Skip to main content
hAP ax³
Our top-of-the-line AX home access point. With all the processing power and speed your household might ever need. Gen 6 wireless, 2.5 Gigabit Ethernet, PoE, WPA3, and more!
2.5G ethernet PoE Input/Output
4 x 1G ethernet
802.11ax + Wave 2
Strong Dual-Band, Dual-Chain wireless
USB 3 port for storage & file sharing
Powerful 1.8 GHz ARM CPU
Video thumbnail
Ultimate power for your whole home
hAP ax³ is our most powerful AX device with the best wireless network coverage so far. It features a modern quad-core ARM CPU running at 1.8 GHz and enough memory (1GB RAM + 128 MB NAND) for most tasks. Complex firewall rules, IPsec hardware encryption, Wireguard, BGP, advanced routing, or multiple remote work VPN tunnels won’t stop your family from comfortable browsing, streaming, gaming, and so on. There’s enough processing power for everyone. And we’ve added a speedy USB 3 port for all your storage purposes or an additional LTE modem.
Background image
AX wireless – as strong as an ox
Depending on your overall setup, our AX product family offers up to 40% higher speed in the 5 GHz and up to 90% higher speed in the 2.4 GHz spectrum! Potent external antennas (via built-in RP-SMA female ports) allow reaching gain up to 5.5 dBi, so you can forget about Wi-Fi Boosters and other tricks. Smooth and fast connectivity for your whole apartment – that’s just how hAP ax³ works. Home network speeds are getting serious. There are 4x Gigabit Ethernet ports and an ultra-fast 2.5 Gigabit port.
Background image
Background image
Some might ask – why do we even need higher wireless speeds? Well, countless use cases have been previously impossible or difficult to pull off. For example, working with large media files over the wireless network – without the need to download and upload everything. Do you really have the time to wait? Grab a hAP ax³ and save more time for the essential things in life!
Background image
Safer in many ways
hAP ax³ can ease your mind on multiple levels simultaneously. European-based production, our famous Northern work ethic, and cooperation with the EU lawmakers ensure full compliance with all the necessary safety policies. Multiple power options (DC Jack & PoE Input) result in fewer worries about potential downtime. The latest RouterOS v7 updates and the addition of WPA3 advanced encryption support bring unprecedented software security.
To sum things up - hAP ax³ is among the fastest, safest, and most powerful choices in the home access point world. Wired or wireless. And it comes with the most advanced networking software on the market – RouterOS. Unlike many other vendors, we don’t limit what you can do. There are no paywalls or confusing subscriptions. All our devices share the same limitless operating system. Imagination is the only limitation.
hAP ax³
Product image
Product image
Product image
Product image thumbnail
Specification
Specifications
  • Product code C53UiG+5HPaxD2HPaxD
  • Suggested price $139.00
  • Architecture ARM 64bit
  • CPU IPQ-6010
  • CPU core count 4
  • CPU nominal frequency auto (864 - 1800) MHz
  • CPU Threads count 4
  • Switch chip model IPQ-6010
  • RouterOS license 6
  • Operating System RouterOS v7
  • Size of RAM 1 GB
  • Storage size 128 MB
  • Storage type NAND
Wireless capabilities
  • Wireless 2.4 GHz Max data rate 574 Mbit/s
  • Wireless 2.4 GHz standards 802.11b/g/n/ax
  • Antenna gain dBi for 2.4 GHz 3.3
  • Wireless 2.4 GHz chip model QCN-5022
  • Wireless 2.4 GHz generation Wi-Fi 6
  • Wireless 5 GHz Max data rate 1200 Mbit/s
  • Wireless 5 GHz Number of chains 2
  • Wireless 5 GHz standards 802.11a/n/ac/ax
  • Antenna gain dBi for 5 GHz 5.5
  • Wireless 5 GHz chip model QCN-5052
  • Wireless 5 GHz generation Wi-Fi 6
  • WiFi speed AX1800
Ethernet
  • 10/100/1000 Ethernet ports 4
  • Number of 1G Ethernet ports with PoE-out 1
  • Number of 2.5G Ethernet ports 1
Peripherals
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB 3.0 type A
  • Max USB current (A) 1.5
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 12-28 V
  • Max power consumption 38 W
  • Max power consumption without attachments 15 W
  • PoE in Passive PoE
  • Cooling type Passive
  • PoE in input Voltage 18-28 V
PoE-out
  • PoE-out ports Ether 1
  • PoE out Passive PoE
  • Low voltage PoE-Out current limit 0.625 A
  • Max total out (A) 0.625 A
  • Total output current 0.625
  • Total output power 15
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
  • IP 20
Other
  • CPU temperature monitor Yes
  • Mode button Yes
Included parts
Note
Wireless Specification
Ethernet test results
IPsec test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.2 download files for arm64 devices.
System Package
Default Packages
More in download page
