2 GB
  • Storage size 512 MB
  • Storage type NAND
  • Tested ambient temperature -30°C to 50°C
Wireless capabilities
  • Wireless 2.4 GHz Max data rate 688 Mbit/s
  • Wireless 2.4 GHz standards 802.11b/g/n/ax/be
  • Antenna gain dBi for 2.4 GHz 4
  • Wireless 2.4 GHz chip model IPQ-5322
  • Wireless 2.4 GHz generation Wi-Fi 7
  • Wireless 5 GHz Max data rate 2882 Mbit/s
  • Wireless 5 GHz Number of chains 2
  • Wireless 5 GHz standards 802.11a/n/ac/ax/be
  • Antenna gain dBi for 5 GHz 7.5
  • Wireless 5 GHz chip model QCM-8083
  • Wireless 5 GHz generation Wi-Fi 7
  • WiFi speed BE9300
  • Wireless 6 GHz Max data rate 5764 Mbit/s
  • Wireless 6 GHz Number of chains 2
  • Wireless 6 GHz standards 802.11ax/be
  • Antenna gain dBi for 6 GHz 8
  • Wireless 6 GHz chip model QXM-8086
  • Wireless 6 GHz generation Wi-Fi 7
Ethernet
  • Number of 2.5G Ethernet ports 5
Peripherals
  • Number of USB ports 3
  • USB slot type USB 3.0 type A
  • Max USB current (A) 1.5
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 24-57 V
  • Max power consumption 29 W
  • Max power consumption without attachments 20 W
  • PoE in 802.3af/at
  • Cooling type Passive
  • PoE in input Voltage 24-57 V
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
  • IP 20
Other
  • CPU temperature monitor Yes
  • Bluetooth version 5.4
Included parts
Note
Ethernet test results
IPsec test results
Documents
Download
Latest RouterOS stable release v7.24.5 download files for arm64 devices.
System Package
More in download page
