Skip to main content
Discontinued
wAP ac 4G kit
Small weatherproof Dual Band 2.4 / 5 GHz wireless access point with LTE antennas and modem for International bands 3, 7, 20, 31, 41n, 42 and 43
ARM
Quad-core CPU
IP 54
LTE Cat4
Mini PCI-e
Outdoors
PoE
Dual-band
wAP ac 4G kit
Product image
Product image
Product image thumbnail
A small package with a huge ambition – the wAP ac 4G is an extremely cost-effective dual-band (2.4 / 5 GHz) home access point based on our popular weatherproof wAP form factor. It has two Gigabit Ethernet ports – you can use the device as a wired router with LTE backup via the Micro SIM slot. Alternatively, you can also enjoy wireless experience anywhere – indoors or outdoors. wAP ac 4G is designed to deliver strong and reliable connection in almost any situation and weather conditions. It can withstand temperatures from -30 C‎° to +60 C‎ and can be easily mounted on walls, ceilings or poles.
Don’t be fooled by the compact size – this device is powered by a four-core 716 MHz CPU and 128 MB RAM, capable of handling heavy loads. Dual-chain 2.4 GHz and dual-chain 5GHz wireless for dual concurrent AP coverage will solve most interference issues in a crowded environment. For example, you can simultaneously use the 2.4 GHz channel for all your household mobile devices and reserve the 5GHz channel for tasks that are sensitive to packet loss – such as streaming high-quality videos.
RBwAPGR-5HacD2HnD&R11e-4G includes LTE modem that supports International LTE bands FDD bands 3 (1800MHz), 7 (2600MHz), 20 (800MHz) and 31 (450MHz), as well as LTE TDD bands 41n (2500MHz), 42 (3500MHz) and 43 (3700MHz).
High performance, great value, astonishing durability, functional and non-intrusive design – wAP ac 4G will meet most demands without making sacrifices.
Specification
Specifications
  • Product code RBwAPGR-5HacD2HnD&R11e-4G
  • Suggested price $169.00
  • Architecture ARM 32bit
  • CPU IPQ-4018
  • CPU core count 4
  • CPU nominal frequency 716 MHz
  • CPU Threads count 4
  • Switch chip model IPQ-4018
  • RouterOS license 4
  • Operating System RouterOS
  • Size of RAM 128 MB
  • Storage size 16 MB
  • Storage type FLASH
  • Tested ambient temperature -30°C to 60°C
Powering
  • Number of DC inputs 2 (DC jack, PoE-IN)
  • DC jack input Voltage 10-57 V
  • Max power consumption 14 W
  • Max power consumption without attachments 10 W
  • PoE in 802.3af/at
  • Cooling type Passive
  • PoE in input Voltage 18-57 V
Mobile
  • LTE Category 4 (150Mbps Downlink, 50Mbps Uplink)
  • LTE FDD bands 3 (1800MHz)
    7 (2600MHz)
    20 (800MHz)
    31 (450MHz)
  • LTE TDD bands 41n (2500MHz)
    42 (3500MHz)
    43 (3700MHz)
  • TAC 35914709
Wireless specifications
  • Wireless 2.4 GHz Max data rate 300 Mbit/s
  • Wireless 2.4 GHz standards 802.11b/g/n
  • Antenna gain dBi for 2.4 GHz 2.5
  • Wireless 2.4 GHz chip model IPQ-4018
  • Wireless 2.4 GHz generation Wi-Fi 4
  • Wireless 5 GHz Max data rate 867 Mbit/s
  • Wireless 5 GHz Number of chains 2
  • Wireless 5 GHz standards 802.11a/n/ac
  • Antenna gain dBi for 5 GHz 2.5
  • Wireless 5 GHz chip model IPQ-4018
  • Wireless 5 GHz generation Wi-Fi 5
Ethernet
  • 10/100/1000 Ethernet ports 2
Peripherals
  • Number of SIM slots 1 Modem (Micro SIM)
  • MiniPCI-e slots 1
Other
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
  • IP IP54
Included parts
Note
Wireless Specification
Ethernet test results
IPsec test results
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.1 download files for arm devices.
System Package
More in download page
