Skip to main content
New
hAP be lite
The most affordable Wi-Fi 7 router & access point for networks that need the flexibility and the power of RouterOS. USB-C powering, 2.5 Gigabit & Gigabit Ethernet, Wi-Fi 7 Multi-Link Operation, BE3600
Triple-chain 7 dBi 5 GHz
Dual-chain 4.4 dBi 2.4 GHz
Powering via USB-C
Dual-core ARM CPU
512 MB DDR3 RAM
1x 2.5G Ethernet
3x 1G Ethernet
The hAP be lite brings modern Wi-Fi 7 performance and RouterOS flexibility into a compact and affordable platform built for setups where space, style, speed, and budget all matter equally. The compact design, low power consumption (up to 12 W), and USB-C powering make placement simple almost anywhere.
Wi-Fi 7 built to deliver more & cost less
Powerful dual-band Wi-Fi 7 antennas and WiFi 7 Multi-Link Operation (MLO) deliver BE3600-class wireless performance for laptops, phones, tablets, and other everyday devices.
Our Wi-Fi 7 products are designed for today’s extremely crowded wireless environments, where more devices than ever are competing for the same airspace. Even in busy areas, Wi-Fi 7 helps keep connections smooth and responsive. The hAP be lite combines dual-chain 2.4 GHz and triple-chain 5 GHz radios, giving additional wireless capacity where modern devices need it most.
On the wired side, we have three Gigabit Ethernet ports and one 2.5 Gigabit Ethernet port for high-speed uplinks, workstations, NAS devices, or other demanding situations.
RouterOS: for tinkerers, optimizers,
and power users alike
Under the hood, the hAP be lite runs on a modern dual-core ARM CPU at 950 MHz with 512 MB of RAM, delivering reliable performance for advanced networking tasks and heavy traffic.
But hardware is only part of the story. With RouterOS, you get far more than basic wireless connectivity. Fully customize your setup to match your exact needs.
Build VLANs
Configure VPNs
Shape traffic
Apply advanced firewall rules
Automate tasks with scripting
No artificial limits. No subscriptions, paywalls or locked features. RouterOS gives you full control, whether you are managing a single compact setup or a much larger network.
You also get access to the updated CAPsMAN for centralized management of multiple MikroTik access points from a single interface.
hAP be lite
Product image
Product image
Product image
Product image
Product image thumbnail
Specification
Specifications
  • Product code A42G-HbeP
  • Suggested price $79.00
  • Architecture ARM 32bit
  • CPU AN7563PT
  • CPU core count 2
  • CPU nominal frequency 950 MHz
  • CPU Threads count 2
  • Switch chip model AN7563PT
  • RouterOS license 4
  • Operating System RouterOS v7
  • Size of RAM 512 MB
  • Storage size 128 MB
  • Storage type NAND
  • Tested ambient temperature -40°C to 50°C
Wireless capabilities
  • Wireless 2.4 GHz Max data rate 688 Mbit/s
  • Wireless 2.4 GHz standards 802.11b/g/n/ax/be
  • Antenna gain dBi for 2.4 GHz 4.4
  • Wireless 2.4 GHz chip model MT7991
  • Wireless 2.4 GHz generation Wi-Fi 7
  • Wireless 5 GHz Max data rate 2882 Mbit/s
  • Wireless 5 GHz Number of chains 3
  • Wireless 5 GHz standards 802.11a/n/ac/ax/be
  • Antenna gain dBi for 5 GHz 7
  • Wireless 5 GHz chip model MT7991
  • Wireless 5 GHz generation Wi-Fi 7
  • WiFi speed BE3600
Ethernet
  • 10/100/1000 Ethernet ports 3
  • Number of 2.5G Ethernet ports 1
Powering
  • Number of DC inputs 1 (USB-C)
  • Max power consumption 12 W
  • Cooling type Passive
  • USB C input Voltage 5 V
Certification & Approvals
  • Certification CE, FCC, IC, EAC, ROHS
  • IP 20
Other
  • CPU temperature monitor Yes
Included parts
Note
Wireless Specification
Ethernet test results
IPsec test results
Download
Latest RouterOS stable release v7.24.5 download files for arm devices.
System Package
Default Packages
More in download page
