Skip to main content
New
SolidRACK 5 mini
A 10” 5U desktop rack with adjustable angle and additional space for cable management – compact, practical, and ready to make your life easier. You can even mount it under your desk!
SolidRACK 5 mini
Product image
Product image
Product image
Product image thumbnail
We love our routers and switches. So naturally, we built them a cozy little nest.
Reinvent the wheel? No, reinvent the nut!
Forget fiddling with awkward mounting hardware – and save your fingers while you’re at it. The mounting nuts slide freely along the rail, while a rubber insert provides just enough friction to keep them exactly where you leave them.
Five units of 10″ rack space give you plenty of room for routers, switches, power distribution, and more – without dedicating half the room to a traditional rack. Compatible with MikroTik and other equipment designed for standard 10″ racks. Optional 10″ mounting ears (coming soon!) let selected MikroTik devices join the setup too: L009, RB5009, and more to come!
Keep it at a strict 90° or give it a tilt for easier access, convenience, and a few extra style points. Just loosen the side screws, adjust, and tighten. Done in seconds!
The SolidRACK 5 mini ships disassembled in one remarkably compact eco box, with everything you need to put it together in a few minutes. Lightweight aluminium construction keeps it sturdy without unnecessary bulk, while included rubber pads help protect your desk from scratches.
SolidRACK 5 mini: a proper home for your network.
Specification
Specifications
  • Product code SR-5U-mini
  • Suggested price $49.00
Documents
Brochure
.PDF
Brochure PDF first page
