Skip to main content
Chateau LTE7 ax
Your favorite high-performance home and office LTE router just got a major upgrade. Chateau LTE7 ax keeps the same powerful hardware, sleek design, and Wi-Fi 6 performance – but now features an LTE Category 7 modem, expanded frequency support, and a significantly lower price than the previous LTE6 ax version.
Powerful 1.8 GHz Quad-core ARM CPU
Strong Dual-band, Dual-chain radio
Fast and respondive LTE Cat7 modem
Container support
4x Gigabit ethernet ports
1 GB of RAM
Are you tired of those suspicious, low-quality default routers from your service providers? So many households are switching to mobile internet, but those default routers can really ruin the experience. That’s why we decided to take everything we’ve learned over the last 20 years of networking excellence and create a single device that will make most households happy: the MikroTik Chateau.
Why upgrade to CAT7?
Twice the upload speed
Depending on the LTE tower infrastructure and other variables
Expanded frequency support
Including Band 28 (700 MHz) & Band 32 (1500 MHz) for better performance in congested areas
Carrier aggregation (2×CA)
For higher efficiency and responsiveness in busy networks
Same trusted design
No changes to installation or configuration
Lower cost
Better connectivity that actually costs less, especially on volume orders
A powerful LTE router for demanding networks
Background image
Background image
Chateau LTE7 ax combines the new R11e-LTE7 modem with a quad-core ARM CPU, 1GB of RAM, Wi-Fi 6 (802.11ax) dual-band wireless, and a 2.5 Gigabit Ethernet port for ultra-fast local connections. Run multiple secure VPN tunnels, advanced firewall rules, advanced container setups, or complex routing scenarios – all while enjoying faster and more reliable mobile connectivity. Whether LTE is your primary connection or a rock-solid backup to fiber, Chateau LTE7 ax adapts to your setup effortlessly… and in style!
Perfect for home offices, businesses, and ISPs
With five Ethernet ports (including a 2.5G port!), 2×2 MIMO LTE and full RouterOS v7 functionality, Chateau LTE7 ax fits a wide range of use cases:
Secure home offices and remote work
LTE-based or hybrid ISP deployments
Small and medium-sized businesses
Households that want performance and clean design
It’s equally comfortable in the hands of seasoned system administrators who need true flexibility – or users who just want to plug it in and forget it’s there.
Chateau supports the TR-069 technology that allows creating custom remote client management options. You can have the most straightforward and basic router settings on the same web-page that you are using to pay the mobile bill.
Two types of Chateau LTE7 ax users
Background image
Michael travels a lot. He has an ultra-fast ISP connection at home. 2.5 Gigabit Ethernet port is his main connection. He uses the LTE7 modem at his travel destination - instead of a hotspot.
Background image
Cynthia is a video editor. She uses the 2.5 Gigabit Ethernet to reach her NAS server with all the large media files. The LTE7 modem is her main connection to the outside world - with all the messengers, online meetings, and the occasional 4K movie streams.
The freedom of LTE
Reach consistent speeds of up to 300 Mbps with carrier aggregation, as CAT7 allows devices to use multiple bands simultaneously. That is a huge advantage in areas with many LTE users. Chateau provides better responsiveness in a crowded environment and higher efficiency for weaker signal situations in the countryside
Depending on the service provider, we have seen Internet speed doubling in rural areas after switching to carrier aggregation, so there is no need to wait for cable network expansions.
Chateau LTE7 ax
Product image
Product image
Product image thumbnail
Specification
Specifications
  • Product code S53UG+5HaxD2HaxD-TC&R11e-LTE7
  • Suggested price $169.00
  • Architecture ARM 64bit
  • CPU IPQ-6010
  • CPU core count 4
  • CPU nominal frequency auto MHz
  • CPU Threads count 4
  • Switch chip model IPQ-6010
  • RouterOS license 4
  • Operating System RouterOS v7
  • Size of RAM 1 GB
  • Storage size 128 MB
  • Storage type NAND
Powering
  • Number of DC inputs 1 (DC jack)
  • DC jack input Voltage 12-28 V
  • Max power consumption 21.5 W
  • Max power consumption without attachments 15.5 W
  • Cooling type Passive
Mobile
  • 3G Category R8 (DL: 42.2 Mbps; UL: 5.76 Mbps)
  • 3G bands 1 (2100 MHz)
    3 (1800 MHz)
    5 (850 MHz)
    8 (900 MHz)
  • LTE Category 7 (DL: 300 Mbps; UL: 100 Mbps)
  • MIMO DL 2x2
  • MIMO UL 1x1
  • LTE FDD bands 1 (2100 MHz)
    3 (1800 MHz)
    5 (850 MHz)
    7 (2600 MHz)
    8 (900 MHz)
    20 (800 MHz)
    28 (700 MHz)
    32 (1500 MHz)
  • LTE TDD bands 38 (2600 MHz)
    40 (2300 MHz)
    41 (2500 MHz)
  • TAC 35312597
Wireless specifications
  • Wireless 2.4 GHz Max data rate 574 Mbit/s
  • Wireless 2.4 GHz standards 802.11b/g/n/ax
  • Antenna gain dBi for 2.4 GHz 3
  • Wireless 2.4 GHz chip model QCN-5022
  • Wireless 2.4 GHz generation Wi-Fi 6
  • Wireless 5 GHz Max data rate 1200 Mbit/s
  • Wireless 5 GHz Number of chains 2
  • Wireless 5 GHz standards 802.11a/n/ac/ax
  • Antenna gain dBi for 5 GHz 6
  • Wireless 5 GHz chip model QCN-5052
  • Wireless 5 GHz generation Wi-Fi 6
Ethernet
  • 10/100/1000 Ethernet ports 4
  • Number of 2.5G Ethernet ports 1
Peripherals
  • Number of SIM slots 1 Modem (Micro SIM)
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB type A
  • Max USB current (A) 1
Other
  • CPU temperature monitor Yes
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • Mode button Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP 20
Included parts
Note
Wireless Specification
Ethernet test results
IPsec test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.24.5 download files for arm64 devices.
System Package
Default Packages
More in download page
