Skip to main content
New
LtAP LTE12 ax
Rugged connectivity for life on the move! The legendary LtAP is back, now with LTE Category 12 (up to 600 Mbps), dual-band Wi-Fi 6, eSIM support, and built-in GPS! With three Gigabit Ethernet ports, flexible powering options, RouterOS v7, and a rugged IP66-rated enclosure built to withstand temperatures from -40°C to +70°C, it's ready for anything. E-mark certified.
ARM
eSIM
GPS
IoT
IP 66
LTE Cat12
MIMO 4x4
Mini PCI-e
Outdoors
PoE
ROS v7
WiFi 6
Dual-band
LtAP LTE12 ax
Product image
Product image
Product image
Product image
Product image
Product image thumbnail
Some networks stay in server rooms. Others ride buses, cross borders, or work at remote industrial sites. The new LtAP LTE12 ax is built for the latter, bringing LTE Category 12, dual-band Wi-Fi 6, eSIM, GPS, and RouterOS v7 together in a rugged IP66-rated enclosure.
Crossing a border shouldn’t mean opening a router to replace its SIM card. With built-in eSIM support, a dual Nano SIM slot, and MikroTik Connectivity, the LtAP gives you more ways to manage cellular access. Choose the operator and data plan that work for your deployment, without making physical SIM swaps part of every journey!
Don’t have a mobile operator contract ready? You can still connect to the mobile network! It’s as easy as 1-2-3: sign in to your MikroTik account, add your LtAP, and pick a data plan. You’re ready to roll!
More connections than seats?
A modern vehicle can carry a whole network of its own: ticketing equipment, cameras, tracking systems, tablets, and more. LTE Cat12 with a 4x4 MIMO provides the cellular connection, while dual-band Wi-Fi 6 (with triple-chain 5 GHz radio with throughput up to 900 Mbit/s) and three Gigabit Ethernet ports take care of the devices on board. Built-in GPS adds positioning capabilities for fleet tracking and monitoring solutions.
Spare tire in the back, spare miniPCIe slot in the LtAP
Need another fallback cellular connection? The miniPCIe slot lets you install a compatible second modem and configure failover through RouterOS. You also get the familiar MikroTik toolkit: VPNs, advanced routing, firewall rules, and remote administration. Can’t go wrong with more backup options in the middle of nowhere, can you?
We’ve learned a thing or two from years of LtAPs on buses, trucks, and out in the field. Meet our toughest LtAP yet, with a brand-new IP66-rated enclosure!
Wall or pole? Your call. The LtAP supports wall mounting and both horizontal and vertical pole mounting. Need external antennas? Dedicated drilling spots let you add SMA connectors.
Who said automation was just for smart homes?
The LtAP comes with an analog input and a digital output, opening up possibilities beyond networking. Connect external sensors, monitor voltage signals, and use RouterOS scripting to automate responses. For example, monitor equipment temperature and activate a cooling fan through an external relay when things get too hot. Simple, practical automation for vehicles, remote installations, and industrial environments.
Specification
Specifications
  • Product code LtAP-5HaxT2HaxD&EG120K-EA
  • Suggested price $329.00
  • Architecture ARM 32bit
  • CPU EN7562CT
  • CPU core count 2
  • CPU nominal frequency 950 MHz
  • CPU Threads count 2
  • Switch chip model EN7562CT
  • RouterOS license 4
  • Operating System RouterOS v7
  • Size of RAM 512 MB
  • Storage size 128 MB
  • Storage type NAND
Powering
  • Number of DC inputs 3 (DC jack, PoE-IN, 2-pin terminal)
  • DC jack input Voltage 12-57 V
  • 2-pin terminal input Voltage 12-57 V
  • Max power consumption 21 W
  • Max power consumption without attachments 15 W
  • PoE in 802.3af/at
  • Cooling type Passive
  • PoE in input Voltage 18-57 V
Mobile
  • 3G Category R8 (DL: 42.2 Mbps; UL: 5.76 Mbps)
  • 3G bands 1 (2100 MHz)
    3 (1800 MHz)
    5 (850 MHz)
    8 (900 MHz)
  • LTE Category 12 (DL: 600 Mbps; UL: 150 Mbps)
  • MIMO DL 4x4
  • MIMO UL 1x1
  • LTE FDD bands 1 (2100 MHz)
    3 (1800 MHz)
    5 (850 MHz)
    7 (2600 MHz)
    8 (900 MHz)
    20 (800 MHz)
    28 (700 MHz)
    32 (1500 MHz)
  • LTE TDD bands 38 (2600 MHz)
    40 (2300 MHz)
    41 (2500 MHz)
    42 (3500 MHz)
    43 (3700 MHz)
  • TAC 86056104
Wireless specifications
  • Wireless 2.4 GHz Max data rate 574 Mbit/s
  • Wireless 2.4 GHz standards 802.11b/g/n/ax
  • Antenna gain dBi for 2.4 GHz 6
  • Wireless 2.4 GHz chip model MT7916AN
  • Wireless 2.4 GHz generation Wi-Fi 6
  • Wireless 5 GHz Max data rate 1800 Mbit/s
  • Wireless 5 GHz Number of chains 3
  • Wireless 5 GHz standards 802.11a/n/ac/ax
  • Antenna gain dBi for 5 GHz 7.5
  • Wireless 5 GHz chip model MT7976AN
  • Wireless 5 GHz generation Wi-Fi 6
Ethernet
  • 10/100/1000 Ethernet ports 3
Peripherals
  • Number of SIM slots 2 Modem (Nano SIM)
  • MiniPCI-e slots 1
  • Serial console port RJ45
  • Number of USB ports 1
  • USB Power Reset Yes
  • USB slot type USB type A
  • Max USB current (A) 1
Other
  • CPU temperature monitor Yes
  • PCB temperature monitor Yes
  • Voltage Monitor Yes
  • eSIM Yes
Certification & Approvals
  • Certification CE, EAC, ROHS
  • IP 66
Included parts
Note
Documents
Brochure
.PDF
Brochure PDF first page
Download
Latest RouterOS stable release v7.25.1 download files for arm devices.
System Package
More in download page
